Ana içeriğe geç
How to Open the Apple TV 4K 2021 Siri Remote
Neye ihtiyacın var
  1. How to Open the Apple TV 4K 2021 Siri Remote, Remove the bottom cover: adım 1, 2 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote, Remove the bottom cover: adım 1, 2 resimden 2.
    • Use a P2 Pentalobe screwdriver to remove the two 6.1 mm-long screws securing the bottom cover.
    • Remove the bottom aluminium cover.
  2. How to Open the Apple TV 4K 2021 Siri Remote, Create a gap: adım 2, 3 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote, Create a gap: adım 2, 3 resimden 2. How to Open the Apple TV 4K 2021 Siri Remote, Create a gap: adım 2, 3 resimden 3.
    • Insert an iFlex into the gap on the right side of the circular clickpad.
    • Insert the iFlex about 3 mm.
    • Use the iFlex to create a gap by prying the circular clickpad upwards.
  3. How to Open the Apple TV 4K 2021 Siri Remote, Unhinge the plastic clips: adım 3, 3 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote, Unhinge the plastic clips: adım 3, 3 resimden 2. How to Open the Apple TV 4K 2021 Siri Remote, Unhinge the plastic clips: adım 3, 3 resimden 3.
    • Insert an opening pick into the gap. Remove the iFlex after inserting the opening pick.
    • Slide the opening pick around the top half of the clickpad.
    • Avoid sliding the opening pick to the bottom half of the clickpad. A flex cable runs there!
  4. How to Open the Apple TV 4K 2021 Siri Remote, Remove the clickpad: adım 4, 3 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote, Remove the clickpad: adım 4, 3 resimden 2. How to Open the Apple TV 4K 2021 Siri Remote, Remove the clickpad: adım 4, 3 resimden 3.
    • Lift the clickpad from the lower right side to access the press connector.
    • Use an opening pick to pry up the clickpad connector to disconnect it.
    • Remove the clickpad.
  5. How to Open the Apple TV 4K 2021 Siri Remote, Remove the face buttons: adım 5, 2 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote, Remove the face buttons: adım 5, 2 resimden 2.
    • Insert the iFlex into the gap on the right edge of the volume button.
  6. How to Open the Apple TV 4K 2021 Siri Remote, Unhinge the volume button: adım 6, 3 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote, Unhinge the volume button: adım 6, 3 resimden 2. How to Open the Apple TV 4K 2021 Siri Remote, Unhinge the volume button: adım 6, 3 resimden 3.
    • Use the iFlex to pry up the volume button to unhinge the plastic clips which keep the button in place.
    • Remove the volume button.
  7. How to Open the Apple TV 4K 2021 Siri Remote: adım 7, 2 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote: adım 7, 2 resimden 2.
    • Insert an angled probe into the housing to release the right plastic clip of the mute button.
    • Carefully push against the buttons clip from the inside.
    • Make sure that the probe doesn't hit any components on the mainboard and is inserted horizontally.
  8. How to Open the Apple TV 4K 2021 Siri Remote: adım 8, 3 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote: adım 8, 3 resimden 2. How to Open the Apple TV 4K 2021 Siri Remote: adım 8, 3 resimden 3.
    • Insert the probe into the gap on the surface of the mute button.
    • Use the probe to pry up the mute button and unhinge the remaining plastic clips.
    • Remove the mute button
  9. How to Open the Apple TV 4K 2021 Siri Remote: adım 9, 2 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote: adım 9, 2 resimden 2.
    • Insert a probe into the case to release the right plastic clip of the play/pause button.
    • Gently press against the clip from the inside.
  10. How to Open the Apple TV 4K 2021 Siri Remote: adım 10, 3 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote: adım 10, 3 resimden 2. How to Open the Apple TV 4K 2021 Siri Remote: adım 10, 3 resimden 3.
    • Insert the probe into the gap on the surface of the play/pause button.
    • Use the probe to pry up the play/pause button and unhinge the remaining plastic clips.
    • Remove the play/pause button.
  11. How to Open the Apple TV 4K 2021 Siri Remote: adım 11, 2 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote: adım 11, 2 resimden 2.
    • Insert the probe into the housing where the clickpad was previously to release the upper plastic clip of the back button.
    • Carefully press against the clip from the inside.
