Ana içeriğe geç
Google Pixel 9 Autofocus and Flash Module Replacement
Neye ihtiyacın var
  1. Google Pixel 9 Autofocus and Flash Module Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 2. Google Pixel 9 Autofocus and Flash Module Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 3.
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    FixBot'a Sor
    Yorum Ekle
  2. Google Pixel 9 Autofocus and Flash Module Replacement, Adhesive information: adım 2, 3 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement, Adhesive information: adım 2, 3 resimden 2. Google Pixel 9 Autofocus and Flash Module Replacement, Adhesive information: adım 2, 3 resimden 3.
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
    FixBot'a Sor
    Yorum Ekle
  3. Google Pixel 9 Autofocus and Flash Module Replacement, Apply a suction handle: adım 3, 2 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement, Apply a suction handle: adım 3, 2 resimden 2.
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
    FixBot'a Sor
    Yorum Ekle
  4. Google Pixel 9 Autofocus and Flash Module Replacement, Insert an opening pick: adım 4, 3 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement, Insert an opening pick: adım 4, 3 resimden 2. Google Pixel 9 Autofocus and Flash Module Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
    FixBot'a Sor
    Yorum Ekle
  5. Google Pixel 9 Autofocus and Flash Module Replacement, Separate the back glass adhesive: adım 5, 3 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement, Separate the back glass adhesive: adım 5, 3 resimden 2. Google Pixel 9 Autofocus and Flash Module Replacement, Separate the back glass adhesive: adım 5, 3 resimden 3.
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
    FixBot'a Sor
    Yorum Ekle
  6. Google Pixel 9 Autofocus and Flash Module Replacement: adım 6, 3 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement: adım 6, 3 resimden 2. Google Pixel 9 Autofocus and Flash Module Replacement: adım 6, 3 resimden 3.
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
    FixBot'a Sor
    Yorum Ekle
  7. Google Pixel 9 Autofocus and Flash Module Replacement: adım 7, 3 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement: adım 7, 3 resimden 2. Google Pixel 9 Autofocus and Flash Module Replacement: adım 7, 3 resimden 3.
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
    FixBot'a Sor
    Yorum Ekle
  8. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the back glass: adım 8, 1 resimden 1.
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
    FixBot'a Sor
    Yorum Ekle
  9. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the upper board cover: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
    FixBot'a Sor
    Yorum Ekle
  10. Google Pixel 9 Autofocus and Flash Module Replacement: adım 10, 2 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement: adım 10, 2 resimden 2.
    • Use a pair of tweezers to remove the upper board cover.
    FixBot'a Sor
    Yorum Ekle
  11. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the midframe: adım 11, 1 resimden 1.
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
    FixBot'a Sor
    Yorum Ekle
  12. Google Pixel 9 Autofocus and Flash Module Replacement, Peel up the flash cable: adım 12, 2 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement, Peel up the flash cable: adım 12, 2 resimden 2.
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
    FixBot'a Sor
    Yorum Ekle
  13. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the midframe: adım 13, 2 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the midframe: adım 13, 2 resimden 2.
    • Remove the midframe, wireless charging coil, and NFC assembly.
    FixBot'a Sor
    Yorum Ekle
  14. Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the battery: adım 14, 2 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the battery: adım 14, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the battery connector.
    FixBot'a Sor
    Yorum Ekle
  15. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the antenna board cover: adım 15, 1 resimden 1.
    • Use a 3IP Torx Plus driver to remove the 5.4 mm-long screw securing the antenna board cover.
    FixBot'a Sor
    Yorum Ekle
  16. Google Pixel 9 Autofocus and Flash Module Replacement: adım 16, 1 resimden 1.
    • Use a pair of tweezers to remove the antenna board cover.
    FixBot'a Sor
    Yorum Ekle
  17. Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the autofocus cable: adım 17, 2 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the autofocus cable: adım 17, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the autofocus connector from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  18. Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the flash: adım 18, 2 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the flash: adım 18, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the flash connector from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  19. Google Pixel 9 Autofocus and Flash Module Replacement, Heat the LDAF adhesive: adım 19, 1 resimden 1.
    • Heat an iOpener and apply it over the LDAF and flash module for one minute to soften the adhesive securing it to the rear camera module.
    FixBot'a Sor
    Yorum Ekle
  20. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the LDAF and flash module: adım 20, 3 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the LDAF and flash module: adım 20, 3 resimden 2. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the LDAF and flash module: adım 20, 3 resimden 3.
    • Peel up and remove the LDAF and flash module.
    • During reassembly, orient the module such that the longer cable is on the bottom edge.
    • Be very careful not to touch the rear camera lenses. If you accidentally do, wipe them with a clean microfiber cloth.
    FixBot'a Sor
    Yorum Ekle
  21. Google Pixel 9 Autofocus and Flash Module Replacement, Reassembly information: adım 21, 3 resimden 1. Google Pixel 9 Autofocus and Flash Module Replacement, Reassembly information: adım 21, 3 resimden 2. Google Pixel 9 Autofocus and Flash Module Replacement, Reassembly information: adım 21, 3 resimden 3.
    • Use a spudger and tweezers to remove the two pieces of adhesive from the bottom of the LDAF and flash module.
    • Remove the larger clear liners from one of the flash module adhesives.
    • Place the adhesive into place on the bottom of the module and press down firmly with the flat end of a spudger to secure the adhesive.
    • Repeat the process to apply the other piece of flash adhesive.
    • Remove the two remaining blue liners.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
Carsten Frauenheim
167.383 İtibar
439 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
29.508 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 98
Her zaman: 1,572
