Ana içeriğe geç
Lenovo Thinkpad T450 Internal Battery Replacement
Neye ihtiyacın var
  1. Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: adım 1, 3 resimden 1. Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: adım 1, 3 resimden 2. Lenovo Thinkpad T450 Internal Battery Replacement, External Battery: adım 1, 3 resimden 3.
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 Internal Battery Replacement, Back Cover: adım 2, 1 resimden 1.
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 Internal Battery Replacement: adım 3, 3 resimden 1. Lenovo Thinkpad T450 Internal Battery Replacement: adım 3, 3 resimden 2. Lenovo Thinkpad T450 Internal Battery Replacement: adım 3, 3 resimden 3.
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: adım 4, 2 resimden 1. Lenovo Thinkpad T450 Internal Battery Replacement, Internal Battery: adım 4, 2 resimden 2.
    • Using the JIS #00 screwdriver, remove the three 2.8 mm screws.
  5. Lenovo Thinkpad T450 Internal Battery Replacement: adım 5, 2 resimden 1. Lenovo Thinkpad T450 Internal Battery Replacement: adım 5, 2 resimden 2.
    • Disconnect the battery cable from the motherboard using the plastic opening tool.
  6. Lenovo Thinkpad T450 Internal Battery Replacement: adım 6, 1 resimden 1.
    • Lift up and remove the battery from the device.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 farklı kişi bu kılavuzu tamamladı.
Justin Ogihara
27.236 İtibar
52 adet Kılavuz yazıldı
Ekip
EDU Team EDU Team üyesi
Staff
7 Üyeler
637 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 36
Son 30 gün: 161
Her zaman: 4,389
