Ana içeriğe geç
Logitech MX Vertical Battery Replacement
Neye ihtiyacın var
  1. Logitech MX Vertical Battery Replacement, Turn off the mouse: adım 1, 1 resimden 1.
    • Before you begin, flip the mouse's power switch down into the OFF position.
    • Unplug all cables from the mouse.
  2. Logitech MX Vertical Battery Replacement, Lay the mouse buttons-side down: adım 2, 1 resimden 1.
    • The mouse's unique shape prevents it from laying flat. If you need to, lay it down on a soft towel to prevent wobble.
  3. Logitech MX Vertical Battery Replacement, Heat the feet adhesive: adım 3, 2 resimden 1. Logitech MX Vertical Battery Replacement, Heat the feet adhesive: adım 3, 2 resimden 2.
    • If you're planning to reuse your existing mouse feet, the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the feet on the mouse's underside for two minutes.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you might warp the plastic shell.
  4. Logitech MX Vertical Battery Replacement, Remove the mouse feet: adım 4, 3 resimden 1. Logitech MX Vertical Battery Replacement, Remove the mouse feet: adım 4, 3 resimden 2. Logitech MX Vertical Battery Replacement, Remove the mouse feet: adım 4, 3 resimden 3.
    • Insert one arm of a pair of angled tweezers underneath the end of one foot.
    • Grip the foot and begin to peel it away from the bottom of the mouse.
    • Peel slowly, making sure the foot and its adhesive are removed in one piece.
    • The foot should come away from the mouse without the need for much force. If it feels stuck, apply more heat and try again.
  5. Logitech MX Vertical Battery Replacement: adım 5, 3 resimden 1. Logitech MX Vertical Battery Replacement: adım 5, 3 resimden 2. Logitech MX Vertical Battery Replacement: adım 5, 3 resimden 3.
    • Use the tweezers to peel the foot away from the mouse to completely remove it.
    • If you're reusing the foot, place it adhesive-side up on a clean surface.
  6. Logitech MX Vertical Battery Replacement: adım 6, 3 resimden 1. Logitech MX Vertical Battery Replacement: adım 6, 3 resimden 2. Logitech MX Vertical Battery Replacement: adım 6, 3 resimden 3.
    • Repeat the process to remove the other foot.
    • To install a new foot:
    • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
    • Remove the feet from their backing and firmly press them into place.
  7. Logitech MX Vertical Battery Replacement, Remove the case screws: adım 7, 2 resimden 1. Logitech MX Vertical Battery Replacement, Remove the case screws: adım 7, 2 resimden 2.
    • Use a Phillips screwdriver to remove the five 6.5 mm‑long recessed screws securing the two halves of the mouse casing together.
  8. Logitech MX Vertical Battery Replacement, Separate the two halves: adım 8, 3 resimden 1. Logitech MX Vertical Battery Replacement, Separate the two halves: adım 8, 3 resimden 2. Logitech MX Vertical Battery Replacement, Separate the two halves: adım 8, 3 resimden 3.
    • Don't try to completely remove the upper half, as the halves are connected with a fragile ribbon cable.
    • Lift the top half of the mouse away from the bottom half.
    • Lay the top half of the mouse—buttons down—onto your work surface, just to the right of the bottom half.
    • Take care to not strain the ribbon cable connecting the two halves.
  9. Logitech MX Vertical Battery Replacement, Disconnect the battery: adım 9, 2 resimden 1. Logitech MX Vertical Battery Replacement, Disconnect the battery: adım 9, 2 resimden 2.
    • Use a pair of tweezers to firmly grip the battery connector.
    • Hold the tweezers with your fingers as close to the connector as possible to get a firm grip.
    • Gently rock the connector side‑to‑side and pull it straight up and out of the socket.
  10. Logitech MX Vertical Battery Replacement, Remove the battery: adım 10, 2 resimden 1. Logitech MX Vertical Battery Replacement, Remove the battery: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    Tesa 61395 Tape
    $2.99
    • Peel the battery away from its shelf.
    • The battery is secured with some light adhesive.
    • Remove the battery.
    • During reassembly:
    • Never install a deformed or damaged battery, as doing so is a potential safety hazard. Replace it with a new battery.
    • If the battery adhesive is still sticky, you can reuse it. Otherwise, use high-concentration (>90%) isopropyl alcohol and a microfiber or lint-free cloth to remove all the old battery adhesive.
    • If your new battery has adhesive pre-installed, remove the plastic liner to expose the adhesive. Otherwise, apply strips of thin, double-sided tape to the battery well (not directly to the battery) where the old adhesive was.
    • Make sure the cable is on the side nearest its connector and firmly press the battery into place.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
9 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
157.854 İtibar
439 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.992 adet Kılavuz yazıldı
13Kılavuz Yorumları
¡Excelente guia! ¡Parece haber sido hecha por el fabricante! ¡Muchas gracias!
Erick Caliz Morales - Yanıt
Where can I purchase a known good new battery (OEM preferred)?
Frank - Yanıt
Is it actually important to replace with the same mAh value?
Or can I go with something bigger as long as the voltage is 3.7V, the connector is the same and the battery actually fits inside the mouse?
Gunnar Arneby - Yanıt
Looking for the same info as the other commenters, where can I find the replacement battery for sale and are the other ones you sell for similar logitech models good enough to replace for this one?
Dylan - Yanıt
You can find the replacment battery here: https://www.cutratebatteries.com
Just search AHB521630PJT-04
You're welcome!
Kilowatt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 159
Son 30 gün: 622
Her zaman: 31,680
