Ana içeriğe geç
Google Pixel 8 Pro Rear Camera Assembly Replacement
Neye ihtiyacın var
  1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 3.
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Mark your opening picks: adım 2, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Mark your opening picks: adım 2, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Mark your opening picks: adım 2, 3 resimden 3.
    • You'll be using opening picks to separate the screen from the frame. If inserted too far, a pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. Google Pixel 8 Pro Rear Camera Assembly Replacement, Tape over a cracked screen: adım 3, 2 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Tape over a cracked screen: adım 3, 2 resimden 2.
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
    • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  4. Google Pixel 8 Pro Rear Camera Assembly Replacement, Heat the bottom edge adhesive: adım 4, 1 resimden 1.
    • Adhesive and clips secure the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the screen for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as extreme heat can damage the screen and/or battery.
  5. Google Pixel 8 Pro Rear Camera Assembly Replacement, Secure the Anti-Clamp: adım 5, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Secure the Anti-Clamp: adım 5, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Secure the Anti-Clamp: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
    • Slide the arms over the left edge of your phone, so you have access to the bottom edge.
    • Position the suction cups as close to the center of the bottom edge as possible.
    • Squeeze the cups together to create suction.
  6. Google Pixel 8 Pro Rear Camera Assembly Replacement, Twist the handle: adım 6, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Twist the handle: adım 6, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Twist the handle: adım 6, 3 resimden 3.
    • Pull the handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
  7. Google Pixel 8 Pro Rear Camera Assembly Replacement, Insert an opening pick: adım 7, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Insert an opening pick: adım 7, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Insert an opening pick: adım 7, 3 resimden 3.
    • Wait one minute for a gap to form between the screen and frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat if the screen cools down.
    • Insert an opening pick into the gap.
    • Don't insert your opening pick more than 3 mm to avoid damaging the spring contacts.
    • Pull the blue handle backwards to unlock the arms and remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  8. Google Pixel 8 Pro Rear Camera Assembly Replacement, Apply a suction cup: adım 8, 2 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Apply a suction cup: adım 8, 2 resimden 2.
    • Apply a suction handle to the center of the screen's bottom edge.
  9. Google Pixel 8 Pro Rear Camera Assembly Replacement, Insert an opening pick: adım 9, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Insert an opening pick: adım 9, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Insert an opening pick: adım 9, 3 resimden 3.
    • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
    • If you're having trouble creating a gap, apply more heat and try again.
  10. Google Pixel 8 Pro Rear Camera Assembly Replacement, Prevent damage to your phone: adım 10, 2 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Prevent damage to your phone: adım 10, 2 resimden 2.
    • To avoid damaging your phone, don't insert your pick more than 3 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
  11. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the bottom edge adhesive: adım 11, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the bottom edge adhesive: adım 11, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the bottom edge adhesive: adım 11, 3 resimden 3.
    • Slide the opening pick along the bottom edge to separate the adhesive securing it.
    • Leave the pick in the bottom right corner to prevent the adhesive from resealing.
  12. Google Pixel 8 Pro Rear Camera Assembly Replacement, Heat the right edge adhesive: adım 12, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  13. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the right edge adhesive: adım 13, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the right edge adhesive: adım 13, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the right edge adhesive: adım 13, 3 resimden 3.
    • Insert a second opening pick under the bottom right corner of the screen.
    • Slide the new pick to the top right corner to separate the adhesive securing the screen's right edge.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  14. Google Pixel 8 Pro Rear Camera Assembly Replacement, Leave a pick in the bottom left corner: adım 14, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Leave a pick in the bottom left corner: adım 14, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Leave a pick in the bottom left corner: adım 14, 3 resimden 3.
    • Insert a third opening pick under the bottom edge of the screen.
    • Slide the new pick to the bottom left corner.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  15. Google Pixel 8 Pro Rear Camera Assembly Replacement, Heat the left edge adhesive: adım 15, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  16. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the left edge adhesive: adım 16, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the left edge adhesive: adım 16, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the left edge adhesive: adım 16, 3 resimden 3.
    • Insert a fourth opening pick under the bottom left corner of the screen.
