Ana içeriğe geç
Garmin Rino 700 Satellite Antenna Replacement
Abigail Dugan
Abigail Dugan ve 5 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
25 - 30 dakika
Orta
If your garmin Rino 700 refuses to connect or will not stay connected long to satellites, you may be needing to replace the satellite antenna. Your device may simply be out of range or may not have had enough time to connect but if thats not the case you can replace the satellite antenna following the steps listed below. This repair is needed for circumstances like if your having trouble accessing satellite signals or if your device is out of range and won’t gain signal.
In this guide the only special requirements you will need are a TR6 Torx Security screwdriver, a T5 Torx screwdriver, and a spudger. One hazard with this guide is that you have to apply heat during the last step so do so carefully. For more information on soldering connections, please visit this guide. Going forward, you can see how to prevent these issues on our troubleshooting page: Garmin Rino 700 Troubleshooting
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Garmin Rino 700 Satellite Antenna Replacement, Battery Disconnect: adım 1, 1 resimden 1.
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
  2. Garmin Rino 700 Satellite Antenna Replacement: adım 2, 2 resimden 1. Garmin Rino 700 Satellite Antenna Replacement: adım 2, 2 resimden 2.
    • Remove the battery cover and set it to the side.
  3. Garmin Rino 700 Satellite Antenna Replacement: adım 3, 2 resimden 1. Garmin Rino 700 Satellite Antenna Replacement: adım 3, 2 resimden 2.
    • Use the spudger to disconnect the battery wire port from the motherboard.
  4. Garmin Rino 700 Satellite Antenna Replacement, Motherboard: adım 4, 2 resimden 1. Garmin Rino 700 Satellite Antenna Replacement, Motherboard: adım 4, 2 resimden 2.
    • Using the T5 Torx screwdriver, remove the two 6.4 mm screws on the motherboard.
  5. Garmin Rino 700 Satellite Antenna Replacement: adım 5, 3 resimden 1. Garmin Rino 700 Satellite Antenna Replacement: adım 5, 3 resimden 2. Garmin Rino 700 Satellite Antenna Replacement: adım 5, 3 resimden 3.
    • Using the nylon spudger, lift the motherboard out of its position.
    • Slide the motherboard out of the front panel of the device.
    • Carefully disconnect the motherboard from the panel and remove it out of the device.
  6. Garmin Rino 700 Satellite Antenna Replacement, Satellite Antenna: adım 6, 3 resimden 1. Garmin Rino 700 Satellite Antenna Replacement, Satellite Antenna: adım 6, 3 resimden 2. Garmin Rino 700 Satellite Antenna Replacement, Satellite Antenna: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently and delicately heat up the solder holding the antenna port to the motherboard.
    • Carefully remove the antenna with the tweezers and set it aside.
    • Refer to the How To Solder and Desolder Connections for a guide on soldering.
Sonuç
Abigail Dugan
512 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 5-5, Hunter Fall 2021 Clemson, Team 5-5, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S5G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 238
