Ana içeriğe geç
Garmin Rino 700 Charging Port Replacement
Abigail Dugan
Abigail Dugan ve 5 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
40 - 45 dakika
Zor
If you find that your Garmin Rino 700 is having battery charging issues (i.e. when you plug it up to charge, it is abnormally slow or not charging at all), you may need to replace the charging port. Replacing the charging port should allow for your Garmin Rino 700 to charge correctly and efficiently again.
For this replacement guide you’ll need a T5 Torx Screwdriver, a TR6 Torx Security Screwdriver, a spudger, an iFixit opening tool, a soldering workstation, and tweezers. This process does involve soldering which can be hazardous as it does involve heat. For more information on soldering connections, please visit this guide. Additionally, you will be picking at small parts within your Garmin Rino 700 so be sure to use caution as to not break any important parts. Going forward, you can see how to prevent these issues on our troubleshooting page: Garmin Rino 700 Troubleshooting
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Garmin Rino 700 Charging Port Replacement, Battery Disconnect: adım 1, 1 resimden 1.
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
  2. Garmin Rino 700 Charging Port Replacement: adım 2, 2 resimden 1. Garmin Rino 700 Charging Port Replacement: adım 2, 2 resimden 2.
    • Remove the battery cover and set it to the side.
  3. Garmin Rino 700 Charging Port Replacement: adım 3, 2 resimden 1. Garmin Rino 700 Charging Port Replacement: adım 3, 2 resimden 2.
    • Use the spudger to disconnect the battery wire port from the motherboard.
  4. Garmin Rino 700 Charging Port Replacement, Motherboard: adım 4, 2 resimden 1. Garmin Rino 700 Charging Port Replacement, Motherboard: adım 4, 2 resimden 2.
    • Using the T5 Torx screwdriver, remove the two 6.4 mm screws on the motherboard.
  5. Garmin Rino 700 Charging Port Replacement: adım 5, 3 resimden 1. Garmin Rino 700 Charging Port Replacement: adım 5, 3 resimden 2. Garmin Rino 700 Charging Port Replacement: adım 5, 3 resimden 3.
    • Using the nylon spudger, lift the motherboard out of its position.
    • Slide the motherboard out of the front panel of the device.
    • Carefully disconnect the motherboard from the panel and remove it out of the device.
  6. Garmin Rino 700 Charging Port Replacement, Charging Port: adım 6, 2 resimden 1. Garmin Rino 700 Charging Port Replacement, Charging Port: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
Sonuç
Bir başkası bu kılavuzu tamamladı.
Abigail Dugan
512 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 5-5, Hunter Fall 2021 Clemson, Team 5-5, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S5G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 384
