Ana içeriğe geç
How to Disconnect the Battery in the Google Pixel 6
Dominik Schnabelrauch
Dominik Schnabelrauch ve 4 diğer katkıda bulunanlar
En son January 15, 2025 tarihinde güncellendi
30 - 40 dakika
Orta
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
This is a prerequisite guide! This guide is part of another procedure and is not meant to be used alone.
Use this guide to disconnect the battery in the Google Pixel 6.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. How to Disconnect the Battery in the Google Pixel 6, Safety precautions: adım 1, 2 resimden 1. How to Disconnect the Battery in the Google Pixel 6, Safety precautions: adım 1, 2 resimden 2.
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. How to Disconnect the Battery in the Google Pixel 6, Anti-Clamp instructions: adım 2, 3 resimden 1. How to Disconnect the Battery in the Google Pixel 6, Anti-Clamp instructions: adım 2, 3 resimden 2. How to Disconnect the Battery in the Google Pixel 6, Anti-Clamp instructions: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. How to Disconnect the Battery in the Google Pixel 6: adım 3, 3 resimden 1. How to Disconnect the Battery in the Google Pixel 6: adım 3, 3 resimden 2. How to Disconnect the Battery in the Google Pixel 6: adım 3, 3 resimden 3.
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. How to Disconnect the Battery in the Google Pixel 6: adım 4, 3 resimden 1. How to Disconnect the Battery in the Google Pixel 6: adım 4, 3 resimden 2. How to Disconnect the Battery in the Google Pixel 6: adım 4, 3 resimden 3.
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. How to Disconnect the Battery in the Google Pixel 6, Loosen the display adhesive: adım 5, 1 resimden 1.
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least three minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  6. How to Disconnect the Battery in the Google Pixel 6, Insert an opening pick: adım 6, 3 resimden 1. How to Disconnect the Battery in the Google Pixel 6, Insert an opening pick: adım 6, 3 resimden 2. How to Disconnect the Battery in the Google Pixel 6, Insert an opening pick: adım 6, 3 resimden 3.
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen, including its safety frame, with the suction handle to create a small gap between the screen and the phone assembly.
    • Insert an opening pick into the gap between the screen frame and the phone assembly.
    • Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  7. How to Disconnect the Battery in the Google Pixel 6, Slice the adhesive: adım 7, 2 resimden 1. How to Disconnect the Battery in the Google Pixel 6, Slice the adhesive: adım 7, 2 resimden 2.
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
  8. How to Disconnect the Battery in the Google Pixel 6: adım 8, 3 resimden 1. How to Disconnect the Battery in the Google Pixel 6: adım 8, 3 resimden 2. How to Disconnect the Battery in the Google Pixel 6: adım 8, 3 resimden 3.
    • The screen of the Google Pixel 6 is not only held in place by adhesive but also small plastic clips. If your opening pick gets blocked during the screen removal procedure, it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (3-4 mm) when slicing the display adhesive.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  9. How to Disconnect the Battery in the Google Pixel 6: adım 9, 3 resimden 1. How to Disconnect the Battery in the Google Pixel 6: adım 9, 3 resimden 2. How to Disconnect the Battery in the Google Pixel 6: adım 9, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  10. How to Disconnect the Battery in the Google Pixel 6: adım 10, 2 resimden 1. How to Disconnect the Battery in the Google Pixel 6: adım 10, 2 resimden 2.
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly.
  11. How to Disconnect the Battery in the Google Pixel 6, Open up the phone assembly: adım 11, 3 resimden 1. How to Disconnect the Battery in the Google Pixel 6, Open up the phone assembly: adım 11, 3 resimden 2. How to Disconnect the Battery in the Google Pixel 6, Open up the phone assembly: adım 11, 3 resimden 3.
    • Avoid straining the display cable during the following procedure.
    • Carefully open the right side of the screen to the left side of the phone assembly like you would open a book.
