Giriş
This guide will show you how to replace the external battery on your Lenovo ThinkPad T460.
A healthy laptop battery will keep your laptop powered on, even when your device is unplugged from an external power source.
If your laptop no longer holds a charge, or loses its charge very quickly, you most likely have a dead or failing battery which may require replacement. Depending on the cause of your faulty battery, you may be able to resolve the issue using this list of troubleshooting symptoms and solutions from Lenovo’s support forum.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Neye ihtiyacın var
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
For optimal performance, after completing this guide, calibrate your newly installed battery.
