Ana içeriğe geç
Logitech MX Master 3 Battery Replacement
Adam O'Camb
Adam O'Camb ve 4 diğer katkıda bulunanlar
En son January 24, 2025 tarihinde güncellendi
30 - 45 dakika
Orta
Öne Çıkan Kılavuzlar
Use this guide to replace the battery in your Logitech MX Master 3 mouse.
Lithium-ion batteries have a limited lifespan. If your mouse dies quickly, it may be time to replace the battery.
If possible, follow this guide after your battery has fallen below 25% charge. While your MX Master 3 has a relatively small battery, any charged battery is a potential safety hazard if accidentally bent or punctured.
Neye ihtiyacın var
Tamir Seti
Bu kit, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Logitech MX Master 3 Battery Replacement, Soften the mouse feet adhesive: adım 1, 3 resimden 1. Logitech MX Master 3 Battery Replacement, Soften the mouse feet adhesive: adım 1, 3 resimden 2. Logitech MX Master 3 Battery Replacement, Soften the mouse feet adhesive: adım 1, 3 resimden 3.
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to each of the mouse feet for about one minute each.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
    • The information sticker adhesive may soften during this step, but you don't need to remove it.
  2. Logitech MX Master 3 Battery Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 1. Logitech MX Master 3 Battery Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 2. Logitech MX Master 3 Battery Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 3.
    • Slide an opening pick under an edge of the left mouse foot.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Peel up and remove the left mouse foot.
  3. Logitech MX Master 3 Battery Replacement, Remove the right and rear mouse feet: adım 3, 2 resimden 1. Logitech MX Master 3 Battery Replacement, Remove the right and rear mouse feet: adım 3, 2 resimden 2.
    • Repeat the previous two steps to remove the right and the rear mouse feet.
  4. Logitech MX Master 3 Battery Replacement, Reassembly information: adım 4, 3 resimden 1. Logitech MX Master 3 Battery Replacement, Reassembly information: adım 4, 3 resimden 2. Logitech MX Master 3 Battery Replacement, Reassembly information: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • For installing new mouse feet or reusing your old ones:
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
  5. Logitech MX Master 3 Battery Replacement, Remove the case screws: adım 5, 1 resimden 1.
    • Use a Phillips screwdriver to remove the five 4.3 mm-long screws securing the lower half of the lower case.
    • Use a T5 Torx driver to remove the one 4.2 mm‑long screw securing the upper half of the lower case.
    The phillips screw at the bottom centre in the image above is recessed quite deeply in the case. Some screwdrivers with replaceable bits don't reach in far enough to engage with the screw. It is also very difficult to relocate the screw when reassembling. I left this screw out, but nothing feels like it is loose.
    Tom - Yanıt
  6. Logitech MX Master 3 Battery Replacement, Release the left clips: adım 6, 3 resimden 1. Logitech MX Master 3 Battery Replacement, Release the left clips: adım 6, 3 resimden 2. Logitech MX Master 3 Battery Replacement, Release the left clips: adım 6, 3 resimden 3.
    • Insert your opening pick into the seam between the thumb rest and the lower case.
    • Slide your pick right, towards the rear of the upper shell and pry upward to release the left clips.
  7. Logitech MX Master 3 Battery Replacement, Release the right clips: adım 7, 2 resimden 1. Logitech MX Master 3 Battery Replacement, Release the right clips: adım 7, 2 resimden 2.
    • Gently pry the upper shell and lower case apart to release the clips on the right side of the mouse.
    • Don't try to fully remove the top shell just yet—another clip and a delicate cable connect the upper shell to the lower case.
  8. Logitech MX Master 3 Battery Replacement, Release the final clip: adım 8, 3 resimden 1. Logitech MX Master 3 Battery Replacement, Release the final clip: adım 8, 3 resimden 2. Logitech MX Master 3 Battery Replacement, Release the final clip: adım 8, 3 resimden 3.
    • Lay your mouse down onto your work surface, making sure none of the clips re-engage.
    • Grasp the upper shell and partially lift up the right edge.
    • Pull the upper shell up and back to release the final clip and separate the upper shell from the lower case.
    • Still keep the two halves close together—a cable is still tethered to the upper shell.
    • To reinstall the upper shell, slide the front edge into place first, then press down around the perimeter of the upper shell to engage the remaining clips.
