Laser Lens Cleaning
Giriş
1. adıma gitThis guide shows where to locate and clean the lens that reads the discs. This may be necessary if the DVD Player isn't reading discs correctly. This will take delicate work in order not to damage the lens.
Neye ihtiyacın var
Aletler
Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
Remove five 7.5 mm Phillips screws on the back of the player.
Locate the lens on the disc drive.
Dip one end of a cotton swab in rubbing alcohol.
Lightly dab the swab on the lens. Be very gentle.
Let the lens dry before replacing the top plate of the DVD player.
13 farklı kişi bu kılavuzu tamamladı.
5Kılavuz Yorumları
ne fonctionne toujours pas
My problem I think is alignment
When i put in a dvd the dvd player want open
I have to unplug it and plug it back in, so it
will open. If I don't put a dvd in it opens and'
closes fine. What's causing this ?
John Bailey - Yanıt