  12. How to Disconnect the Battery in the Google Pixel 6, Remove the display cable bracket: adım 12, 3 resimden 1. How to Disconnect the Battery in the Google Pixel 6, Remove the display cable bracket: adım 12, 3 resimden 2. How to Disconnect the Battery in the Google Pixel 6, Remove the display cable bracket: adım 12, 3 resimden 3.
    • Use a pair of tweezers to carefully unhinge and remove the metal bracket sitting on top of the display cable connector.
    • Make sure to keep this component to reinstall it during reassembly.
  13. How to Disconnect the Battery in the Google Pixel 6, Disconnect the display cable: adım 13, 2 resimden 1. How to Disconnect the Battery in the Google Pixel 6, Disconnect the display cable: adım 13, 2 resimden 2.
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  14. How to Disconnect the Battery in the Google Pixel 6, Remove the screen: adım 14, 1 resimden 1.
    • Remove the screen.
    • During reassembly:
    • If you replaced the screen, check the front-facing camera hole on the screen and remove any remaining protective liners in it.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide if you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
  15. How to Disconnect the Battery in the Google Pixel 6, Loosen the graphite film adhesive: adım 15, 1 resimden 1.
    • Apply a heated iOpener or a heat gun to the rear glass to loosen the adhesive underneath the graphite films on top of the battery. Apply the iOpener for at least two minutes.
    • Don't apply heat directly onto the battery. It is susceptible to heat damage and could cause a thermal event.
  16. How to Disconnect the Battery in the Google Pixel 6, Remove the graphite films: adım 16, 3 resimden 1. How to Disconnect the Battery in the Google Pixel 6, Remove the graphite films: adım 16, 3 resimden 2. How to Disconnect the Battery in the Google Pixel 6, Remove the graphite films: adım 16, 3 resimden 3.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the top edge of the battery and the motherboard shield.
    • Remove the graphite film.
  17. How to Disconnect the Battery in the Google Pixel 6: adım 17, 3 resimden 1. How to Disconnect the Battery in the Google Pixel 6: adım 17, 3 resimden 2. How to Disconnect the Battery in the Google Pixel 6: adım 17, 3 resimden 3.
    • If the graphite film is hard to peel off, it has most likely cooled down. Reapply your iOpener or heat gun to the rear glass for 1-2 minutes to reheat it.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the left edge of the battery and the motherboard shield.
  18. How to Disconnect the Battery in the Google Pixel 6: adım 18, 3 resimden 1. How to Disconnect the Battery in the Google Pixel 6: adım 18, 3 resimden 2. How to Disconnect the Battery in the Google Pixel 6: adım 18, 3 resimden 3.
    • The graphite film at the bottom edge of the battery only needs to be removed when replacing the battery or the loudspeaker.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the bottom edge of the battery and the loudspeaker assembly.
    • You'll also remove a piece of foam that bridges the display and the speaker. Be sure to replace the foam after installing a new graphite film.
  19. How to Disconnect the Battery in the Google Pixel 6, Unfasten the motherboard cover screws: adım 19, 1 resimden 1.
    Magnetic Project Mat
    $19.95
    • Use a Torx T3 screwdriver to remove the screws securing the motherboard cover:
    • Eight 4.8 mm-long screws
    • One 2.4 mm-long screw
  20. How to Disconnect the Battery in the Google Pixel 6: adım 20, 3 resimden 1. How to Disconnect the Battery in the Google Pixel 6: adım 20, 3 resimden 2. How to Disconnect the Battery in the Google Pixel 6: adım 20, 3 resimden 3.
    • Carefully lift up the motherboard cover and remove it.
  21. How to Disconnect the Battery in the Google Pixel 6, Disconnect the battery cable: adım 21, 2 resimden 1. How to Disconnect the Battery in the Google Pixel 6, Disconnect the battery cable: adım 21, 2 resimden 2.
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Sonuç
231.499 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.716 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 50
