Equity Alarm Clock 13014 Alarm Replacement
Neye ihtiyacın var
Use a spudger to open and detach the wiring from the box holding the battery.
Insert the flat end of the spudger on both sides of the box, gently pry it open and detach it from the clock.
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Is there someone I can send my alarm clock to for fixing? IF so, how much would it cost? I do not have the tools nor the know how to do it. Most likely, the alarm will have to be replaced. The little motor on the inside is not working when it is time for it to go off. It does not move the ringer/clanger. Thanks,
mariacarbonell@comcast.net
