Ana içeriğe geç
Garmin Rino 700 Battery Replacement
Neye ihtiyacın var
  1. Garmin Rino 700 Battery Replacement, Battery Disconnect: adım 1, 1 resimden 1.
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
  2. Garmin Rino 700 Battery Replacement: adım 2, 2 resimden 1. Garmin Rino 700 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the battery cover and set it to the side.
  3. Garmin Rino 700 Battery Replacement: adım 3, 2 resimden 1. Garmin Rino 700 Battery Replacement: adım 3, 2 resimden 2.
    • Use the spudger to disconnect the battery wire port from the motherboard.
  4. Garmin Rino 700 Battery Replacement, Battery: adım 4, 3 resimden 1. Garmin Rino 700 Battery Replacement, Battery: adım 4, 3 resimden 2. Garmin Rino 700 Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Using a Phillips #000 screwdriver, remove the two 4.8 mm screws holding the battery bracket in place.
    • Using a plastic opening tool, remove the battery from the back case of the device.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Abigail Dugan
512 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 5-5, Hunter Fall 2021 Clemson, Team 5-5, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S5G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 40
Her zaman: 1,557
