Giriş
Laptop batteries can become faulty in as little as 2 years. Having a working battery is an essential piece to an efficient laptop, as the main function of the laptop is to be able to work away from home. Laptops with short battery lives can be extremely tedious as you constantly need to be plugging them in to an outlet.
If you have had your Lenovo IdeaPad Flex 5-1570 for longer than 2 years and/or you are experiencing a short battery life, it may be time to replace your battery. Do not worry however, replacing the battery in this device is simple and requires little to no tools.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Neye ihtiyacın var
Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Hullo. In the pic on step -1, near the top left screw, the back cover is cracking up. Whenever, I open the Display panel, the back panel at this point shows tendency to open. The screw is obviously is out of its threading. Is this damage, physical or due to battery swelling. My battery life seems alright. After full charge, it stays for more than 30h with intermittent use. Can you reply to svnarasimhan5@gmail.com
Hello,
Thank you so much for the guide.
Have a question though, is the following battery compatible for Lenovo Flex 5 1570 (Type 80XB): https://www.ebuyindia.in/products/origin...
Appreciate your help.
I bought this battery to replace my old failed battery. The installation went very well. But I soon noticed that the battery and the charging adaptor were getting extremely hot every time I plugged it in. After 1 month the laptop stopped completely. There was absolutely no issues with the laptop before except the battery.
I would never go for an iFixit battery again.
