Ana içeriğe geç
MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement
Neye ihtiyacın var
    1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement, Remove the lower case: adım 1, 1 resimden 1.
      Bu adımda kullanılan alet:
      Magnetic Project Mat
      $19.95
      • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
      • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
      • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
      • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
      • Two 6.8 mm screws
      • Two 5.3 mm screws
      • Two 3.4 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 2, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 2, 2 resimden 2.
      • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
      • Lift the suction handle to create a slight separation between the lower case and the chassis.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 3, 3 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 3, 3 resimden 2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 3, 3 resimden 3.
      • Insert one corner of an opening pick into the space between the lower case and the chassis.
      • Slide the opening pick around the nearest corner and halfway up the side of the case.
      • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
      FixBot'a Sor
      Yorum Ekle
    4. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 4, 3 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 4, 3 resimden 2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 4, 3 resimden 3.
      • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
      FixBot'a Sor
      Yorum Ekle
    5. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 5, 3 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 5, 3 resimden 2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 5, 3 resimden 3.
      • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
      • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
      • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
      FixBot'a Sor
      Yorum Ekle
    6. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 6, 3 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 6, 3 resimden 2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 6, 3 resimden 3.
      • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
      • It may help to pull first at one corner, then the other.
      • Pull to the side—not up.
      • This may require a lot of force.
      • The edges of the case can be sharp, so grip the sides carefully.
      FixBot'a Sor
      Yorum Ekle
    7. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 7, 1 resimden 1.
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
      • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement, Disconnect the battery: adım 8, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement, Disconnect the battery: adım 8, 2 resimden 2.
      • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
      • Remove the tape.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 9, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 9, 2 resimden 2.
      • Gently peel back the small piece of tape covering the battery board data cable connector.
      • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 10, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 10, 2 resimden 2.
      • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
      • Locking tabs on ZIF connectors are fragile, so be gentle when using the tip of the spudger.
      FixBot'a Sor
      Yorum Ekle
    4. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 11, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 11, 2 resimden 2.
      • Disconnect the battery board data cable by sliding it out from its socket.
      • Slide parallel to the logic board, in the direction of the cable.
      FixBot'a Sor
      Yorum Ekle
    5. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 12, 1 resimden 1.
      • Fold the battery board data cable back and out of the way.
      • If you're replacing your battery, you may need to completely remove and transfer this cable to your new battery. Disconnect both ends and carefully remove the cable. During installation, be careful not to install it upside-down or backwards—note the orientation in the photos.
      FixBot'a Sor
      Yorum Ekle
    6. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 13, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 13, 2 resimden 2.
      • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
      FixBot'a Sor
      Yorum Ekle
    7. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 14, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 14, 2 resimden 2.
      • Use a spudger to gently lift the battery power connector, disconnecting the battery.
      • Lift the connector high enough so that it stays separated from its socket.
      • If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement, Remove the antenna cable assembly: adım 15, 1 resimden 1.
      • Remove the four 3.3 mm T3 Torx screws securing the plastic covers on top of the display hinges.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 16, 3 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 16, 3 resimden 2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 16, 3 resimden 3.
      • Remove both plastic hinge covers.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 17, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 17, 2 resimden 2.
      • Remove the two 3.1 mm T3 Torx screws securing the aluminum cover on top of the main display cable.
      • Remove the cover.
      FixBot'a Sor
      Yorum Ekle
    4. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 18, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 18, 2 resimden 2.
      • Remove the two 1.7 mm T3 Torx screws securing the aluminum cover on top of the display cable flex connector.
      • Remove the cover.
      FixBot'a Sor
      Yorum Ekle
    5. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 19, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 19, 2 resimden 2.
      • Pry the display board flex cable straight up from its socket to disconnect it from the display board.
      FixBot'a Sor
      Yorum Ekle
    6. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 20, 3 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 20, 3 resimden 2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 20, 3 resimden 3.
      • Remove the four 1.5 mm T3 Torx screws securing the two aluminum covers on top of the two display cable connectors.
      • Use a pair of tweezers to remove the two aluminum covers.
      FixBot'a Sor
      Yorum Ekle
    7. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 21, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 21, 2 resimden 2.
      • Remove the four 3.3 mm T5 Torx screws (two on each side) which secure the antenna cable assembly.
      • Also remove the twelve 1.1 mm P2 pentalobe screws (six on each side).
