Ana içeriğe geç
Laser Lens Cleaning
Laser Lens Cleaning
Nathan Klammer
Nathan Klammer ve 5 diğer katkıda bulunanlar
En son February 5, 2024 tarihinde güncellendi
10 dakika
Kolay
This guide shows where to locate and clean the lens that reads the discs. This may be necessary if the DVD Player isn't reading discs correctly. This will take delicate work in order not to damage the lens.
Neye ihtiyacın var
Aletler
  1. Laser Lens Cleaning, Top Panel: adım 1, 2 resimden 1. Laser Lens Cleaning, Top Panel: adım 1, 2 resimden 2.
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
    When i put in a dvd the dvd player want open
    I have to unplug it and plug it back in, so it
    will open. If I don't put a dvd in it opens and'
    closes fine. What's causing this ?
    John Bailey - Yanıt
  2. Laser Lens Cleaning: adım 2, 2 resimden 1. Laser Lens Cleaning: adım 2, 2 resimden 2.
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Laser Lens Cleaning, Laser Lens Cleaning: adım 3, 2 resimden 1. Laser Lens Cleaning, Laser Lens Cleaning: adım 3, 2 resimden 2.
    • Locate the lens on the disc drive.
    • Make sure that there is no dust on or near the player and area you are working on. Dust can get on the lens and scratch it while you are cleaning. It is very important that the lens is not damaged because the lens is used to read the discs.
    • Dip one end of a cotton swab in rubbing alcohol.
    • Lightly dab the swab on the lens. Be very gentle.
    • Let the lens dry before replacing the top plate of the DVD player.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Nathan Klammer
476 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G20
4 Üyeler
7 adet Kılavuz yazıldı
5Kılavuz Yorumları
This item was not appropriate, thank you for trying.
bigd734 - Yanıt
Works on Samsung's box(home theater), thank you!
CarlBraun - Yanıt
It worked on my cheap player. This unit is on 24/7. The dust in the house is heavy and smokers so the fix is cheap and I picked up a few things. Thanks
Seeker - Yanıt
ne fonctionne toujours pas
JEAN PIERRE LARVOR - Yanıt
My problem I think is alignment
James Smith - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 70
Son 30 gün: 389
Her zaman: 53,011
