Ana içeriğe geç
HP Stream 11-d010nr Keyboard Replacement
Josh Corrigan
Josh Corrigan ve 7 diğer katkıda bulunanlar
En son February 18, 2025 tarihinde güncellendi
5 - 25 dakika
Orta
Daha iyi giriş
Öğrenci İş Başında
Sometimes the keyboard of an HP Stream 11-d010nr will start to behave sub-optimally, such as unresponsive or sticky keys. This guide will show you how to replace it.
Neye ihtiyacın var
Aletler
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Daha fazlasını göster…
  1. HP Stream 11-d010nr Keyboard Replacement, Pry out the inserts: adım 1, 2 resimden 1. HP Stream 11-d010nr Keyboard Replacement, Pry out the inserts: adım 1, 2 resimden 2.
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
  2. HP Stream 11-d010nr Keyboard Replacement, Unscrew the back cover: adım 2, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
  3. HP Stream 11-d010nr Keyboard Replacement, Pry the keyboard casing up: adım 3, 2 resimden 1. HP Stream 11-d010nr Keyboard Replacement, Pry the keyboard casing up: adım 3, 2 resimden 2.
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
  4. HP Stream 11-d010nr Keyboard Replacement, Identify the connectors: adım 4, 1 resimden 1.
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
  5. HP Stream 11-d010nr Keyboard Replacement, Disconnect the cables: adım 5, 3 resimden 1. HP Stream 11-d010nr Keyboard Replacement, Disconnect the cables: adım 5, 3 resimden 2. HP Stream 11-d010nr Keyboard Replacement, Disconnect the cables: adım 5, 3 resimden 3.
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
  6. HP Stream 11-d010nr Keyboard Replacement, Lift the keyboard out: adım 6, 1 resimden 1.
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Josh Corrigan
347 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G3, White Winter 2019 Cal Poly, Team S1-G3, White Winter 2019 üyesi
CPSU-WHITE-W19S1G3
4 Üyeler
11 adet Kılavuz yazıldı
2Kılavuz Yorumları
I feel like the 5-10 minutes estimated time is way too short for this repair (however, I have not done this, and may be wrong).
Constantin Legras - Yanıt
There will definitely be variation depending on each individual but our group came to the conclusion that this was a reasonable time frame. I appreciate the feedback though and if anyone else reaches out saying it is too short I will increase the estimated time. Thank you!
Josh Corrigan -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 923
