Ana içeriğe geç
LG G3 Battery Replacement
Neye ihtiyacın var
    1. LG G3 Battery Replacement, Back Cover: adım 1, 2 resimden 1. LG G3 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
      • Power off your phone before beginning disassembly.
      • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
      • Pry the back cover up to separate its plastic clips.
      FixBot'a Sor
      Yorum Ekle
    2. LG G3 Battery Replacement: adım 2, 2 resimden 1. LG G3 Battery Replacement: adım 2, 2 resimden 2.
      • Lift the back cover to release the rest of the plastic clips and remove it.
      • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
      • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. LG G3 Battery Replacement, Battery: adım 3, 2 resimden 1. LG G3 Battery Replacement, Battery: adım 3, 2 resimden 2.
      • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
      FixBot'a Sor
      Yorum Ekle
    2. LG G3 Battery Replacement: adım 4, 2 resimden 1. LG G3 Battery Replacement: adım 4, 2 resimden 2.
      • Lift the battery out of its recess and remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
21 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
262.731 İtibar
682 adet Kılavuz yazıldı
1Rehber Yorum
Thank you very much!
ItayDigital - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 17
Son 30 gün: 82
Her zaman: 18,817
