Ana içeriğe geç
MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement
Neye ihtiyacın var
  1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
    To remove the back panel there are two different pentalobe screws 2.3mm and 3mm however on the tools list there is only one screwdriver. Will I be able to remove both screws with the same screwdriver?
    lantzero - Yanıt
    The 2.0 and 2.3 mm measurements are screw lengths, the screw heads are the same sized P5 pentalobe heads. We include the screw lengths so you don't put the wrong screws in the wrong places and end up with screw heads poking out of your device. Hope that clears up some confusion =)
    Sam Goldheart -
    Yes the same screwdriver will remove both screws, the difference in screws I believe is the length and width but the head is the same.
    Mike -
    Just be careful to store the 2 shorter screws in a seperate space then the other 3mm screws.
    The first time I opened up my Macbook, I put the screws in the wrong order.
    Shahzad Arif -
    Woohoo, much easier than I thought... Just got confused with the bottom case screw driver but after figure out it was P5 then everything went smooth.... One thing I wanted to upgrade was the wifi to ac and got one on ebay!
    didierma - Yanıt
    If you have 54 Bit Driver kit, please use Star 5 driver to remove screw for rMBP 2012 Late
    iyeori - Yanıt
    It took about 40 minutes due to an extreme measure of caution but I did it! The only real difficulty was reattaching the screen to the base (yes you have to pry the hinges open) and re-connecting the camera wires. After a few tries the camera wires finally came together. I'm hating Apple for all it's frailty and magical screws but I love ifixit!
    floyd - Yanıt
    Simple guide, but it solved my problem. Was wondering why the top two screws weren't going all the way down. Hadn't realized they were 0.7mm shorter.
    Emilio Mejia - Yanıt
    I have BootCamp running Win7 on my MBPwRetina15" 2013'Late. I run Visual Studio to build and run my Company's Application which is very CPU & NVidia (specific) intensive. So much so that during a build & run of app I was averaging about 85~95+Celcius!!! And every so often would reach 100Celcius!!! I could not take it anymore so I decided to delve into and re-apply Thermal Paste on the CPU/GPU. I ended up going with CooLaboratory Liquid Pro instead of the traditonal AS5. The original Thermal Paste was pure garbage,,, part of the CPU seemed like it was missing TP. I was scared to do this but it turned out easier than I had imagined. I am currently building the same application and can already observe that the temps average about 75~85 and once in a while will reach 90Celcius. So I am seeing about a 10~15 degree drop in Temps and that makes me very happy!
    Alvaro Suarez - Yanıt
    Nice to hear that, i was looking for that kind of information. I have a MBPwRetina 15 Mid 2012 and looking to obtain the best performance!
    Jose David Valle -
    Woa! Thanks dude! And you follow some guides here for the thermal paste? My mac 15’’ early 2013 heats up a lot but I’m a bit worried about touching anything
    Bert0ld0 -
    Much easier than expected. Sounds like several people had trouble with the backlight. It is possible that they damaged something by not first making sure to power down the computer completely with the “Shut Down” command. This should be step 1 before removing the back cover screws. Also as noted all the back cover screws are Apple Pentelope #5 bit, but 2 of the screws are shorter than the others. This bit is is hard to find in most stores. Buy it on line along with the Tork #5 and #8. 11/21/2017
    Walt Goede - Yanıt
    Not sure if this has been listed.
    PRO TIPS from a non-pro:
    1 - Keep screws separated and labeled by step # and size.
    2 - Be very careful to get screws in properly threaded, its VERY easy to strip the ccrew holes and screws. Especially the case. Not that it happened to me…
    3 - It was impossible for me to get all the adhesive off the case from under battery, it left a lot on w/o issue (yet).
    4 - Make sure you have Aluminium Foil before starting!
    5 - Upgrade the SSD or HDD while your in there!
    erin - Yanıt
    Do we remove the logic board purely to get the speaker enclosures out and away from the acetone? Or does it physically block getting the batteries out? Ie. if I wanted to risk the damage to the speakers, could I jump straight to step 34?
    Obviously I don’t want to melt the speakers, but I’m kinda weighing that risk against losing a screw or breaking a connector…
    Michael Ferenduros - Yanıt
    So I did take the risk and swapped out the battery without doing the logic-board + speaker removal.
    Before applying the acetone I put tape on the exposed sides of the speaker-enclosures as best I could - I wrapped the tape, sticky side out, around a card, slid it into the gap, and pressed it onto the speakers. And when applying the acetone, I squirted it as gently as possible onto the side of the battery and let it run down the side, which seemed to help avoid getting too much on the speakers.
    The speaker’s plastic turned white in the spots where the acetone touched it, but it looked like surface damage only. Otherwise it was a nice and smooth procedure.
