Ana içeriğe geç
Lenovo ThinkPad T431S Screen Replacement
Christine Portanova
Christine Portanova ve 4 diğer katkıda bulunanlar
En son June 3, 2020 tarihinde güncellendi
10 dakika
Orta
This guide will show you how to locate and replace the Lenovo T431s screen. The screen is what gives your visuals on your computer. If you have a blotchy screen, poor visuals, or physical screen damage, you might need to replace your screen.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Lenovo ThinkPad T431S Screen Replacement, Screen: adım 1, 2 resimden 1. Lenovo ThinkPad T431S Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use the Jimmy tool to remove the screen bezel with a gentle prying motion.
  2. Lenovo ThinkPad T431S Screen Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad T431S Screen Replacement: adım 2, 2 resimden 2.
    • Remove the four 3.0 mm screws in the four corners of the screen with a Phillips #1 screwdriver bit.
    • While removing the screws, pry the screen off with an opening tool.
    • If your screen is cracked, use caution, as there will be broken glass or sharp parts.
  3. Lenovo ThinkPad T431S Screen Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T431S Screen Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T431S Screen Replacement: adım 3, 3 resimden 3.
    • Lift screen off of top panel to reveal LCD power plug/connector.
    • There will be a wire attaching the screen to the rest of the device.
    • Remove the tape on the wire so you can unplug the connection, pulling upwards.
    • Information about disposal of your damaged screen can be found at E-Waste Recycling
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 992