      • These small screws can strip easily, so make sure your P2 pentalobe driver is in good condition before applying pressure.
      FixBot'a Sor
      Yorum Ekle
    8. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 22, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 22, 2 resimden 2.
      • Use a pair of tweezers to remove the plastic antenna cable cover.
      • This cover is secured with some light adhesive.
      FixBot'a Sor
      Yorum Ekle
    9. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 23, 3 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 23, 3 resimden 2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 23, 3 resimden 3.
      • Carefully disconnect the two antenna coax cables by prying them straight up from the logic board.
      • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
      FixBot'a Sor
      Yorum Ekle
    10. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 24, 3 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 24, 3 resimden 2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 24, 3 resimden 3.
      • To reconnect each antenna cable, use tweezers to align the connector directly over its socket, and then press down with a spudger so it snaps into place.
      FixBot'a Sor
      Yorum Ekle
    11. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 25, 1 resimden 1.
      • Remove the 3.7 mm T5 Torx screw securing the two antenna coax cables to the main board.
      FixBot'a Sor
      Yorum Ekle
    12. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 26, 3 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 26, 3 resimden 2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 26, 3 resimden 3.
      • Use an opening pick to lever out the antenna cable assembly in the areas shown.
      • Don't slide the opening pick from side to side, because there are two display cables that can be damaged.
      FixBot'a Sor
      Yorum Ekle
    13. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 27, 3 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 27, 3 resimden 2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 27, 3 resimden 3.
      • Carefully remove the antenna assembly while simultaneously feeding the antenna cable bundle out from underneath the heat pipe.
      • Remove the antenna cable assembly.
      • During reassembly, gently pinch the cable bundle together and guide it under the heat pipe into the correct position on the board. If needed, use your tools to help guide it through, but don't force it.
      FixBot'a Sor
      Yorum Ekle
    1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement, Remove the display assembly: adım 28, 1 resimden 1.
      • Remove the four 3.9 mm T3 Torx screws securing the spring hinges of the two display cables.
      FixBot'a Sor
      Yorum Ekle
    2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 29, 3 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 29, 3 resimden 2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 29, 3 resimden 3.
      • Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the spring hinge.
      • Use a pair of tweezers to pull the spring hinge of the display cable out of its bracket.
      • Repeat this step with the right spring hinge of the display cable assembly.
      FixBot'a Sor
      Yorum Ekle
    3. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 30, 2 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 30, 2 resimden 2.
      • Fully open the screen and stand your MacBook Pro up on one side.
      • While steadying the MacBook pro with your free hand, remove the three T8 Torx screws from the lower display hinge.
      • Remove the remaining three T8 Torx screws from the upper display bracket.
      FixBot'a Sor
      Yorum Ekle
    4. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 31, 3 resimden 1. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 31, 3 resimden 2. MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement: adım 31, 3 resimden 3.
      • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
      • Push both halves of the MacBook Pro together so that the hinge brackets can be lifted clear of their recesses in the chassis.
      • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
      • Remove the display/screen assembly, being careful not to snag it on any cables.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
33 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
168.252 İtibar
438 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
53.964 adet Kılavuz yazıldı
8Kılavuz Yorumları
I’ve followed all these steps but the screen doesn’t power up and the backlight on the keyboard stays off. It just seems to be infinitely rebooting itself. Any ideas what might be wrong?
buttifli - Yanıt Paylaş
You have to connect it to original charger and it should power right up
Mr Telephone Man - Yanıt Paylaş
I followed this guide and successfully and happily repaired my MacBook Pro. Thank you Carsten and iFixit! I will add that you need to be very careful and aware of your finger placement and/or wear gloves when you separate the lower case from the main body. The inner and outer edges of the case is very sharp and can slice your finger open. Unfortunately, I am speaking from a painful experience. This disclaimer should be added to that portion of the tutorial out of the safety of all DIY professional technicians. This guide is great and helped me complete the job successfully. The finger slice could have been an amateur move but it could honestly happen to anybody. Happy repairing!
Shane Samuelson - Yanıt Paylaş
Does anyone know if the camera will work with an oem replacement? Reading a lot of posts that say it wont without config software
Jono Sidwell - Yanıt Paylaş
Mine works without adding any config software. Followed the guide through and through without any issues or extra configurations. Happy fixing!
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 103
Son 30 gün: 442
Her zaman: 39,608
