Giriş
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the fingerprint reader in your Google Pixel 6.
If you replace the fingerprint reader in the Pixel 6 or switch it between two different displays, you need to recalibrate it to maintain its functionality.
Warning: The replacement of the fingerprint reader in the Google Pixel 6 is not complicated, but the screen can get damaged very easily during the removal procedure.
Caution: The Pixel 6 contains class 1 lasers. Disassembly could result in exposure to invisible infrared laser emissions.
Retaining water resistance after the repair will depend on how well you reapply the adhesive, but your device will lose its IP (Ingress Protection) rating.
You’ll need replacement adhesive to reattach components when reassembling the device.
Note: Replacement fingerprint sensors are not available for sale on iFixit or from Google.
Neye ihtiyacın var
Bu adımda kullanılan alet:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your phone.
Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
Squeeze the cups together to apply suction.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the phone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least three minutes.
Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
Lift the screen, including its safety frame, with the suction handle to create a small gap between the screen and the phone assembly.
Insert an opening pick into the gap between the screen frame and the phone assembly.
Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
The screen of the Google Pixel 6 is not only held in place by adhesive but also small plastic clips. If your opening pick gets blocked during the screen removal procedure, it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (3-4 mm) when slicing the display adhesive.
Insert a third opening pick underneath the bottom left corner of the screen.
Slide the opening pick along the left edge of the screen to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Carefully open the right side of the screen to the left side of the phone assembly like you would open a book.
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of tweezers to carefully unhinge and remove the metal bracket sitting on top of the display cable connector.
Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
Remove the screen.
If you replaced the screen, check the front-facing camera hole on the screen and remove any remaining protective liners in it.
This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
Follow this guide if you're using custom-cut adhesives for your device.
Follow this guide if you're using a pre-cut adhesive card.
If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
Use one arm of a pair of tweezers to carefully open the ZIF connector at the rear side of the screen.
Use a pair of tweezers to disconnect the fingerprint reader by pulling its cable out of the ZIF connector.
Apply a heated iOpener to the screen where the fingerprint reader is located to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
Carefully slide an opening pick underneath the fingerprint reader cable to slice its adhesive.
Use your opening pick to separate the fingerprint reader from the screen.
Use a pair of tweezers or your fingers to carefully remove the fingerprint reader.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
11 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
Will you ever sell a fingerprint replacement part?
Great guide! Using very little alcohol after heating the display can help loosen up the adhesive holding the fingerprint scanner.
This is incomplete. It STOPS 1/2 THROUGH!!!!!
This guide stops at removal of the original part. NO WHERE DOES IT GET TO REASSEMBLY or CALIBRATION!!!
Reassembly is literally all the steps but backwards and the calibration program is listed at the top of the article.
