Ana içeriğe geç
How to Reseal an Apple Watch
Neye ihtiyacın var
  1. How to Reseal an Apple Watch, Clean the watch frame: adım 1, 2 resimden 1. How to Reseal an Apple Watch, Clean the watch frame: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Adhesive Cleanup Kit (Set of 12)
    $7.99
    • The following steps show how to apply new display adhesive with the display already installed. If you're installing a new screen or removed your screen jump to Step 6 of this guide.
    • Apply a little bit of isopropyl alcohol (>90%) to a cotton swab, or Q-tip (or use a cleaning pad) and gently remove the old adhesive on top of the watch frame.
    • To remove the adhesive on the side with the display cables, gently lay the display on the frame.
    • Avoid straining or tearing the display cables.
  2. How to Reseal an Apple Watch, Clean the rear side of the display: adım 2, 2 resimden 1. How to Reseal an Apple Watch, Clean the rear side of the display: adım 2, 2 resimden 2.
    • Flip the Apple Watch upside down so the display lays flat and lift the watch body.
    • Gently remove the old adhesive on the rear side of the display.
  3. How to Reseal an Apple Watch, Prepare the adhesive: adım 3, 1 resimden 1.
    • Use a pair of tweezers to carefully remove the replacement adhesive (including the blue protective film) from the backing paper.
  4. How to Reseal an Apple Watch, Apply the new adhesive: adım 4, 3 resimden 1. How to Reseal an Apple Watch, Apply the new adhesive: adım 4, 3 resimden 2. How to Reseal an Apple Watch, Apply the new adhesive: adım 4, 3 resimden 3.
    • Hold the replacement adhesive diagonally and thread it over the display.
    • Slightly tilt the display forward to align the adhesive with the frame.
    • Position the replacement adhesive on the watch frame, where the old adhesive was located.
  5. How to Reseal an Apple Watch: adım 5, 1 resimden 1.
    • Use the pointed end of a spudger to press the replacement adhesive into place.
    • To completely reseal your watch jump straight to step 14.
  6. How to Reseal an Apple Watch, Clean the watch frame: adım 6, 2 resimden 1. How to Reseal an Apple Watch, Clean the watch frame: adım 6, 2 resimden 2.
    $7.99
    • To remove the adhesive on the side with the display cables, gently fold the cables down.
    • Don‘t fold the cable sharply and only bend them to avoid cable damage.
  7. How to Reseal an Apple Watch, Clean the rear side of the display: adım 7, 2 resimden 1. How to Reseal an Apple Watch, Clean the rear side of the display: adım 7, 2 resimden 2.
    • If you‘re reusing your old display you need to remove the leftover adhesive from its rear side.
  8. How to Reseal an Apple Watch, Prepare the adhesive: adım 8, 1 resimden 1.
  9. How to Reseal an Apple Watch, Apply the new adhesive: adım 9, 2 resimden 1. How to Reseal an Apple Watch, Apply the new adhesive: adım 9, 2 resimden 2.
    • Hold the replacement adhesive diagonally and thread it over the display cables.
    • Slightly tilt the display cables forward to align the adhesive with the frame.
  10. How to Reseal an Apple Watch: adım 10, 1 resimden 1.
  11. How to Reseal an Apple Watch, Reconnect the screen: adım 11, 2 resimden 1. How to Reseal an Apple Watch, Reconnect the screen: adım 11, 2 resimden 2.
    • Lay your display flat on your working surface.
    • Hold the watch body in an upright position and grab the display cables with a pair of tweezers.
    • Before inserting the cables into the connectors, make sure the ZIF connector flaps are in an upright position. Otherwise, you risk damaging the cables.
    • Align the display cables parallel to the ZIF connectors and push them in.
    • No force is needed to push the cables into the connectors. If the cable doesn’t insert easily, it’s probably misaligned and needs to be gently removed and repositioned.
  12. How to Reseal an Apple Watch, Secure the ZIF connectors: adım 12, 3 resimden 1. How to Reseal an Apple Watch, Secure the ZIF connectors: adım 12, 3 resimden 2. How to Reseal an Apple Watch, Secure the ZIF connectors: adım 12, 3 resimden 3.
    • Use the pointed end of a spudger and fold down the black flaps on top of the ZIF connectors to secure the cables.
  13. How to Reseal an Apple Watch, Reinstall the heat dissipation stickers: adım 13, 3 resimden 1. How to Reseal an Apple Watch, Reinstall the heat dissipation stickers: adım 13, 3 resimden 2. How to Reseal an Apple Watch, Reinstall the heat dissipation stickers: adım 13, 3 resimden 3.
    • Carefully adhere the old heat dissipation stickers to the ZIF connectors on the rear side of the display or apply new heat dissipation stickers where the old ones were located.
  14. How to Reseal an Apple Watch, Remove the protective film: adım 14, 3 resimden 1. How to Reseal an Apple Watch, Remove the protective film: adım 14, 3 resimden 2. How to Reseal an Apple Watch, Remove the protective film: adım 14, 3 resimden 3.
    • Use tweezers and a pair of scissors to lift and cut a corner of the protective film.
    • Remove the film from the display adhesive.
  15. How to Reseal an Apple Watch, Reseal the Apple Watch: adım 15, 2 resimden 1. How to Reseal an Apple Watch, Reseal the Apple Watch: adım 15, 2 resimden 2.
    • Align the screen and press it down firmly onto the adhesive.
    • To improve bonding of the adhesive, apply a heated iOpener to the display. Then apply pressure for a few hours —for example, place your Apple Watch under one or two heavy books overnight.
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
247.614 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.765 adet Kılavuz yazıldı
2Kılavuz Yorumları
Applying this adhesive is a mess. It sticks to everything, except the watch itself. I ruined one. I will use glue instead. Great that I ordered two for two separate watches.
Krisztian - Yanıt
Also the adhesive is not thick enough nor broad enough. Really disappointed. I trust my B7000 more!
Dieter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 109
Son 30 gün: 506
Her zaman: 20,209
