Ana içeriğe geç
Huawei P20 Pro Battery Replacement
Neye ihtiyacın var
  1. Huawei P20 Pro Battery Replacement, Rear Glass Replacement: adım 1, 1 resimden 1.
    • Switch off your phone.
    • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Huawei P20 Pro is of moderate strength, however a hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Huawei P20 Pro Battery Replacement: adım 2, 3 resimden 1. Huawei P20 Pro Battery Replacement: adım 2, 3 resimden 2. Huawei P20 Pro Battery Replacement: adım 2, 3 resimden 3.
    • If the phone's rear glass is cracked, a suction cup may not stick very well. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the rear glass close to the bottom edge of the phone.
    • Lift the bottom edge with the suction cup, opening a slight gap between the rear glass and the frame.
    • Insert an opening pick in the gap and slide it to the bottom right corner. Leave it there to prevent the adhesive from resealing.
  3. Huawei P20 Pro Battery Replacement: adım 3, 2 resimden 1. Huawei P20 Pro Battery Replacement: adım 3, 2 resimden 2.
    • Insert a second opening pick and slide it to the bottom left corner. Leave it there to prevent the adhesive from resealing.
  4. Huawei P20 Pro Battery Replacement: adım 4, 3 resimden 1. Huawei P20 Pro Battery Replacement: adım 4, 3 resimden 2. Huawei P20 Pro Battery Replacement: adım 4, 3 resimden 3.
    • Insert a third opening pick at the bottom left corner.
    • Slide the tip of the opening pick along the left edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner of the phone to prevent the adhesive from resealing.
  5. Huawei P20 Pro Battery Replacement: adım 5, 2 resimden 1. Huawei P20 Pro Battery Replacement: adım 5, 2 resimden 2.
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
    • Insert a fourth opening pick at the top left corner of the phone.
    • Slide the opening pick along the upper edge of the phone to cut the adhesive beneath the rear glass and leave it in the top right corner.
  6. Huawei P20 Pro Battery Replacement: adım 6, 3 resimden 1. Huawei P20 Pro Battery Replacement: adım 6, 3 resimden 2. Huawei P20 Pro Battery Replacement: adım 6, 3 resimden 3.
    • Insert a fifth opening pick at the top right corner of the rear glass.
    • Slide the opening pick along the right edge of the phone to cut the remaining adhesive.
    • Don't open the phone all the way yet. The proximity sensor flex cable is still connected to the motherboard.
  7. Huawei P20 Pro Battery Replacement: adım 7, 3 resimden 1. Huawei P20 Pro Battery Replacement: adım 7, 3 resimden 2. Huawei P20 Pro Battery Replacement: adım 7, 3 resimden 3.
    • Carefully lift the rear glass until you can reach the connector of the proximity sensor flex cable next to the rear camera assembly.
  8. Huawei P20 Pro Battery Replacement: adım 8, 2 resimden 1. Huawei P20 Pro Battery Replacement: adım 8, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the proximity sensor flex cable.
  9. Huawei P20 Pro Battery Replacement: adım 9, 2 resimden 1. Huawei P20 Pro Battery Replacement: adım 9, 2 resimden 2.
    • Remove the rear glass.
    • Before installing fresh adhesive and reassembly, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
  10. Huawei P20 Pro Battery Replacement, Motherboard Cover and NFC: adım 10, 1 resimden 1.
    • Remove the nine Phillips #00 screws (3.4 mm length).
  11. Huawei P20 Pro Battery Replacement: adım 11, 3 resimden 1. Huawei P20 Pro Battery Replacement: adım 11, 3 resimden 2. Huawei P20 Pro Battery Replacement: adım 11, 3 resimden 3.
    • Insert an opening pick under the left side of the motherboard cover that includes the NFC.
    • Slide the opening pick towards the top left corner of the phone and twist it to pry the cover out of its plastic clamps.
  12. Huawei P20 Pro Battery Replacement: adım 12, 2 resimden 1. Huawei P20 Pro Battery Replacement: adım 12, 2 resimden 2.
    • Repeat the previous process on the right side and twist the opening pick to pry up the motherboard cover.
  13. Huawei P20 Pro Battery Replacement: adım 13, 1 resimden 1.
    • Remove the motherboard cover.
  14. Huawei P20 Pro Battery Replacement, Battery Disconnect: adım 14, 2 resimden 1. Huawei P20 Pro Battery Replacement, Battery Disconnect: adım 14, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
  15. Huawei P20 Pro Battery Replacement, Interconnect Cable with Charging Port: adım 15, 1 resimden 1.
    • Remove the five Phillips #00 screws (3.4 mm length).
  16. Huawei P20 Pro Battery Replacement: adım 16, 3 resimden 1. Huawei P20 Pro Battery Replacement: adım 16, 3 resimden 2. Huawei P20 Pro Battery Replacement: adım 16, 3 resimden 3.
    • Use a pair of tweezers to disconnect the antenna cable.
