Ana içeriğe geç
Lenovo ThinkPad T480 Keyboard Replacement
Sarah Westberg
Sarah Westberg ve başka bir katkıda bulunan
En son December 20, 2023 tarihinde güncellendi
10 - 20 dakika
Kolay
If the keyboard becomes dirty, it loses keys, or it becomes non-functional, you might need to replace the keyboard of your Lenovo ThinkPad T480.
The keyboard is an integral component of your Lenovo ThinkPad T480. It is one of the main input devices of your laptop, allowing the user to enter data in the form of characters like numbers and letters into the computer.
This repair is an easy process. Just be sure to disable the internal battery, remove the external battery and unplug the device prior to beginning your fix. Also be careful when you remove the keyboard because it is connected to two cables on the underside that need to be detached.
Neye ihtiyacın var
Parçalar
Aletler
  • Spudger
    Spudger
Daha fazlasını göster…
  1. Lenovo ThinkPad T480 Keyboard Replacement, External Battery: adım 1, 2 resimden 1. Lenovo ThinkPad T480 Keyboard Replacement, External Battery: adım 1, 2 resimden 2.
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Keyboard Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480 Keyboard Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480 Keyboard Replacement: adım 2, 3 resimden 3.
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
  4. Lenovo ThinkPad T480 Keyboard Replacement: adım 4, 1 resimden 1.
    • Open the laptop so the keyboard is facing you.
  5. Lenovo ThinkPad T480 Keyboard Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T480 Keyboard Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T480 Keyboard Replacement: adım 5, 3 resimden 3.
    • Push the keyboard towards the screen and away from the trackpad and then slide it out towards you gently.
    • The keyboard is connected to the board by two ribbon connectors.
    • Be careful not to rip the connectors when you flip the keyboard over.
  6. Lenovo ThinkPad T480 Keyboard Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T480 Keyboard Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T480 Keyboard Replacement: adım 6, 3 resimden 3.
    • Flip the keyboard over towards you to expose the backside of the keyboard and the two ribbon connectors.
    • Using the black nylon spudger, flip the first ribbon connector lock open. Slide the first connector out.
  7. Lenovo ThinkPad T480 Keyboard Replacement: adım 7, 3 resimden 1. Lenovo ThinkPad T480 Keyboard Replacement: adım 7, 3 resimden 2. Lenovo ThinkPad T480 Keyboard Replacement: adım 7, 3 resimden 3.
    • Using the black nylon spudger, unlock the second ribbon connector and slide it out from the port.
  8. Lenovo ThinkPad T480 Keyboard Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad T480 Keyboard Replacement: adım 8, 2 resimden 2.
    • Remove the keyboard from the laptop.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Sarah Westberg
29.405 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.468 adet Kılavuz yazıldı
3 Yorum
Thanks for this. I need help with my Lenovo Thinkpad T480 keyboard to motherboard connector pin. That is the third image in step 6.
Where can I get a replacement?
EagleCreeks Assortment - Yanıt
Thank you so much!
Lioneed Devotchenko - Yanıt
Hi @lioneeddev99026, You are most welcome. I'm glad the guide was helpful!
Sarah Westberg -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 154
Son 30 gün: 619
Her zaman: 17,946
