Ana içeriğe geç
DualShock 4 CHU-ZCT2U Battery Replacement
Neye ihtiyacın var
  1. DualShock 4 CHU-ZCT2U Battery Replacement, Remove the rear panel screws: adım 1, 2 resimden 1. DualShock 4 CHU-ZCT2U Battery Replacement, Remove the rear panel screws: adım 1, 2 resimden 2.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CHU-ZCT2U Battery Replacement, Separate the rear panel: adım 2, 2 resimden 1. DualShock 4 CHU-ZCT2U Battery Replacement, Separate the rear panel: adım 2, 2 resimden 2.
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CHU-ZCT2U Battery Replacement, Release the plastic clips: adım 3, 3 resimden 1. DualShock 4 CHU-ZCT2U Battery Replacement, Release the plastic clips: adım 3, 3 resimden 2. DualShock 4 CHU-ZCT2U Battery Replacement, Release the plastic clips: adım 3, 3 resimden 3.
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CHU-ZCT2U Battery Replacement, Remove the rear panel: adım 4, 2 resimden 1. DualShock 4 CHU-ZCT2U Battery Replacement, Remove the rear panel: adım 4, 2 resimden 2.
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Battery Replacement: adım 5, 2 resimden 1. DualShock 4 CHU-ZCT2U Battery Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
  6. DualShock 4 CHU-ZCT2U Battery Replacement, Remove the battery: adım 6, 2 resimden 1. DualShock 4 CHU-ZCT2U Battery Replacement, Remove the battery: adım 6, 2 resimden 2.
    Satın Al
    • Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
  7. DualShock 4 CHU-ZCT2U Battery Replacement: adım 7, 2 resimden 1. DualShock 4 CHU-ZCT2U Battery Replacement: adım 7, 2 resimden 2.
    • Remove the battery.
Sonuç
28 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
75.409 İtibar
288 adet Kılavuz yazıldı
3 Yorum
For this DualShock 4 CHU-ZCT2U Battery Replacement, shouldn’t the battery model be JDM-040 and not JDM-030 for this controller. I ordered the battery listed but the connector was too large. So I believe this needs to be edited to match accordingly to avoid confusion and incorrect orders. Thanks!
Tom Nguyen - Yanıt
Good catch! I just pulled apart the ZCT1U and ZCT2U models and you are right. I will fix this in the guide. Thank you!
Sam Omiotek -
Can perhaps someone tell me what exact connector does the original battery use ?
MCQ - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 231
Son 30 gün: 1,165
Her zaman: 27,330