    • Use a pair of tweezers to pull the antenna cable out of its routing.
  17. Huawei P20 Pro Battery Replacement: adım 17, 3 resimden 1. Huawei P20 Pro Battery Replacement: adım 17, 3 resimden 2. Huawei P20 Pro Battery Replacement: adım 17, 3 resimden 3.
    • Slide an opening pick under the left side of the daughterboard cover and start to pry it up until you can get a good grip.
    • Remove the daughterboard cover.
  18. Huawei P20 Pro Battery Replacement: adım 18, 1 resimden 1.
    • Remove the two Phillips #00 screws (3.4 mm length) on both sides of the USB C port.
  19. Huawei P20 Pro Battery Replacement: adım 19, 2 resimden 1. Huawei P20 Pro Battery Replacement: adım 19, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the upper end of the interconnect and charging port flex cable from the motherboard.
  20. Huawei P20 Pro Battery Replacement: adım 20, 3 resimden 1. Huawei P20 Pro Battery Replacement: adım 20, 3 resimden 2. Huawei P20 Pro Battery Replacement: adım 20, 3 resimden 3.
    • Use the flat end of a spudger to pry up and disconnect the bottom end of the interconnect and charging port flex cable from the daughterboard.
    • Use a pair of tweezers to move the antenna cable out of the way.
  21. Huawei P20 Pro Battery Replacement: adım 21, 3 resimden 1. Huawei P20 Pro Battery Replacement: adım 21, 3 resimden 2. Huawei P20 Pro Battery Replacement: adım 21, 3 resimden 3.
    • Use a pair of tweezers to pull the charging port out of its recess.
    • Remove the interconnect cable including the charging port.
  22. Huawei P20 Pro Battery Replacement, Battery: adım 22, 3 resimden 1. Huawei P20 Pro Battery Replacement, Battery: adım 22, 3 resimden 2. Huawei P20 Pro Battery Replacement, Battery: adım 22, 3 resimden 3.
    • Use an iOpener to loosen the adhesive beneath the battery. Apply the iOpener on the display for at least two minutes.
    • In the following step, only apply the spudger in the areas marked in red, which is where the battery adhesive is located.
    • Avoid the orange area where the display flex cable is running.
  23. Huawei P20 Pro Battery Replacement: adım 23, 3 resimden 1. Huawei P20 Pro Battery Replacement: adım 23, 3 resimden 2. Huawei P20 Pro Battery Replacement: adım 23, 3 resimden 3.
    • In case you have trouble to pry up the battery the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for about two minutes to help weaken the adhesive.
    • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert the flat end of a spudger at the top left corner of the battery and start to pry it up.
    • Work your way down the left side of the battery and loosen the adhesive with the spudger.
  24. Huawei P20 Pro Battery Replacement: adım 24, 3 resimden 1. Huawei P20 Pro Battery Replacement: adım 24, 3 resimden 2. Huawei P20 Pro Battery Replacement: adım 24, 3 resimden 3.
    • Insert the spudger at the top right corner of the battery and start to pry it up.
    • Work your way down to the bottom end of the battery to loosen all the adhesive.
  25. Huawei P20 Pro Battery Replacement: adım 25, 2 resimden 1. Huawei P20 Pro Battery Replacement: adım 25, 2 resimden 2.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard. Replace it with a new battery.
    • Before installing a new battery remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place for 5-10 seconds.
Sonuç
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
59 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
203.353 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
22 Yorum
Quando sostituisci la batteria perdi tutti i dati ?
ale - Yanıt
Hi Ale,
when replacing the battery you won’t lose any data as long as you don’t damage any relevant components for data saving.
Dato che purtroppo non parlo italiano, ho creato questa risposta con l'aiuto di un traduttore. — Quando si sostituisce la batteria non si perderanno dati finché non si danneggiano componenti rilevanti per il salvataggio dei dati.
Dominik Schnabelrauch -
I just watched 2 YouTube guides on doing this and one used an adhesive ring strip while the other used glue from a bottle. Is one solution any more solid than the other?
Also, I don’t have an iOpener so would either isopropyl alcohol or a hair dryer be a good alternative for softening the back cover/battery adhesive?
Finally, I’ve seen and heard people using all sorts of things to pry out phone batteries ~ plastic pry sticks, metal pry tools, and even flat-edge screwdrivers. Which tool(s) are the safest and/or most effective?
TinkerJosh - Yanıt
Hi TinkerJosh, isopropyl alcohol (>97%) is a valid option for softening adhesive. A hairdryer will also achieve a good result for heating the adhesive. I would advise against using metal tools (such as metal spudgers or flat screwdrivers). To pry out the battery you are better off with opening picks and a plastic card. Either way, try not to puncture or deform the battery to avoid damaging it. Successful repairing
Tobias Isakeit -
Great instruction, Thanks. Is there a part # For the new adhesive gasket, and where can it be bought?
derek5 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 32
Son 7 gün: 247
Son 30 gün: 1,161
Her zaman: 108,072
