Ana içeriğe geç
DualSense Controller v2 Joystick Replacement
Neye ihtiyacın var
  1. DualSense Controller v2 Joystick Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 2.
    • Disconnect and power down the controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Joystick Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 3.
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Joystick Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 2.
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Joystick Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 3.
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Joystick Replacement, Remove the middle trim: adım 5, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Remove the middle trim: adım 5, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Remove the middle trim: adım 5, 3 resimden 3.
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
  6. DualSense Controller v2 Joystick Replacement, Remove the L1 button: adım 6, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Remove the L1 button: adım 6, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Remove the L1 button: adım 6, 3 resimden 3.
    • Insert the flat end of a spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry the spudger upward to remove the L1 button.
  7. DualSense Controller v2 Joystick Replacement, Remove the R1 button: adım 7, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Remove the R1 button: adım 7, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Remove the R1 button: adım 7, 3 resimden 3.
    • Insert the flat end of a spudger into the gap above the R1 button.
    • Pry the spudger upward to remove the R1 button.
  8. DualSense Controller v2 Joystick Replacement, Remove the case screws: adım 8, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller v2 Joystick Replacement: adım 9, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller v2 Joystick Replacement, Unclip the rear case: adım 10, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Unclip the rear case: adım 10, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Unclip the rear case: adım 10, 3 resimden 3.
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. DualSense Controller v2 Joystick Replacement, Remove the rear case: adım 11, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Remove the rear case: adım 11, 2 resimden 2.
    • Use your hands to carefully pull the rear case off of the controller.
    • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
  12. DualSense Controller v2 Joystick Replacement, Reposition the battery: adım 12, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Reposition the battery: adım 12, 2 resimden 2.
    • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
    • Don't strain the battery cables.
  13. DualSense Controller v2 Joystick Replacement, Disconnect the battery: adım 13, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Disconnect the battery: adım 13, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Don't pull on the wires to disconnect the battery.
  14. DualSense Controller v2 Joystick Replacement, Remove the battery: adım 14, 1 resimden 1.
    • Remove the battery.
  15. DualSense Controller v2 Joystick Replacement, Remove the lower microphone: adım 15, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Remove the lower microphone: adım 15, 2 resimden 2.
    • Use the pointed end of a spudger to remove the lower microphone from its bracket next to the battery.
    • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
  16. DualSense Controller v2 Joystick Replacement: adım 16, 2 resimden 1. DualSense Controller v2 Joystick Replacement: adım 16, 2 resimden 2.
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  17. DualSense Controller v2 Joystick Replacement, Remove the battery bracket: adım 17, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
  18. DualSense Controller v2 Joystick Replacement: adım 18, 2 resimden 1. DualSense Controller v2 Joystick Replacement: adım 18, 2 resimden 2.
    • Lift the battery bracket off of the motherboard.
  19. DualSense Controller v2 Joystick Replacement, Disconnect the right trigger assembly: adım 19, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Disconnect the right trigger assembly: adım 19, 2 resimden 2.
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
    • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
    • Don't completely remove the ribbon cable yet.
  20. DualSense Controller v2 Joystick Replacement: adım 20, 2 resimden 1. DualSense Controller v2 Joystick Replacement: adım 20, 2 resimden 2.
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers, and disconnect it from the trigger assembly.
    • Depending on the controller's model, the ribbon cable may block the motherboard from coming loose. If so, remove the cable from the trigger assembly.
  21. DualSense Controller v2 Joystick Replacement, Disconnect the left trigger assembly: adım 21, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Disconnect the left trigger assembly: adım 21, 2 resimden 2.
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
  22. DualSense Controller v2 Joystick Replacement: adım 22, 2 resimden 1. DualSense Controller v2 Joystick Replacement: adım 22, 2 resimden 2.
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the trigger assembly.
  23. DualSense Controller v2 Joystick Replacement, Disconnect the upper microphone: adım 23, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Disconnect the upper microphone: adım 23, 2 resimden 2.
    • Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
    • If you're not replacing this microphone, don't remove it from the frame.
  24. DualSense Controller v2 Joystick Replacement, Disconnect the touchpad: adım 24, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Disconnect the touchpad: adım 24, 2 resimden 2.
    • Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
  25. DualSense Controller v2 Joystick Replacement, Lift out the motherboard: adım 25, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Lift out the motherboard: adım 25, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Lift out the motherboard: adım 25, 3 resimden 3.
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Don't strain the four soldered wires tethering the motherboard to the vibration motors.
  26. DualSense Controller v2 Joystick Replacement, Desolder the vibration motor wires: adım 26, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Desolder the vibration motor wires: adım 26, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Desolder the vibration motor wires: adım 26, 3 resimden 3.
    FixHub | Power Series Smart Soldering Iron
    $79.95
    • Flip the motherboard and midframe over to access the red and black vibration motor wires.
    • Use a soldering iron to disconnect the vibration motor wires from the motherboard.
    • To learn how to solder, or to get some helpful tips and tricks, check out our soldering guide.
    • During reassembly, refer to this photo to ensure the wires are soldered back to their correct positions.
  27. DualSense Controller v2 Joystick Replacement, Remove the joystick covers: adım 27, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Remove the joystick covers: adım 27, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Remove the joystick covers: adım 27, 3 resimden 3.
    • Use your fingers to remove the left and right joystick covers from the motherboard.
  28. DualSense Controller v2 Joystick Replacement, Remove the speaker: adım 28, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Remove the speaker: adım 28, 2 resimden 2.
    • Use your fingers to remove the speaker and foam pad from the motherboard.
    • Only the motherboard remains.
    • During reassembly, make sure the gold contacts on the speaker are aligned with the gold contacts on the motherboard.
  29. DualSense Controller v2 Joystick Replacement, Solder joint overview: adım 29, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Solder joint overview: adım 29, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Solder joint overview: adım 29, 3 resimden 3.
    • Your DualSense motherboard may look slightly different than the images in this guide, but you can still follow the procedure to replace it.
    • Each joystick module is secured with 14 solder joints:
    • Four anchor joints
    • Six joints connecting the two potentiometers
    • Four joystick push-button joints
    • The remaining steps will show how to replace the left joystick (with the controller facing you). You can follow the same procedure to replace the right joystick.
  30. DualSense Controller v2 Joystick Replacement, Prepare the potentiometers: adım 30, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Prepare the potentiometers: adım 30, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Prepare the potentiometers: adım 30, 3 resimden 3.
    • Each joystick module has two potentiometers—they're the colored square blocks along two sides of the joystick.
    • Insert the tips of a pair of angled tweezers between the top edge of a potentiometer and the joystick frame.
    • Pivot the tweezers down to bend the top edge of the potentiometer away from the joystick frame.
  31. DualSense Controller v2 Joystick Replacement: adım 31, 3 resimden 1. DualSense Controller v2 Joystick Replacement: adım 31, 3 resimden 2. DualSense Controller v2 Joystick Replacement: adım 31, 3 resimden 3.
    • Repeat the procedure on the second potentiometer.
  32. DualSense Controller v2 Joystick Replacement: adım 32, 2 resimden 1. DualSense Controller v2 Joystick Replacement: adım 32, 2 resimden 2.
    • Use tweezers to remove the wiper mechanisms out of both potentiometers.
  33. DualSense Controller v2 Joystick Replacement, Secure the motherboard: adım 33, 1 resimden 1.
    Helping Hands
    $9.99
    • Secure the motherboard with helping hands or a similar tool so that the potentiometer solder joints face up.
    • Attach clips to the clear areas on the board to prevent damaging the surface-mounted components.
  34. DualSense Controller v2 Joystick Replacement, Desolder the potentiometers: adım 34, 1 resimden 1.
    No-Clean Flux
    $4.95
    • Apply flux to the three solder joints securing one of the potentiometers.
    • Flux improves the flow of molten solder, which makes it easier to work with. If you're having trouble with goopy or sticky solder, apply more flux.
  35. DualSense Controller v2 Joystick Replacement: adım 35, 1 resimden 1.
    • Set the soldering iron to 375–400 °C (~700–750 °F).
    • The DualSense controller has lead-free solder, which requires a higher working temperature than leaded solder.
    • For full instructions on how to desolder through-hole solder joints, follow this guide.