    • Slide the new pick to the top left corner to separate the adhesive securing the screen's left edge.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
  17. Google Pixel 8 Pro Rear Camera Assembly Replacement, Heat the top edge adhesive: adım 17, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  18. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the top edge adhesive: adım 18, 2 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the top edge adhesive: adım 18, 2 resimden 2.
    • Insert a fifth opening pick under the top edge of the screen, near the left corner.
    • Slide the opening pick to the top right corner to separate the adhesive securing the screen's top edge.
  19. Google Pixel 8 Pro Rear Camera Assembly Replacement, Prop up the screen: adım 19, 2 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Prop up the screen: adım 19, 2 resimden 2.
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cable.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access the screen cable without straining it.
  20. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the screen cable cover: adım 20, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the screen cable cover: adım 20, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the screen cable cover: adım 20, 3 resimden 3.
    • Use an opening tool to pry up the upper edge of the screen cable cover.
    • Remove the cover.
  21. Google Pixel 8 Pro Rear Camera Assembly Replacement, Disconnect the screen: adım 21, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Disconnect the screen: adım 21, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Disconnect the screen: adım 21, 3 resimden 3.
    • Insert the point of a spudger under the top right corner of the screen's press connector.
    • Gently pry up and disconnect the cable.
    • Remove the screen.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  22. Google Pixel 8 Pro Rear Camera Assembly Replacement, Screen information: adım 22, 1 resimden 1.
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  23. Google Pixel 8 Pro Rear Camera Assembly Replacement, Reassembly information: adım 23, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Reassembly information: adım 23, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Reassembly information: adım 23, 3 resimden 3.
    • If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow this guide to apply adhesive to your old screen.
    • Thoroughly check the entire screen for any plastic liners or tape and use the pull tabs to remove all of them. Look carefully for a large piece of plastic covering the back of the screen, a small one near the front camera cutout, and adhesive liners around the perimeter.
    • Reconnect the screen cable and reinstall its cover.
    • Firmly press the screen into place on the frame—you should feel the clips "pop" into place.
    • Press firmly around the perimeter of the screen to secure it with the new adhesive.
    • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
    • Follow this guide to calibrate the fingerprint sensor.
  24. Google Pixel 8 Pro Rear Camera Assembly Replacement, Disconnect the 5G mmWave antenna: adım 24, 2 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Disconnect the 5G mmWave antenna: adım 24, 2 resimden 2.
    • The next few steps show how to disconnect and detach the 5G mmWave antenna cable. If your phone doesn't have a 5G mmWave antenna, skip the next four steps.
    • Be very careful not to scrape off or damage any surface mounted components during this step.
    • Insert the tip of a spudger under the top edge of the 5G mmWave antenna's press connector.
  25. Google Pixel 8 Pro Rear Camera Assembly Replacement, Heat the 5G mmWave antenna adhesive: adım 25, 1 resimden 1.
  26. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the 5G mmWave antenna adhesive: adım 26, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the 5G mmWave antenna adhesive: adım 26, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Separate the 5G mmWave antenna adhesive: adım 26, 3 resimden 3.
    • Insert the flat end of a spudger between the bottom of the 5G mmWave antenna cable and the midframe, just above the press connector.
    • Twist the spudger to separate the bottom of the cable from the midframe.
  27. Google Pixel 8 Pro Rear Camera Assembly Replacement, Peel up the 5G mmWave antenna: adım 27, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Peel up the 5G mmWave antenna: adım 27, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Peel up the 5G mmWave antenna: adım 27, 3 resimden 3.
    Tesa 61395 Tape
    $5.99
    • Grip the bottom of the 5G mmWave antenna cable and gently peel it from the midframe.
    • During reassembly, press the cable back into place on the midframe to secure it with the old adhesive. If it doesn't stick, use thin, double-sided tape to secure it.
  28. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the graphite tape: adım 28, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the graphite tape: adım 28, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the graphite tape: adım 28, 3 resimden 3.
    • A large graphite sheet must be removed and replaced to complete this repair. It connects the upper part of the battery, midframe, and the rear cameras.
    • Insert the point of a spudger under different parts of the graphite sheet and lift until you can grip the sheet with your fingers.
