Ana içeriğe geç
HTC Vive XR Elite Battery Cradle Batteries Replacement
Neye ihtiyacın var
  1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Prepare your Vive XR Elite for disassembly: adım 1, 1 resimden 1.
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
  2. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the USB-C power cable: adım 2, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the USB-C power cable: adım 2, 2 resimden 2.
    • Disconnect the USB-C power cable.
  3. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the battery cradle: adım 3, 3 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the battery cradle: adım 3, 3 resimden 2. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the battery cradle: adım 3, 3 resimden 3.
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
  4. HTC Vive XR Elite Battery Cradle Batteries Replacement: adım 4, 3 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement: adım 4, 3 resimden 2. HTC Vive XR Elite Battery Cradle Batteries Replacement: adım 4, 3 resimden 3.
    • Repeat the previous step for the left temple slot.
  5. HTC Vive XR Elite Battery Cradle Batteries Replacement, Separate the headset and battery cradle: adım 5, 1 resimden 1.
    • Separate the headset and battery cradle.
  6. HTC Vive XR Elite Battery Cradle Batteries Replacement, Insert an opening pick: adım 6, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Insert an opening pick: adım 6, 2 resimden 2.
    • Insert a long edge of an opening pick in the gap between the two halves of the battery cradle, near the USB-C cable.
  7. HTC Vive XR Elite Battery Cradle Batteries Replacement, Release the top clips: adım 7, 3 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Release the top clips: adım 7, 3 resimden 2. HTC Vive XR Elite Battery Cradle Batteries Replacement, Release the top clips: adım 7, 3 resimden 3.
    • Slide the opening pick along the top edge of battery cradle to release its plastic clips.
  8. HTC Vive XR Elite Battery Cradle Batteries Replacement: adım 8, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement: adım 8, 2 resimden 2.
    • Flip the battery cradle over.
    • Insert the long edge of an opening pick in the gap between the two halves of the battery cradle.
  9. HTC Vive XR Elite Battery Cradle Batteries Replacement, Release the bottom clips: adım 9, 3 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Release the bottom clips: adım 9, 3 resimden 2. HTC Vive XR Elite Battery Cradle Batteries Replacement, Release the bottom clips: adım 9, 3 resimden 3.
    • Slide the opening pick along the bottom edge of battery cradle to release its plastic clips.
  10. HTC Vive XR Elite Battery Cradle Batteries Replacement, Separate the battery cradle halves: adım 10, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Separate the battery cradle halves: adım 10, 2 resimden 2.
    • Pull apart the two halves of the battery cradle to completely separate them.
  11. HTC Vive XR Elite Battery Cradle Batteries Replacement, Peel back the graphite thermal tape: adım 11, 3 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Peel back the graphite thermal tape: adım 11, 3 resimden 2. HTC Vive XR Elite Battery Cradle Batteries Replacement, Peel back the graphite thermal tape: adım 11, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to peel back the graphite thermal tape covering the inner plastic frame.
    • If the tape tears a little, don't worry! During reassembly, stick it back in its original place as if it were still one piece
  12. HTC Vive XR Elite Battery Cradle Batteries Replacement, Unfasten the inner plastic frame: adım 12, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Unfasten the inner plastic frame: adım 12, 2 resimden 2.
    FixMat
    $36.95
    • Use a T5 Torx screwdriver to remove the nine screws securing the inner plastic frame:
    • Five 11.8 mm-long screws
    • Three 5.6 mm-long screws
    • One 5.6 mm-long screw
    • This screw is covered by a piece of black plastic tape. Use tweezers to remove it before unscrewing.
  13. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the inner plastic frame: adım 13, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the inner plastic frame: adım 13, 2 resimden 2.
    • Remove the inner plastic frame, making sure to thread the graphite thermal tape through it.
  14. HTC Vive XR Elite Battery Cradle Batteries Replacement, Unfasten the headstrap clips: adım 14, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Unfasten the headstrap clips: adım 14, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the two 5.6 mm-long screws securing the headstrap clips.
