Ana içeriğe geç
Logitech MX Master 3S Battery Replacement
Clay Eickemeyer
Clay Eickemeyer ve 4 diğer katkıda bulunanlar
En son January 24, 2025 tarihinde güncellendi
30 - 45 dakika
Orta
Öne Çıkan Kılavuzlar
Use this guide to replace the battery in your Logitech MX Master 3S mouse.
Lithium-ion batteries have a limited lifespan. If your mouse dies quickly, it may be time to replace the battery.
If possible, follow this guide after your battery has fallen below 25% charge. While your MX Master 3S has a relatively small battery, any charged battery is a potential safety hazard if accidentally bent or punctured.
Neye ihtiyacın var
Tamir Seti
Bu kit, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Logitech MX Master 3S Battery Replacement, Soften the mouse feet adhesive: adım 1, 3 resimden 1. Logitech MX Master 3S Battery Replacement, Soften the mouse feet adhesive: adım 1, 3 resimden 2. Logitech MX Master 3S Battery Replacement, Soften the mouse feet adhesive: adım 1, 3 resimden 3.
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to each of the mouse feet for about one minute each.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
    • The information sticker adhesive may soften during this step, but you don't need to remove it.
  2. Logitech MX Master 3S Battery Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 1. Logitech MX Master 3S Battery Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 2. Logitech MX Master 3S Battery Replacement, Separate the mouse foot adhesive: adım 2, 3 resimden 3.
    • Slide an opening pick under an edge of the left mouse foot.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Peel up and remove the left mouse foot.
  3. Logitech MX Master 3S Battery Replacement, Remove the remaining feet: adım 3, 3 resimden 1. Logitech MX Master 3S Battery Replacement, Remove the remaining feet: adım 3, 3 resimden 2. Logitech MX Master 3S Battery Replacement, Remove the remaining feet: adım 3, 3 resimden 3.
    • Repeat the previous two steps for the three remaining feet.
    • The front foot doesn't cover any screws—if you're only removing the mouse feet to open up the mouse, you don't need to remove this foot.
  4. Logitech MX Master 3S Battery Replacement, Reassembly information: adım 4, 3 resimden 1. Logitech MX Master 3S Battery Replacement, Reassembly information: adım 4, 3 resimden 2. Logitech MX Master 3S Battery Replacement, Reassembly information: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • For installing new mouse feet or reusing your old ones:
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
    Why are we removing leftover adhesive if we went to the trouble of heating for full removal (and reuse)?
    This makes no sense. Might as well just rip em off!
    craigalanelliott - Yanıt
  5. Logitech MX Master 3S Battery Replacement, Unfasten the lower case: adım 5, 1 resimden 1.
    • Use a Phillips screwdriver to remove the five 4.3 mm‑long screws securing the bottom half of the lower case.
    • Use a T5 Torx driver to remove the one 4.2 mm‑long screw securing the top half of the lower case.
    El texto del segundo paso está mal. Se repite con el primero.
    Manuel Sánchez - Yanıt
    Whats the circumference of the screws? You just talk about the length.
    phonc - Yanıt
  6. Logitech MX Master 3S Battery Replacement, Release the left clips: adım 6, 3 resimden 1. Logitech MX Master 3S Battery Replacement, Release the left clips: adım 6, 3 resimden 2. Logitech MX Master 3S Battery Replacement, Release the left clips: adım 6, 3 resimden 3.
    • Insert your opening pick into the seam between the thumb rest and the lower case.
    • Slide your pick right, towards the rear of the upper shell and pry upward to release the left clips.
  7. Logitech MX Master 3S Battery Replacement, Release the right clips: adım 7, 2 resimden 1. Logitech MX Master 3S Battery Replacement, Release the right clips: adım 7, 2 resimden 2.
    • Gently pry the upper shell and lower case apart to release the clips on the right side of the mouse.
    • Don't try to fully remove the top shell just yet—another clip and a delicate cable connect the upper shell to the lower case.
