Ana içeriğe geç
Lenovo ThinkPad T490s SSD Replacement
Clay Eickemeyer
Clay Eickemeyer ve 2 diğer katkıda bulunanlar
En son March 18, 2025 tarihinde güncellendi
15 - 30 dakika
Kolay
Follow this guide through the process of removing and replacing the Solid State Drive (SSD) in your Thinkpad T490s. A common use of this process is to upgrade the SSD. Note that a thermal pad helps the SSD dissipate heat more effectively. Remember to keep the original thermal pad, or have a replacement ready.
Before you perform this repair, back up your existing SSD if possible. If you’re replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Neye ihtiyacın var
Tamir Setleri
Bu kitler, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. Lenovo ThinkPad T490s SSD Replacement, Loosen the back screws: adım 1, 2 resimden 1. Lenovo ThinkPad T490s SSD Replacement, Loosen the back screws: adım 1, 2 resimden 2.
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These screws are captive—they won't come out after being unscrewed.
  2. Lenovo ThinkPad T490s SSD Replacement, Release the clips: adım 2, 2 resimden 1. Lenovo ThinkPad T490s SSD Replacement, Release the clips: adım 2, 2 resimden 2.
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the clips holding the cover. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad T490s SSD Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T490s SSD Replacement: adım 3, 2 resimden 2.
    • Insert your opening pick between the cover and the device body at the other hinge corner.
    • Pry upward to release additional retaining clips.
  4. Lenovo ThinkPad T490s SSD Replacement, Remove the back cover: adım 4, 3 resimden 1. Lenovo ThinkPad T490s SSD Replacement, Remove the back cover: adım 4, 3 resimden 2. Lenovo ThinkPad T490s SSD Replacement, Remove the back cover: adım 4, 3 resimden 3.
    • Grab the front edge of the cover and lift it away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  5. Lenovo ThinkPad T490s SSD Replacement, Disconnect the battery cable: adım 5, 2 resimden 1. Lenovo ThinkPad T490s SSD Replacement, Disconnect the battery cable: adım 5, 2 resimden 2.
    • Grab the battery pull-tab at the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad T490s SSD Replacement, Remove the SSD screw: adım 6, 2 resimden 1. Lenovo ThinkPad T490s SSD Replacement, Remove the SSD screw: adım 6, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the 3.7 mm-long screw holding down the SSD.
  7. Lenovo ThinkPad T490s SSD Replacement, Remove the SSD by hand: adım 7, 3 resimden 1. Lenovo ThinkPad T490s SSD Replacement, Remove the SSD by hand: adım 7, 3 resimden 2. Lenovo ThinkPad T490s SSD Replacement, Remove the SSD by hand: adım 7, 3 resimden 3.
    • Pull the SSD out and away from its socket.
    • If this motion requires excessive force, walk the SSD side to side as you pull.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
3 farklı kişi bu kılavuzu tamamladı.
Clay Eickemeyer
82.327 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.502 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 35
Son 30 gün: 233
Her zaman: 6,227
