Ana içeriğe geç
HP EliteBook x360 1030 G3 Battery Replacement
Neye ihtiyacın var
  1. HP EliteBook x360 1030 G3 Battery Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Battery Replacement: adım 2, 1 resimden 1.
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Battery Replacement: adım 4, 2 resimden 1. HP EliteBook x360 1030 G3 Battery Replacement: adım 4, 2 resimden 2.
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
    Connector to the left may be stuck to the battery a little. Don’t worry just be careful.
    Leighton Doswell - Yanıt
  5. HP EliteBook x360 1030 G3 Battery Replacement: adım 5, 1 resimden 1.
    • Gently lift the battery out of its place.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Pablo Arriola
528 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 üyesi
CPSU-MANESS-S19S2G9
4 Üyeler
16 adet Kılavuz yazıldı
5Kılavuz Yorumları
Thanks, it is very useful.
Mohamed Wafi Aljunaedi - Yanıt
thats very nice
montrez damonei - Yanıt
Looks easy and do you know if the pc can work without battery, only with charger?
Sam Uel - Yanıt
Thank you. very useful.
mustapha ELABED - Yanıt
Very simple and precise with good warnings too
Roland Appiah - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 39
Son 30 gün: 172
Her zaman: 13,383