    • Press the soldering iron tip against a potentiometer joint to heat it.
    • Don't heat the joint longer than 15 seconds at a time, or you risk damaging the solder pad.
    • If you're having trouble melting the solder joint, apply some leaded solder onto the soldering iron tip and try again. The leaded solder helps with heat transfer while lowering the melting temperature of the existing lead-free solder joint.
    • Once the joint's molten, use a desoldering pump to suck away the solder.
    • Repeat the heating and sucking procedure a few times on the same joint to remove as much solder as possible. Be sure not to heat the joint longer than 15 seconds at a time.
  36. DualSense Controller v2 Joystick Replacement: adım 37, 1 resimden 1.
    • Repeat the procedure on the remaining two potentiometer joints.
  37. DualSense Controller v2 Joystick Replacement: adım 38, 1 resimden 1.
    • This step shows how to remove residual solder with a solder wick. If the potentiometer feels loose, skip this step.
    • Apply flux to the solder joint.
    • Lay a piece of clean solder wick over the solder joint.
    • Press the tip of the soldering iron over the wick so that the residual solder melts and transfers into the wick.
    • Repeat the process with the remaining two solder joints.
  38. DualSense Controller v2 Joystick Replacement: adım 39, 3 resimden 1. DualSense Controller v2 Joystick Replacement: adım 39, 3 resimden 2. DualSense Controller v2 Joystick Replacement: adım 39, 3 resimden 3.
    • Use tweezers or pliers to gently pull the potentiometer away from the board.
    • If the potentiometer feels stuck, repeat the previous three steps to try to remove the residual solder holding the potentiometer in place.
    • You can also try heating each joint as you wiggle the potentiometer out of the board. This is best accomplished with help from a friend.
  39. DualSense Controller v2 Joystick Replacement: adım 40, 3 resimden 1. DualSense Controller v2 Joystick Replacement: adım 40, 3 resimden 2. DualSense Controller v2 Joystick Replacement: adım 40, 3 resimden 3.
    • Repeat the desoldering procedure to desolder and remove the second potentiometer.
  40. DualSense Controller v2 Joystick Replacement, Cut apart the joystick frame: adım 41, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Cut apart the joystick frame: adım 41, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Cut apart the joystick frame: adım 41, 3 resimden 3.
    • The next few steps show how to break apart and desolder the joystick frame.
    • Use flush cutters to cut the top corners of the joystick frame.
    • Be very careful not to cut yourself on the sharp edges. Bend any sharp edges down with pliers.
  41. DualSense Controller v2 Joystick Replacement: adım 42, 1 resimden 1.
    • Use pliers to bend the metal frame outwards from the module.
  42. DualSense Controller v2 Joystick Replacement: adım 43, 2 resimden 1. DualSense Controller v2 Joystick Replacement: adım 43, 2 resimden 2.
    • Remove the plastic components from the center of the joystick module.
    • Remove any loose pieces from the joystick module.
  43. DualSense Controller v2 Joystick Replacement: adım 44, 2 resimden 1. DualSense Controller v2 Joystick Replacement: adım 44, 2 resimden 2.
    • Use flush cutters to cut apart the top sections of the remaining frame walls, separating each wall into two pieces.
  44. DualSense Controller v2 Joystick Replacement, Desolder the cut pins: adım 45, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Desolder the cut pins: adım 45, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Desolder the cut pins: adım 45, 3 resimden 3.
    • Secure the motherboard so that the solder joints face upward.
    • Use the soldering iron to heat a solder joint securing one of the frame anchors.
    • Once the solder is molten, use pliers to grab and pull the frame anchor out of its through-hole.
    • Repeat the procedure to remove all four anchor joints.
  45. DualSense Controller v2 Joystick Replacement, Remove the push-button: adım 46, 3 resimden 1. DualSense Controller v2 Joystick Replacement, Remove the push-button: adım 46, 3 resimden 2. DualSense Controller v2 Joystick Replacement, Remove the push-button: adım 46, 3 resimden 3.
    • Slide the flat end of a spudger under the joystick module's plastic base.
    • Slowly pry up the base to bend and break it away from the motherboard.
    • Remove the plastic base.
