Ana içeriğe geç
Dyson DC33 Brush Deep Clean
Steve Bonds
Steve Bonds ve başka bir katkıda bulunan
En son December 14, 2018 tarihinde güncellendi
30 dakika - 2 saat
Orta
Topluluk-Katkılı Kılavuz
When the brush bar can't turn, the vacuum makes a horrible clicking-grinding noise while working on carpet. After about five to ten regular cleanings, chances are enough debris has managed to sneak around the end caps that this deep cleaning is needed.
Ideally this gets done before the bar is so choked with hair that the friction starts melting it. This guide exists so that you can learn from the misfortune of others!
Neye ihtiyacın var
  1. Dyson DC33 Brush Deep Clean, Remove Brush Bar: adım 1, 1 resimden 1.
  2. Dyson DC33 Brush Deep Clean, Remove End Caps from Brush Bar: adım 2, 3 resimden 1. Dyson DC33 Brush Deep Clean, Remove End Caps from Brush Bar: adım 2, 3 resimden 2. Dyson DC33 Brush Deep Clean, Remove End Caps from Brush Bar: adım 2, 3 resimden 3.
    • These are not threaded.
    • Gently hold one end cap while pulling on the other. Wiggle back and forth to slide the cap off the rod running through the center of the brush bar.
    • The spots where hair/debris needs to be removed are circled in red in the third photo.
  3. Dyson DC33 Brush Deep Clean, Remove Debris from Behind End Caps: adım 3, 3 resimden 1. Dyson DC33 Brush Deep Clean, Remove Debris from Behind End Caps: adım 3, 3 resimden 2. Dyson DC33 Brush Deep Clean, Remove Debris from Behind End Caps: adım 3, 3 resimden 3.
    • Easy-- just grab the hair and debris and pull.
  4. Dyson DC33 Brush Deep Clean, Brush Bar Repair or Replacement: adım 4, 3 resimden 1. Dyson DC33 Brush Deep Clean, Brush Bar Repair or Replacement: adım 4, 3 resimden 2. Dyson DC33 Brush Deep Clean, Brush Bar Repair or Replacement: adım 4, 3 resimden 3.
    • Problems created by the friction and heat can be trivially prevented with some routine maintenance once owners know that it needs to be done. The debris was causing enough friction and heat to actually melt the brush bar.
    • The bearing itself is a metal ring with ball bearings at the end of the brush bar.
    • The sleeve area where the hair and plastic melted together is not supposed to be a bearing surface. This means that it doesn't need to be very smooth so an unskilled scraping with a utility knife to remove the melted plastic and debris is good enough to make it work.
    • Use a utility knife to carve/scrape away melted plastic and debris until it clears the end cap. It doesn't need to be pretty.
    • Optionally, replace the whole brush bar if it's too far gone or the repair goes poorly.
    I used a wet qtip to clean all the junk out..worked beautifully!!
    Erin E Armijo - Yanıt
  5. Dyson DC33 Brush Deep Clean, Reassembly: adım 5, 1 resimden 1.
    • Insert the rod through the brush bar and press the cap back on the end.
    • The hardest part is getting the end of the brush bar under that tight motor belt. Look for where it hangs up and use the screwdriver shaft to pull in an appropriate direction to allow the brush bar to slide a bit more through.
    • Once the bar is in align the small end of the caps towards the back of the vacuum (as shown)
    • When putting the cover back on, snap the front in first, then press the coin-operated tabs through their holes and turn with a coin.
    • Congrats! You don't need a new vacuum or expensive repair!
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Steve Bonds
1.126 İtibar
1 Kılavuz yazıldı
Ekip
DXC DXC üyesi
Business
1 Üye
1 Kılavuz yazıldı
9Kılavuz Yorumları
Thank you, finding info on the proper brush placement was difficult. Thanks for your help. Scott
Scott Johnson - Yanıt
It worked! Beater bar spins strongly now! Some much hair and debris under the end caps! And the pain in my my fingers when they pinched between the belt and the bar is slowly going away lol. Seriously, my wife was ready to buy a new vacuum, so thank you!!!
John Watson - Yanıt
My beater bar on my DC33 is not moving and there is no suction. There is strong suction on the attachment tool. My husband did get all
the hair and debris from the beater bar.
Sherri - Yanıt
Oh my gosh..so many videos just said to clean the brush..finding your tutorial for deep cleaning was a godsend- THANK YOU for sparing me the expense of replacing..thiswas the "last ditch effort" before I bought the bullet and bought a new one tomorrow! I am sending positive karma vibes your way-- without your lesson, the black dust and "uck" would have never been found and eliminated!!
I have a Dyson dc 33 and I done this and the brush spins but whenever I put the cleaner on the floor it stops spinning on hardwood floor and carpet what’s going on or what can I do to fix it ?
Justin Shaffer - Yanıt
Thank you for posting this tutorial! I wish Dyson would include this part in their brush cleaning process. Cleaning the end caps is what mine needed the actually get the brush to spin again. No money spent!
psr91676 - Yanıt
Guys, hello, anyone cleaned deeply his DC33c original brush ?
Mehdi BENSMAINE - Yanıt
just did and it was a breeze.
Tom Shannon -
Thanks, you were thorough and concise. You made it an easy repair. I would not have figured out how to remove the end caps.
Tom Shannon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 45
Her zaman: 11,422