  8. Logitech MX Master 3S Battery Replacement, Release the final clip: adım 8, 3 resimden 1. Logitech MX Master 3S Battery Replacement, Release the final clip: adım 8, 3 resimden 2. Logitech MX Master 3S Battery Replacement, Release the final clip: adım 8, 3 resimden 3.
    • Lay your mouse down onto your work surface, making sure none of the clips re-engage.
    • Grasp the upper shell and partially lift up the right edge.
    • Pull the upper shell up and back to release the final clip and separate the upper shell from the lower case.
    • Still keep the two halves close together—a cable is still tethered to the upper shell.
    • To reinstall the upper shell, slide the front edge into place first, then press down around the perimeter of the upper shell to engage the remaining clips.
  9. Logitech MX Master 3S Battery Replacement, Reposition the upper shell: adım 9, 3 resimden 1. Logitech MX Master 3S Battery Replacement, Reposition the upper shell: adım 9, 3 resimden 2. Logitech MX Master 3S Battery Replacement, Reposition the upper shell: adım 9, 3 resimden 3.
    • Be careful not to strain the cable connecting the upper shell to the lower case.
    • Lift the upper shell away from the lower case and lay it to the right of the mouse.
  10. Logitech MX Master 3S Battery Replacement, Disconnect the interconnect cable: adım 10, 3 resimden 1. Logitech MX Master 3S Battery Replacement, Disconnect the interconnect cable: adım 10, 3 resimden 2. Logitech MX Master 3S Battery Replacement, Disconnect the interconnect cable: adım 10, 3 resimden 3.
    • Use the flat end of a spudger to gently lift up the sliding lock on the interconnect cable socket.
    • Slide the cable straight out of its socket on the motherboard.
    • During reassembly, insert the cable into the socket with its blue tab facing out, then push down the sliding lock to secure the cable.
    How many pins of the cable?
    Harid Wongpanitlert - Yanıt
    The lock broke trying to reinsert the ribbon cable. Be careful.
    Garrett Vogele - Yanıt
  11. Logitech MX Master 3S Battery Replacement, Remove the upper shell: adım 11, 1 resimden 1.
    • Remove the upper shell from the lower case.
    Dear Logitech, please support the upper Shell as replacement Part (without doughter-boards)
    FusterCluck - Yanıt
  12. Logitech MX Master 3S Battery Replacement, Disconnect the battery: adım 12, 3 resimden 1. Logitech MX Master 3S Battery Replacement, Disconnect the battery: adım 12, 3 resimden 2. Logitech MX Master 3S Battery Replacement, Disconnect the battery: adım 12, 3 resimden 3.
    • Use a pair of tweezers to grip the top of the battery connector.
    • Always pull cables by their connectors and not the wires themselves.
    • Gently rock the connector side to side and pull it out of its socket.
    • The connector is held tightly within its socket. If it feels stuck, try a different grip—use the protrusions around the neck of the connector if you need more leverage.
    • If the connector won't budge, skip to the next step for an alternate method.
  13. Logitech MX Master 3S Battery Replacement, Disconnect the battery with tweezers: adım 13, 3 resimden 1. Logitech MX Master 3S Battery Replacement, Disconnect the battery with tweezers: adım 13, 3 resimden 2. Logitech MX Master 3S Battery Replacement, Disconnect the battery with tweezers: adım 13, 3 resimden 3.
    • If your battery connector still feels stuck:
    • Insert each arm of a pair of pointed tweezers into the cutouts on the side of the battery connector's motherboard socket.
    • Push the connector up, just enough to grip the top of the connector with another pair of tweezers or your fingers.
    • Pull the battery connector completely out of its socket to disconnect it.
    It is not this easy
  14. Logitech MX Master 3S Battery Replacement, Unfasten the battery housing: adım 14, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 3.5 mm-long screws securing the battery housing.