  46. DualSense Controller v2 Joystick Replacement: adım 47, 2 resimden 1. DualSense Controller v2 Joystick Replacement: adım 47, 2 resimden 2.
    • Use flush cutters and pliers to break and remove the plastic base remnants from the push-button.
    • Use flush cutters to cut the four push-button pins securing it to the motherboard.
  47. DualSense Controller v2 Joystick Replacement: adım 48, 2 resimden 1. DualSense Controller v2 Joystick Replacement: adım 48, 2 resimden 2.
    • Remove the push-button.
    • Remove any plastic base remnants.
  48. DualSense Controller v2 Joystick Replacement: adım 49, 2 resimden 1. DualSense Controller v2 Joystick Replacement: adım 49, 2 resimden 2.
    • Use the soldering iron to heat a solder joint securing one of the push-button pins.
    • Once the solder is molten, use tweezers to grab the pin and pull it out of its through-hole.
    • Repeat the procedure to remove all four push-button pins.
  49. DualSense Controller v2 Joystick Replacement, Clean up the through-holes: adım 50, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Clean up the through-holes: adım 50, 2 resimden 2.
    • Secure the motherboard so you can access both sides of it.
    • Use the soldering iron to heat one side of a through-hole.
    • Use a desoldering pump on the opposite side of the through-hole to suck up any remaining solder.
    • Don't heat the through-hole continuously for longer than 15 seconds at a time to avoid damaging the pad.
    • If needed, use solder wick to remove any residual solder.
    • Repeat this for all through-holes and both sides of the motherboard.
  50. DualSense Controller v2 Joystick Replacement: adım 51, 1 resimden 1.
    • Visually inspect each through-hole and make sure they're not blocked by residual solder. If some holes look blocked, repeat the previous step to clear the blockage.
  51. DualSense Controller v2 Joystick Replacement, Clean the surface of the motherboard: adım 52, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Clean the surface of the motherboard: adım 52, 2 resimden 2.
    • Apply a few drops of high concentration (>90%) isopropyl alcohol to the top side of the motherboard, where the new joystick module will sit.
    • Use a cotton swab or a soft brush and cloth to wipe away the flux residue.
  52. DualSense Controller v2 Joystick Replacement, Solder the replacement joystick: adım 53, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Solder the replacement joystick: adım 53, 2 resimden 2.
    • Place the replacement joystick module onto the motherboard so that all the pins thread through the through-holes.
    • Gently press the joystick onto the board so that the joystick sits flush with the board surface.
  53. DualSense Controller v2 Joystick Replacement: adım 54, 1 resimden 1.
    • Flip the motherboard over and secure it so that you can solder the joystick module pins.
    • Apply flux to one of the frame anchors to prep it for soldering.
    • For full instructions on how to solder through-hole solder joints, follow this guide.
    • Solder one of the frame anchors to the motherboard.
  54. DualSense Controller v2 Joystick Replacement: adım 56, 1 resimden 1.
    • Check that the joystick module is still sitting flush on top of the motherboard (as shown). If it isn't, reheat the soldered pin and reposition the module.
  55. DualSense Controller v2 Joystick Replacement: adım 57, 1 resimden 1.
    • Solder the remaining joystick module pins (14 total) to the motherboard. Apply flux as you solder to help create good bonds.
  56. DualSense Controller v2 Joystick Replacement, Clean and inspect your work: adım 58, 2 resimden 1. DualSense Controller v2 Joystick Replacement, Clean and inspect your work: adım 58, 2 resimden 2.
    • Apply a few drops of high concentration (>90%) isopropyl alcohol to the motherboard wherever you can see flux residue.
    • Visually inspect your work:
    • Make sure each solder joint looks well-formed.
    • Make sure no solder joints are shorting each other.
Sonuç
Congratulations! You've replaced the controller's joystick and, in the process, leveled up your soldering skills.
To reassemble the controller, go to this step and follow the instructions in reverse order.
You'll need to run the calibration tool to calibrate the new joystick.
7 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
309.486 İtibar
701 adet Kılavuz yazıldı
1Rehber Yorum
Is there a calibration element post install of the new modules?
iDoctor Cell Phone Repair - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 58
Son 7 gün: 399
Son 30 gün: 1,695
Her zaman: 9,389
