Ana içeriğe geç
Lenovo Thinkpad T450 CMOS Battery Replacement
Justin Ogihara
Justin Ogihara
En son January 24, 2024 tarihinde güncellendi
6 - 10 dakika
Orta
The CMOS (Complementary Metal Oxide Semiconductor) battery powers the BIOS firmware in a computer. The CMOS battery is a chip that is typically found in laptops rather than desktops. When you unplug your laptop from its power source, the BIOS relies on the CMOS battery for power. Most CMOS batteries in laptops will last 2 to 10 years from the date they were manufactured.
Common CMOS battery failure symptoms include the following:
  • Constant beeping noise coming from the motherboard
  • Date and time of the computer have been reset
  • Hardware drivers are missing or have disappeared
  • Can’t connect to the Internet
  • Laptop won’t boot up
If your device is experiencing any of the above symptoms, it may be time to replace the CMOS battery. Follow the instructions below to remove and replace the CMOS battery in the Lenovo ThinkPad T450 laptop.
Neye ihtiyacın var
Aletler
  1. Lenovo Thinkpad T450 CMOS Battery Replacement, External Battery: adım 1, 3 resimden 1. Lenovo Thinkpad T450 CMOS Battery Replacement, External Battery: adım 1, 3 resimden 2. Lenovo Thinkpad T450 CMOS Battery Replacement, External Battery: adım 1, 3 resimden 3.
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 CMOS Battery Replacement, Back Cover: adım 2, 1 resimden 1.
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 CMOS Battery Replacement: adım 3, 3 resimden 1. Lenovo Thinkpad T450 CMOS Battery Replacement: adım 3, 3 resimden 2. Lenovo Thinkpad T450 CMOS Battery Replacement: adım 3, 3 resimden 3.
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 CMOS Battery Replacement, CMOS Battery: adım 4, 3 resimden 1. Lenovo Thinkpad T450 CMOS Battery Replacement, CMOS Battery: adım 4, 3 resimden 2. Lenovo Thinkpad T450 CMOS Battery Replacement, CMOS Battery: adım 4, 3 resimden 3.
    • Using the plastic opening tool, disconnect the CMOS battery from the motherboard.
  5. Lenovo Thinkpad T450 CMOS Battery Replacement: adım 5, 2 resimden 1. Lenovo Thinkpad T450 CMOS Battery Replacement: adım 5, 2 resimden 2.
    • Insert the plastic opening tool underneath the CMOS battery and pry it up and away from the motherboard.
    • When you reassemble your device, you may need to reapply adhesive to the back of the CMOS battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Justin Ogihara
29.081 İtibar
52 adet Kılavuz yazıldı
Ekip
EDU Team EDU Team üyesi
Staff
7 Üyeler
753 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 53
Son 30 gün: 286
Her zaman: 12,688
