Ana içeriğe geç
Google Pixel 9 5G mmWave Antenna Replacement
Neye ihtiyacın var
  1. Google Pixel 9 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 2. Google Pixel 9 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 3.
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 9 5G mmWave Antenna Replacement, Adhesive information: adım 2, 3 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement, Adhesive information: adım 2, 3 resimden 2. Google Pixel 9 5G mmWave Antenna Replacement, Adhesive information: adım 2, 3 resimden 3.
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
  3. Google Pixel 9 5G mmWave Antenna Replacement, Apply a suction handle: adım 3, 2 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement, Apply a suction handle: adım 3, 2 resimden 2.
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
  4. Google Pixel 9 5G mmWave Antenna Replacement, Insert an opening pick: adım 4, 3 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement, Insert an opening pick: adım 4, 3 resimden 2. Google Pixel 9 5G mmWave Antenna Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
  5. Google Pixel 9 5G mmWave Antenna Replacement, Separate the back glass adhesive: adım 5, 3 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement, Separate the back glass adhesive: adım 5, 3 resimden 2. Google Pixel 9 5G mmWave Antenna Replacement, Separate the back glass adhesive: adım 5, 3 resimden 3.
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 5G mmWave Antenna Replacement: adım 6, 3 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement: adım 6, 3 resimden 2. Google Pixel 9 5G mmWave Antenna Replacement: adım 6, 3 resimden 3.
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
  7. Google Pixel 9 5G mmWave Antenna Replacement: adım 7, 3 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement: adım 7, 3 resimden 2. Google Pixel 9 5G mmWave Antenna Replacement: adım 7, 3 resimden 3.
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
  8. Google Pixel 9 5G mmWave Antenna Replacement, Remove the back glass: adım 8, 1 resimden 1.
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
  9. Google Pixel 9 5G mmWave Antenna Replacement, Remove the upper board cover: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
  10. Google Pixel 9 5G mmWave Antenna Replacement: adım 10, 2 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement: adım 10, 2 resimden 2.
    • Use a pair of tweezers to remove the upper board cover.
  11. Google Pixel 9 5G mmWave Antenna Replacement, Remove the midframe: adım 11, 1 resimden 1.
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
  12. Google Pixel 9 5G mmWave Antenna Replacement, Peel up the flash cable: adım 12, 2 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement, Peel up the flash cable: adım 12, 2 resimden 2.
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
  13. Google Pixel 9 5G mmWave Antenna Replacement, Remove the midframe: adım 13, 2 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement, Remove the midframe: adım 13, 2 resimden 2.
    • Remove the midframe, wireless charging coil, and NFC assembly.
  14. Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the battery: adım 14, 2 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the battery: adım 14, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the battery connector.
  15. Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: adım 15, 3 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: adım 15, 3 resimden 2. Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: adım 15, 3 resimden 3.
    • Use the tip of a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
  16. Google Pixel 9 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: adım 16, 3 resimden 1. Google Pixel 9 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: adım 16, 3 resimden 2. Google Pixel 9 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: adım 16, 3 resimden 3.
    • Remove the 5G mmWave antenna.
    • A small flex cable attaches to the back of the antenna with a press connector. You may need to reconnect it if it falls off.
    • During reassembly, insert the antenna so it's between the frame and the small metal bracket near the top right corner.
Sonuç
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
Carsten Frauenheim
136.963 İtibar
371 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 43
Son 30 gün: 181
Her zaman: 1,056
