Ana içeriğe geç
JBL Flip 6 Battery Replacement
Neye ihtiyacın var
  1. JBL Flip 6 Battery Replacement, Pry up the fabric cover: adım 1, 3 resimden 1. JBL Flip 6 Battery Replacement, Pry up the fabric cover: adım 1, 3 resimden 2. JBL Flip 6 Battery Replacement, Pry up the fabric cover: adım 1, 3 resimden 3.
    • Before starting repairs, turn off your device and unplug any cables.
    • The fabric cover of the JBL Flip 6 is secured by plastic clips.
    • Insert the flat end of a spudger into the seam between the two halves of the fabric cover.
    • Push the spudger underneath the edge of the fabric cover without the control panel and pry upwards to release its plastic clips.
  2. JBL Flip 6 Battery Replacement, Release the plastic clips: adım 2, 3 resimden 1. JBL Flip 6 Battery Replacement, Release the plastic clips: adım 2, 3 resimden 2. JBL Flip 6 Battery Replacement, Release the plastic clips: adım 2, 3 resimden 3.
    • Repeat the previous step, using your spudger to work your way along the entire seam to release the remaining plastic clips.
  3. JBL Flip 6 Battery Replacement, Pry up the fabric cover: adım 3, 2 resimden 1. JBL Flip 6 Battery Replacement, Pry up the fabric cover: adım 3, 2 resimden 2.
    • Insert the flat end of a spudger underneath the opposite edge of the fabric cover—the side with the control panel.
    • Pry upwards to release the plastic clip.
  4. JBL Flip 6 Battery Replacement, Release the plastic clips: adım 4, 2 resimden 1. JBL Flip 6 Battery Replacement, Release the plastic clips: adım 4, 2 resimden 2.
    • Repeat the previous step to release the last plastic clip on the other end of the fabric cover.
  5. JBL Flip 6 Battery Replacement, Remove the fabric cover: adım 5, 3 resimden 1. JBL Flip 6 Battery Replacement, Remove the fabric cover: adım 5, 3 resimden 2. JBL Flip 6 Battery Replacement, Remove the fabric cover: adım 5, 3 resimden 3.
    • Use one hand to spread the edges of the fabric cover apart and your other hand to pull the speaker assembly away from the cover.
    • Remove the fabric cover.
    • During reassembly, this is a good point to power on your device and test your repair before reinstalling the fabric cover.
  6. JBL Flip 6 Battery Replacement, Unclip the right passive radiator: adım 6, 3 resimden 1. JBL Flip 6 Battery Replacement, Unclip the right passive radiator: adım 6, 3 resimden 2. JBL Flip 6 Battery Replacement, Unclip the right passive radiator: adım 6, 3 resimden 3.
    • The right passive radiator is secured by plastic clips and labeled R.
    • Insert the flat end of a spudger underneath the passive radiator housing near one of the plastic clips.
    • Pry upwards to release the first plastic clip holding the passive radiator housing in place.
  7. JBL Flip 6 Battery Replacement: adım 7, 2 resimden 1. JBL Flip 6 Battery Replacement: adım 7, 2 resimden 2.
    • Repeat the previous step to release all of the plastic clips holding the housing in place.
  8. JBL Flip 6 Battery Replacement, Remove the right passive radiator: adım 8, 2 resimden 1. JBL Flip 6 Battery Replacement, Remove the right passive radiator: adım 8, 2 resimden 2.
    • Remove the right passive radiator.
  9. JBL Flip 6 Battery Replacement, Unfasten the safety bracket: adım 9, 2 resimden 1. JBL Flip 6 Battery Replacement, Unfasten the safety bracket: adım 9, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 9.5 mm-long screws securing the safety bracket.
  10. JBL Flip 6 Battery Replacement, Remove the safety bracket: adım 10, 2 resimden 1. JBL Flip 6 Battery Replacement, Remove the safety bracket: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or your fingers to remove the safety bracket.
  11. JBL Flip 6 Battery Replacement, Unfasten the woofer: adım 11, 2 resimden 1. JBL Flip 6 Battery Replacement, Unfasten the woofer: adım 11, 2 resimden 2.
    • Use a Phillips screwdriver to remove the four 9.5 mm-long screws securing the woofer.
    • Don't try to remove the woofer all the way yet, as it‘s still connected to the motherboard.
  12. JBL Flip 6 Battery Replacement, Move the woofer: adım 12, 3 resimden 1. JBL Flip 6 Battery Replacement, Move the woofer: adım 12, 3 resimden 2. JBL Flip 6 Battery Replacement, Move the woofer: adım 12, 3 resimden 3.
    • The woofer cables are long enough to allow placing the woofer outside the speaker assembly, but avoid straining or sharply folding the cables when doing so.
    • When handling the woofer, grab it by its edges to avoid damaging the fragile center material.
    • Lift the woofer out of its recess and place it next to the speaker assembly.
  13. JBL Flip 6 Battery Replacement, Disconnect the woofer: adım 13, 2 resimden 1. JBL Flip 6 Battery Replacement, Disconnect the woofer: adım 13, 2 resimden 2.
    • The woofer is connected to the motherboard with a JST connector.
    • Use a pair of tweezers to grasp the sides of the woofer connector.
    • Slide the connector out of its socket, gently wiggling it left and right to loosen the clips securing it.
  14. JBL Flip 6 Battery Replacement, Remove the woofer: adım 14, 1 resimden 1.
    • Remove the woofer.
  15. JBL Flip 6 Battery Replacement, Unfasten the tweeter: adım 15, 2 resimden 1. JBL Flip 6 Battery Replacement, Unfasten the tweeter: adım 15, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 9.5 mm-long screws securing the tweeter.