    • The sections of graphite sheet between the rear cameras and the battery will most likely tear. If they do, grip the broken part of the sheet and remove that section.
    • Peel up and remove the entire graphite sheet.
    • During reassembly, do not reuse the old graphite sheet. Follow this guide to replace the sheet.
  29. Google Pixel 8 Pro Rear Camera Assembly Replacement, Move the USB‑C cover tape: adım 29, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Move the USB‑C cover tape: adım 29, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Move the USB‑C cover tape: adım 29, 3 resimden 3.
    • Use the tip of a spudger to gently lift the plastic shim that runs along the top of the USB-C port cover.
    • Remove the shim and set it aside or move it out of the way so you can access the USB-C port cover screws.
  30. Google Pixel 8 Pro Rear Camera Assembly Replacement, Reassembly information: adım 30, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Reassembly information: adım 30, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Reassembly information: adım 30, 3 resimden 3.
    • During reassembly, follow this step to replace the plastic shim that runs across the bottom of the midframe and loudspeaker. If you don't have a replacement, press the old one back into place.
    • Remove the larger rectangular liner from the shim.
    • Place the shim so the smaller piece of foam lines up with the bottom of the USB-C port cover.
    • Use the flat end of a spudger to firmly press down along the whole shim to secure it.
    • Remove the remaining liner.
  31. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the USB‑C port cover: adım 31, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the USB‑C port cover: adım 31, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the USB‑C port cover: adım 31, 3 resimden 3.
    FixMat
    $36.95
    • While the Pixel 8 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T3 Torx screwdriver to remove the two 5 mm‑long 3IP Torx Plus screws securing the USB‑C port cover.
    • Remove the cover.
  32. Google Pixel 8 Pro Rear Camera Assembly Replacement, Unfasten the midframe: adım 32, 2 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Unfasten the midframe: adım 32, 2 resimden 2.
    • Use a T3 Torx screwdriver to remove the seven 5 mm‑long 3IP Torx Plus screws securing the midframe.
  33. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the midframe: adım 33, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the midframe: adım 33, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the midframe: adım 33, 3 resimden 3.
    • Remove the midframe.
    • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
  34. Google Pixel 8 Pro Rear Camera Assembly Replacement, Disconnect the battery: adım 34, 2 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Disconnect the battery: adım 34, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the battery cable press connector.
  35. Google Pixel 8 Pro Rear Camera Assembly Replacement, Disconnect the front camera: adım 35, 2 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Disconnect the front camera: adım 35, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the front camera press connector.
  36. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the front camera: adım 36, 1 resimden 1.
    • Remove the front camera.
  37. Google Pixel 8 Pro Rear Camera Assembly Replacement, Disconnect the rear camera assembly: adım 37, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Disconnect the rear camera assembly: adım 37, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Disconnect the rear camera assembly: adım 37, 3 resimden 3.
    • Use the point of a spudger to pry up and disconnect all three rear camera press connectors from the top edge of the logic board.
  38. Google Pixel 8 Pro Rear Camera Assembly Replacement, Unfasten the rear camera assembly: adım 38, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Unfasten the rear camera assembly: adım 38, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Unfasten the rear camera assembly: adım 38, 3 resimden 3.
    • You may need to hold the 5G mmWave antenna cable out of the way while removing the rear camera assembly screws.
    • Use a T3 Torx screwdriver to remove the two screws securing the rear camera assembly:
    • One 3.5 mm‑long 3IP Torx Plus screw securing the top left corner
    • One 5 mm‑long 3IP Torx Plus screw securing the top right corner
  39. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the rear camera assembly: adım 39, 3 resimden 1. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the rear camera assembly: adım 39, 3 resimden 2. Google Pixel 8 Pro Rear Camera Assembly Replacement, Remove the rear camera assembly: adım 39, 3 resimden 3.
    • Insert a spudger between the right edge of the rear camera assembly and frame.
    • Pry the rear camera assembly up and remove it.
Sonuç
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
3 farklı kişi bu kılavuzu tamamladı.
Spencer Day
150.037 İtibar
995 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.648 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 60
Son 30 gün: 204
Her zaman: 6,253