  9. Logitech MX Master 3 Battery Replacement, Disconnect the interconnect cable: adım 9, 3 resimden 1. Logitech MX Master 3 Battery Replacement, Disconnect the interconnect cable: adım 9, 3 resimden 2. Logitech MX Master 3 Battery Replacement, Disconnect the interconnect cable: adım 9, 3 resimden 3.
    • Be careful not to strain the cable connecting the upper shell to the lower case.
    • Use the flat end of a spudger to gently lift up the black sliding lock on the interconnect cable socket.
    • Slide the cable straight out of its socket on the motherboard.
    • During reassembly, insert the cable into the socket with its blue tab facing out, then push down the sliding lock to secure the cable.
    Hola. He roto el bloqueo deslizante. No encuentro ningún sitio donde lo vendan. ¿Alguien puede ayudarme? Gracias
    Pedro S. - Yanıt
    I would consider steps 9 & 10 optional at least for the MX Master 3. It is trivial to turn the top half over next to the base and remove the battery/battery tray without removing this cable. Taking this cable out and replacing it is likely to be the hardest part of this guide and most likely to cause damage.
    John Oster - Yanıt
  10. Logitech MX Master 3 Battery Replacement, Remove the top half of the mouse: adım 10, 1 resimden 1.
    • Remove the upper shell from the lower case.
  11. Logitech MX Master 3 Battery Replacement, Disconnect the battery: adım 11, 3 resimden 1. Logitech MX Master 3 Battery Replacement, Disconnect the battery: adım 11, 3 resimden 2. Logitech MX Master 3 Battery Replacement, Disconnect the battery: adım 11, 3 resimden 3.
    • Use a pair of tweezers to grip the top of the battery connector.
    • Always pull cables by their connectors and not the wires themselves.
    • Gently rock the connector side to side and pull it out of its socket.
    • The connector is held tightly within its socket. If it feels stuck, try a different grip—use the protrusions around the neck of the connector if you need more leverage.
  12. Logitech MX Master 3 Battery Replacement, Unscrew the battery housing: adım 12, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 3.5 mm-long screws securing the battery housing.
  13. Logitech MX Master 3 Battery Replacement, Remove the battery housing: adım 13, 1 resimden 1.
    • Remove the battery housing.
  14. Logitech MX Master 3 Battery Replacement, Soften the battery adhesive: adım 14, 1 resimden 1.
    • The battery is secured within its housing by some light adhesive.
    • Flip the battery housing over so the battery is facing down.
    • Apply a heated iOpener to the battery housing for about 2 minutes to soften the battery adhesive.
  15. Logitech MX Master 3 Battery Replacement, Separate the battery adhesive: adım 15, 2 resimden 1. Logitech MX Master 3 Battery Replacement, Separate the battery adhesive: adım 15, 2 resimden 2.
    • Insert the long edge of an opening pick between the battery and its housing at the side opposite the battery cable.
    • Push the opening pick under the battery and lift up to pry the battery out of its housing.
    • Make sure you push underneath the battery and not into it. Don't bend, crease, deform, poke, or puncture the battery—a damaged battery is a potential fire hazard.
    • If you encounter significant resistance, pause and reheat the adhesive.
  16. Logitech MX Master 3 Battery Replacement, Remove the battery: adım 16, 2 resimden 1. Logitech MX Master 3 Battery Replacement, Remove the battery: adım 16, 2 resimden 2.
    Tesa 61395 Tape
    $5.99
    • Remove the battery.
    • To install a new battery:
    • Use a spudger or your fingers to peel any old adhesive off of the battery housing. The old adhesive shouldn't leave any residue.
    • If your new battery doesn't come with preinstalled adhesive, place a couple strips of double-sided tape into the battery housing.
    • Orient your new battery so its cables route through the cutout in the corner of the housing. Press the battery firmly into place to secure it.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
12 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
210.627 İtibar
416 adet Kılavuz yazıldı
4Kılavuz Yorumları
Pretty straight forward manual. Is there also a manual or spare parts available for the scroll wheel and/or its parts?
Kaspars Lubins - Yanıt
Hi! any clue of where to buy the replacement battery?
Fabian Torres - Yanıt
On Amazon or AliExpress. Google for 652535
Дмитрий Притупов -
For the step (step 10) to remove the ribbon cable to separate the top half from the bottom, you are better served keeping it together but being careful not to damage the cable. The cable retaining clip and connector housing are delicate and can break trying to release the clip. And it's difficult to put back on.
Emmanuel L - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 28
Son 7 gün: 206
Son 30 gün: 924
Her zaman: 35,015