  16. JBL Flip 6 Battery Replacement, Tweeter connector information: adım 16, 2 resimden 1. JBL Flip 6 Battery Replacement, Tweeter connector information: adım 16, 2 resimden 2.
    • There are different versions of the JBL Flip 6 with different tweeter connectors. Both require a slightly different disconnection procedure.
    • A connector next to the woofer connector, which can be disconnected just like the woofer's.
    • A spade connector with contact springs, which can be disconnected by simply prying up the tweeter.
    • To pry up the tweeter, insert the tip of a spudger between the battery connector and the connector stem of the tweeter and gently press the tweeter upwards to push the stems out of their contact springs.
    • To reconnect the spade connector, just press the contacts back into the springs.
  17. JBL Flip 6 Battery Replacement, Remove the tweeter: adım 17, 3 resimden 1. JBL Flip 6 Battery Replacement, Remove the tweeter: adım 17, 3 resimden 2. JBL Flip 6 Battery Replacement, Remove the tweeter: adım 17, 3 resimden 3.
    • Use a spudger to pry up the tweeter.
    • Remove the tweeter.
  18. JBL Flip 6 Battery Replacement, Unlatch the power button cable ZIF connector: adım 18, 2 resimden 1. JBL Flip 6 Battery Replacement, Unlatch the power button cable ZIF connector: adım 18, 2 resimden 2.
    • Use the tip of a spudger or your fingernail to flip up the small, hinged locking flap on the power button cable ZIF connector.
  19. JBL Flip 6 Battery Replacement, Disconnect the power button cable: adım 19, 2 resimden 1. JBL Flip 6 Battery Replacement, Disconnect the power button cable: adım 19, 2 resimden 2.
    • Use a pair of tweezers to pull the power button cable out of the ZIF connector.
  20. JBL Flip 6 Battery Replacement, Unlatch the charging cable ZIF connector: adım 20, 2 resimden 1. JBL Flip 6 Battery Replacement, Unlatch the charging cable ZIF connector: adım 20, 2 resimden 2.
    • Use the tip of a spudger or your fingernail to flip up the small, hinged locking flap on the charging cable ZIF connector.
  21. JBL Flip 6 Battery Replacement, Disconnect the charging cable: adım 21, 2 resimden 1. JBL Flip 6 Battery Replacement, Disconnect the charging cable: adım 21, 2 resimden 2.
    • Use a pair of tweezers to pull the charging cable out of the ZIF connector.
  22. JBL Flip 6 Battery Replacement, Unlatch the volume button cable ZIF connector: adım 22, 2 resimden 1. JBL Flip 6 Battery Replacement, Unlatch the volume button cable ZIF connector: adım 22, 2 resimden 2.
    • Use the tip of a spudger or your fingernail to flip up the small, hinged locking flap on the volume button cable ZIF connector.
  23. JBL Flip 6 Battery Replacement, Disconnect the volume button cable: adım 23, 2 resimden 1. JBL Flip 6 Battery Replacement, Disconnect the volume button cable: adım 23, 2 resimden 2.
    • Use a pair of tweezers to pull the volume button cable out of the ZIF connector.
  24. JBL Flip 6 Battery Replacement, Move the motherboard: adım 24, 2 resimden 1. JBL Flip 6 Battery Replacement, Move the motherboard: adım 24, 2 resimden 2.
    • Insert a finger into the woofer cutout and press against the left edge of the motherboard.
    • Push the motherboard out of the speaker assembly just until you get free access to the battery connector. You don't need to push it out all the way.
  25. JBL Flip 6 Battery Replacement, Disconnect the battery: adım 25, 3 resimden 1. JBL Flip 6 Battery Replacement, Disconnect the battery: adım 25, 3 resimden 2. JBL Flip 6 Battery Replacement, Disconnect the battery: adım 25, 3 resimden 3.
    • The battery is connected to the motherboard with a power cable connector that has a small tab on the side that locks it in place.
    • Squeeze the tab against the connector, and pull the connector straight up from its socket to disconnect the battery.
  26. JBL Flip 6 Battery Replacement, Remove the battery: adım 26, 3 resimden 1. JBL Flip 6 Battery Replacement, Remove the battery: adım 26, 3 resimden 2. JBL Flip 6 Battery Replacement, Remove the battery: adım 26, 3 resimden 3.
    • Pull the battery out of the speaker assembly to remove it.
Sonuç
If possible, power on your device and test your repair before reassembly. For optimal performance, calibrate your newly installed battery after completing this guide.
13 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
257.165 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
25.562 adet Kılavuz yazıldı
2Kılavuz Yorumları
Donde puedo y me recomiendas comprar la bateria de mi Flip 6
Juan - Yanıt Paylaş
Yowza! ABSOLUTELY Great directions. THANK YOU!
I Read thru this while trying to decide which small portable Bluetooth speaker to buy. Tired of tossing units because the battery is not replaceable. This JBL Flip 6 IS but >>> WOW - not exactly easy for someone not too experienced. Guess I will just have to learn and gain experience. Sure wish Samsung/JBL made life easier for users tho. The only thing that looks 'iffy' for this speaker is the fraying fabric. I guess nail polish might stop the fraying.
[As for getting back into 'fixing' things - reminds me that when i was 6 i took my Baby Ben Clock apart and after reconstruction there was ONE screw left over. Clock worked for the next 23 years as I moved frm place to place and then it somehow just disappeared (alas). Since then (some 50 yrs) I've always wondered WHY the clock was constructed with an 'extra' screw in the first place]
Abi Woodbridge - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 162
Son 30 gün: 729
Her zaman: 21,464