  15. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the headstrap clips: adım 15, 3 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the headstrap clips: adım 15, 3 resimden 2. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the headstrap clips: adım 15, 3 resimden 3.
    • Use tweezers to remove the left and right headstrap clips.
  16. HTC Vive XR Elite Battery Cradle Batteries Replacement, Peel back the battery board thermal pad: adım 16, 3 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Peel back the battery board thermal pad: adım 16, 3 resimden 2. HTC Vive XR Elite Battery Cradle Batteries Replacement, Peel back the battery board thermal pad: adım 16, 3 resimden 3.
    • Use tweezers or your fingers to peel back the thermal pad covering the battery board.
    • Work slowly to avoid tearing the thermal pad.
  17. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the batteries: adım 17, 3 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the batteries: adım 17, 3 resimden 2. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the batteries: adım 17, 3 resimden 3.
    • Use the flat end of a spudger to push the left and right battery cell connectors out of their respective sockets.
  18. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the power LED: adım 18, 3 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the power LED: adım 18, 3 resimden 2. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the power LED: adım 18, 3 resimden 3.
    • Use the point of a spudger to flip up the locking flap on the power LED ZIF connector.
    • Use tweezers or your fingers to disconnect the power LED cable.
    • During reassembly, slide the cable into the connector and close the locking flap. If the cable is getting stuck, gently remove it and realign it before trying again.
  19. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the USB-C power cable: adım 19, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Disconnect the USB-C power cable: adım 19, 2 resimden 2.
    • Pull the black tab straight up on the USB-C power cable to disconnect it.
    • During reassembly, align the cable directly over the connector and press straight down to reconnect it.
  20. HTC Vive XR Elite Battery Cradle Batteries Replacement, Peel back the conductive tape: adım 20, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Peel back the conductive tape: adım 20, 2 resimden 2.
    • Use tweezers or your fingers to peel the conductive tape away from the front metal battery enclosure.
  21. HTC Vive XR Elite Battery Cradle Batteries Replacement, Unfasten the battery board: adım 21, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Unfasten the battery board: adım 21, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the four 4.1 mm-long screws securing the battery board.
  22. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the battery board: adım 22, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the battery board: adım 22, 2 resimden 2.
    • Remove the battery board.
  23. HTC Vive XR Elite Battery Cradle Batteries Replacement, Unfasten the front metal battery cover: adım 23, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Unfasten the front metal battery cover: adım 23, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the three screws securing the front metal battery enclosure:
    • Two 11.8 mm-long screws
    • One 4.8 mm-long screw
  24. HTC Vive XR Elite Battery Cradle Batteries Replacement, Unclip the USB-C power cable: adım 24, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Unclip the USB-C power cable: adım 24, 2 resimden 2.
    • Slide the USB-C power cable to the left to unclip it.
  25. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the front metal battery enclosure: adım 25, 2 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the front metal battery enclosure: adım 25, 2 resimden 2.
    • Remove the front metal battery enclosure.
  26. HTC Vive XR Elite Battery Cradle Batteries Replacement, Reposition the battery cradle: adım 26, 1 resimden 1.
    • Stand the battery cradle upright so the battery cells can fold flat on your work surface.
  27. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the right battery cell: adım 27, 3 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the right battery cell: adım 27, 3 resimden 2. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the right battery cell: adım 27, 3 resimden 3.
    • Don't try to fully remove the batteries yet, as they're still attached to the cradle with graphite thermal tape.
    • Peel off the graphite thermal tape covering the right battery cell.
    • Remove the right battery cell.
  28. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the left battery cell: adım 28, 3 resimden 1. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the left battery cell: adım 28, 3 resimden 2. HTC Vive XR Elite Battery Cradle Batteries Replacement, Remove the left battery cell: adım 28, 3 resimden 3.
    • Repeat the previous step for the left battery cell.
Sonuç
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Chayton Ritter
24.895 İtibar
105 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
10 Üyeler
15.881 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 23
Her zaman: 605