  15. Logitech MX Master 3S Battery Replacement, Remove the battery housing: adım 15, 2 resimden 1. Logitech MX Master 3S Battery Replacement, Remove the battery housing: adım 15, 2 resimden 2.
    • Remove the battery housing from the lower case.
  16. Logitech MX Master 3S Battery Replacement, Soften the battery adhesive: adım 16, 2 resimden 1. Logitech MX Master 3S Battery Replacement, Soften the battery adhesive: adım 16, 2 resimden 2.
    • The battery is secured within its housing by some light adhesive.
    • Flip the battery housing over so the battery is facing down.
    • Apply a heated iOpener to the battery housing for about 2 minutes to soften the battery adhesive.
  17. Logitech MX Master 3S Battery Replacement, Separate the battery adhesive: adım 17, 3 resimden 1. Logitech MX Master 3S Battery Replacement, Separate the battery adhesive: adım 17, 3 resimden 2. Logitech MX Master 3S Battery Replacement, Separate the battery adhesive: adım 17, 3 resimden 3.
    • Insert the long edge of an opening pick between the battery and its housing at the side opposite the battery cable.
    • Push the opening pick under the battery and lift up to pry the battery out of its housing.
    • Make sure you push underneath the battery and not into it. Don't bend, crease, deform, poke, or puncture the battery—a damaged battery is a potential fire hazard.
    • If you encounter significant resistance, pause and reheat the adhesive.
  18. Logitech MX Master 3S Battery Replacement, Remove the battery: adım 18, 3 resimden 1. Logitech MX Master 3S Battery Replacement, Remove the battery: adım 18, 3 resimden 2. Logitech MX Master 3S Battery Replacement, Remove the battery: adım 18, 3 resimden 3.
    Tesa 61395 Tape
    $5.99
    • Remove the battery.
    • To install a new battery:
    • Use a spudger or your fingers to peel any old adhesive off of the battery housing. The old adhesive shouldn't leave any residue.
    • If your new battery doesn't come with preinstalled adhesive, place a couple strips of double-sided tape into the battery housing.
    • Orient your new battery so its cables route through the cutout in the corner of the housing. Press the battery firmly into place to secure it.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
5 farklı kişi bu kılavuzu tamamladı.
Clay Eickemeyer
82.950 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.675 adet Kılavuz yazıldı
5Kılavuz Yorumları
Sounds easier than it is. Broke the mouse and couldn't get it back together. The ribbon cable locks are super flimsy and getting the top back on is nearly impossible and there is no direction for that. I have built keyboards and things, but this is in another league.
Much easier to order another on Amazon and return the old one in its place. It s*cks... but if you charge $100 for a mouse and it breaks within a year, it should be on the company, not the consumer.
D B Cooper - Yanıt
isn't the screwdriver too short to reach the recessed screw in the bottom?
Sean Smith - Yanıt
Commenting to confirm, this repair can be done. Be careful around the ribbon cable step, don't tug the two halves, try to ease it off. My cable came loose, but the cable lock was intact, so I was safe to reconnect the cable. When putting the two halves back together, it takes more pressure than I was comfortable using to get the last pin. Start with the weird 'U' section of the mouse, then work your way around the back and thumb-side of the mouse. The final pin for me was the front underneath the left/right click at the front of the mouse. If you are certain it's the last pin, put pressure to close the mouse. My mouse is fine, I hope yours will be too. You're experience may vary. Oh and the provided screwdriver was able to reach the recessed screw with a few millimeters to spare. They provided a long Philips bit. You're average Philips bit, will not reach. They provided a 1.125 inch bit or in metric, around 2.857 cm. 'Bit' doesn't include or account for the shape of screwdriver or the screwdriver's insert.
Malik W - Yanıt
Great guide! I was able to fix my mouse without any major issues thanks to this guide.
TOWOHA - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 45
Son 7 gün: 306
Son 30 gün: 1,512
Her zaman: 26,806