  12. How to Open the Apple TV 4K 2021 Siri Remote: adım 12, 3 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote: adım 12, 3 resimden 2. How to Open the Apple TV 4K 2021 Siri Remote: adım 12, 3 resimden 3.
    • Insert the probe into the gap on the surface of the back button.
    • Use the probe to pry up the back button and unhinge the remaining plastic clips.
    • Remove the back button.
  13. How to Open the Apple TV 4K 2021 Siri Remote: adım 13, 3 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote: adım 13, 3 resimden 2. How to Open the Apple TV 4K 2021 Siri Remote: adım 13, 3 resimden 3.
    • Insert the probe into the inner housing where the clickpad used to be to release the upper plastic clip of the TV button.
  14. How to Open the Apple TV 4K 2021 Siri Remote: adım 14, 3 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote: adım 14, 3 resimden 2. How to Open the Apple TV 4K 2021 Siri Remote: adım 14, 3 resimden 3.
    • Insert the probe into the gap on the surface of the TV button.
    • Use the probe to pry up the TV button and unhinge the remaining plastic clips.
    • Remove the TV button.
  15. How to Open the Apple TV 4K 2021 Siri Remote, Remove the Siri button: adım 15, 1 resimden 1.
    • Use a T3 Torx screwdriver to remove the two 4.7 mm-long screws securing the Siri button on the right edge of the remote.
  16. How to Open the Apple TV 4K 2021 Siri Remote: adım 16, 3 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote: adım 16, 3 resimden 2. How to Open the Apple TV 4K 2021 Siri Remote: adım 16, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use the pointed end of a spudger or a pair of tweezers to lift the Siri button up and out of the remote.
    • Remove the Siri button.
  17. How to Open the Apple TV 4K 2021 Siri Remote, Push the internal frame slightly out of the housing: adım 17, 2 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote, Push the internal frame slightly out of the housing: adım 17, 2 resimden 2.
    • Turn the remote upside down.
    • This will avoid the power button falling into the case and getting jammed.
    • Insert the flat end of a spudger into the charging port.
    • Don't worry! This won't damage the port.
    • Push the spudger in to slide the insides of the remote out about 1 inch (2.5 cm).
    • Don't try to push it all out yet! The power button needs to be removed first.
  18. How to Open the Apple TV 4K 2021 Siri Remote, Remove the power button: adım 18, 3 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote, Remove the power button: adım 18, 3 resimden 2. How to Open the Apple TV 4K 2021 Siri Remote, Remove the power button: adım 18, 3 resimden 3.
    • Turn the remote back over and make sure that the recess of the inner frame aligns with the power button.
    • Use the pointed end of a spudger to press the power button into the recess of the inner frame (if it didn’t already fall in by itself).
    • Remove the power button.
  19. How to Open the Apple TV 4K 2021 Siri Remote, Remove the internal frame from the housing: adım 19, 2 resimden 1. How to Open the Apple TV 4K 2021 Siri Remote, Remove the internal frame from the housing: adım 19, 2 resimden 2.
    • Pull the inner frame out of its aluminum housing.
    • There is a slight resistance when pulling out.
Sonuç
Repair didn’t go as planned? Check out our Answers community for help.
12 farklı kişi bu kılavuzu tamamladı.
Adriana Zwink
56.183 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.429 adet Kılavuz yazıldı
12 Yorum
Hi,
Thank you so much for the guide - I was able to open up my coffee spilled on remote clean it and actually fix it! However...somewhere along the lines I broke the Siri button (it was working fine prior to me opening up the remote)! It's a physical problem - I can't push it down physically, there is no spring like behavior...was there something in between the button that I dislodged? Any ideas?
Joanna - Yanıt
Loosen the screws under the clickwheel and place the button a bit farther inwards.
Bachsau -
Whaa? I just wanted to slide out the module and desolder the Siri button in the same fashion I cleanly remove panic buttons on key fobs. I’ll be using JB Weld. Thank you for the heads up. Apple presenting two screws, lol!
wolear - Yanıt
May not be immediately clear from the photos, but to extract the two P2 Pentalobe screws, you'll need to hold the P2 bit about 10-degrees off-axis. The screws are not longitudinal to the case.
John Shirley - Yanıt
I found the screw heads to be extremely brittle, got them out once and inserted again but now I am seeing small shavings coming off and can't open it again, word of caution
Ryan Owens - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 137
Son 7 gün: 674
Son 30 gün: 2,532
Her zaman: 53,113
