Ana içeriğe geç
Insignia NS-CLLT01 LCD Screen Replacement
Shain Powell
Shain Powell ve 5 diğer katkıda bulunanlar
En son August 1, 2019 tarihinde güncellendi
1 saat
Zor
If your clock display is not working, and you've ensured that the clock is turned on with the brightness up, then you may need to replace the screen itself. This guide will help you do so, but you will need to solder some connections.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Insignia NS-CLLT01 LCD Screen Replacement, Insignia NS-CLLT01 Top Casing Removal: adım 1, 2 resimden 1. Insignia NS-CLLT01 LCD Screen Replacement, Insignia NS-CLLT01 Top Casing Removal: adım 1, 2 resimden 2.
    • Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
  2. Insignia NS-CLLT01 LCD Screen Replacement: adım 2, 3 resimden 1. Insignia NS-CLLT01 LCD Screen Replacement: adım 2, 3 resimden 2. Insignia NS-CLLT01 LCD Screen Replacement: adım 2, 3 resimden 3.
    • On the bottom of the clock, use your fingernail to push the battery cover to the right.
    • Lift the battery cover up and to the right to reveal the batteries.
  3. Insignia NS-CLLT01 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
    • Once the batteries are removed, close the cover.
  4. Insignia NS-CLLT01 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
    • Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
    • The screws may not come out of the bottom of the clock. As long as you have unscrewed them, the clock can still be opened.
  5. Insignia NS-CLLT01 LCD Screen Replacement: adım 5, 3 resimden 1. Insignia NS-CLLT01 LCD Screen Replacement: adım 5, 3 resimden 2. Insignia NS-CLLT01 LCD Screen Replacement: adım 5, 3 resimden 3.
    • Turn the clock back over.
    • Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
  6. Insignia NS-CLLT01 LCD Screen Replacement, Motherboard: adım 6, 2 resimden 1. Insignia NS-CLLT01 LCD Screen Replacement, Motherboard: adım 6, 2 resimden 2.
    • Grip the white ribbon cable connector that attaches the lightning cable to the middle of the central circuit board located in the bottom of the clock. Pinch and pull straight up to detach the cable.
  7. Insignia NS-CLLT01 LCD Screen Replacement: adım 7, 2 resimden 1. Insignia NS-CLLT01 LCD Screen Replacement: adım 7, 2 resimden 2.
    • Remove the white ribbon connector that connects the central circuit board to the circuit board attached to the top of the clock by gripping it on both sides and pulling it straight away from the board.
  8. Insignia NS-CLLT01 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Unscrew the two 10mm screws from the bottom circuit board.
  9. Insignia NS-CLLT01 LCD Screen Replacement: adım 9, 3 resimden 1. Insignia NS-CLLT01 LCD Screen Replacement: adım 9, 3 resimden 2. Insignia NS-CLLT01 LCD Screen Replacement: adım 9, 3 resimden 3.
    • Use the narrow end of a plastic spudger to pull back the clip in the center of the board.
    • At the same time, pry the circuit board up by wedging another spudger into the top left-hand corner of the board and working it along the back, pushing the edge of the board away from the back of the clock.
    • The black radio antenna, which is attached to the board and comes out of the back of the clock, will need to be pushed into the clock from the outside as the board is lifted up.
  10. Insignia NS-CLLT01 LCD Screen Replacement: adım 10, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Once the ports on the back of the circuit board are displaced and resting against the back of the clock, use a pair of tweezers to lift the circuit board up off of the bottom of the clock, continuing to feed the radio antenna through the side of the clock as the board lifts up.
  11. Insignia NS-CLLT01 LCD Screen Replacement: adım 11, 1 resimden 1.
    • Pull the radio antenna the rest of the way through the side of the clock.
  12. Insignia NS-CLLT01 LCD Screen Replacement: adım 12, 1 resimden 1.
    • Turn the circuit board over.
    • Disconnect the two white connectors on the bottom of the circuit board by gripping the sides of each connector and pulling straight out.
  13. Insignia NS-CLLT01 LCD Screen Replacement, LCD Screen: adım 13, 2 resimden 1. Insignia NS-CLLT01 LCD Screen Replacement, LCD Screen: adım 13, 2 resimden 2.
    • Lift the adhesive strip that holds down the grey ribbon cable which attaches to the circuit board and the LCD screen.
  14. Insignia NS-CLLT01 LCD Screen Replacement: adım 14, 3 resimden 1. Insignia NS-CLLT01 LCD Screen Replacement: adım 14, 3 resimden 2. Insignia NS-CLLT01 LCD Screen Replacement: adım 14, 3 resimden 3.
    • Remove the screen by pushing it toward the middle of the clock and pulling it up out of the clock.
  15. Insignia NS-CLLT01 LCD Screen Replacement: adım 15, 2 resimden 1. Insignia NS-CLLT01 LCD Screen Replacement: adım 15, 2 resimden 2.
    • Lift the adhesive strip that covers the connections between the grey ribbon cable and the circuit board by peeling it off of the circuit board.
  16. Insignia NS-CLLT01 LCD Screen Replacement: adım 16, 1 resimden 1.
Sonuç
Shain Powell
101 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 6-9, Williams Fall 2015 Baylor, Team 6-9, Williams Fall 2015 üyesi
BU-WILLIAMS-F15S6G9
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 706