    Your milage may vary, obviously.
    I changed the battery pack as well without removing the logic board etc. It helped, that the batteries already were swollen, thus access to the glue stripes was easier. It works, if you give a little tension, pulling a pack upwards, and then work with a small blade or knife, and cut the glue stripes. It may take a while, but much less time than dismantling the whole macbook. If you don’t hurry, and don’t apply too much force, you will not damage anything. Beside the 10 cover screws you only have to loose 2 screws for the battery connector. After removing the old pack I used Methanol to remove the glue. I prefer this solvent to Acetone, because it’s less or not harmful to plastic (however, no warranty, just my personal experience). I was able to finish the work in 40 minutes, although it was the first time I opened my Macbook. Well, I am an engineer, that helps, but with dismantling all boards it definitely would have taken double the time. And more risks to break a plug or make a mistake while reassembling.
    Heinrich Jung -
    Success. I needed to replace the right speaker. I thought I was ready at step 22 (you are able to replace the left speaker at this point… but but the right) To replace the right I continued thru step 29 but didn’t completely remove the motherboard. I just lifted it enough to remove and replace the right speaker cable.
    Read all of the comments and solved many problems. Thanks to I-fixit, Walter Galen and all who posted comments.
    Will Brecht - 03/02/2019
    Will Brecht - Yanıt
    1/2
    If you're taking the shortcut (nylon, wire…and no adhesive for battery removal (you'll def need to remove the adhesive once the battery pack is removed) things to note:
    1 The adhesive may still be pretty strong. Mine was and I broke several wires trying to do the cheese cutter move down the back of the middle two batteries
    2 if you're cheese cutting through the adhesive, when you get to the base, don't go too far. I did and severed the battery cell connector… disconcerting puff of smoke.
    Ruairi Kennedy - Yanıt
    If you get a puff of smoke removing a bad battery which is going to be replaced it really doesn’t matter, its being replaced.
    robert -
    2/2
    3 the you tube video dude was lucky not to have his two Central batteries adhered . Mine were stuck fast.
    4 don't forget about the two small T 5 screws to the left and right of the battery head board, just below the main battery connector.
    5 the Track Pad sits behind the two central batteries. The batteries are adhered to a flat plate that protects the Track Pad which is pretty resilient. You can do the cheese wire trick without cutting through anything you shouldn't. However be careful if you're using a spudger or other tool between the two centre batteries at the top of the T. This is where the Track Pad connector (its very flat and exposed) to the motherboard.
    6 seems obvious when it's written , but you will need the adhesive remover if you are interested in removing the adhesive. It's a work out.
    I just completed this successfully. The guide was great, and I recommend reading each of the steps’ comments, too. It is possible to cut out a majority of the steps outlined here if you’d rather not dismantle most of your laptop. As I’m a novice and this was the first difficult fix I’d ever tried, the idea of taking so many things apart — including removing the logic board — was a little scary. Everyone calculates risk and reward differently, but for me, the risk of removing the logic board for the reward of being able to remove the battery packs with adhesive remover was too great, so I opted to only do steps 1–4, 42–53 and removed the battery with one of the cards from iFixit’s kit. If you go this route, expect it to be a little frustrating & slow going — it took me around 20–30 minutes of slowly chipping away at the adhesive with only the card. There are other techniques out there (wire, fishing line, etc.) and I’d advise looking into them. Keep track of screws: tape, draw out diagrams, label them, etc.
    Jake Thornberry - Yanıt
    I only removed the 10 screws and the back panel, the 5 speaker’s screws (without removing the speakers), and the two battery screws, and managed to remove the battery package without undoing anything else. I used a member card (credit card type) to loosen the adhesives under the batteries.
    To remove the rest of the glue, I soaked it with something called Label Off from Biltema (Nordic). Finally, I used methylated spirit (rødsprit) to clean it all up and let it dry for 5 minutes before assembling the new battery pack.
    Andreas H. Parlow - Yanıt
    I have now replaced the battery and the dc-in board, and I still can’t get the battery to charge. I also bought a new magsafe power adapter. It appears all cables are connected, and the computer runs fine on the battery (until it runs out of juice, then I will be at a complete loss). No clue what to try next. Any suggestions? Thanks!
    matt rogers - Yanıt
    Why do you need to remove the entire logic board??? Seems like if you detach the appropriate cables, remove the speakers, that that should be enough. Removing the entire board doesn’t seem necessary - what am I missing?
    Sandwah - Yanıt
    What on earth are you talking about? This has nothing to do with the logic board.
    Trevor Picard -
    The speaker cables are routed under the logic board, or at least the right-side one is. I found that if you can undo the fastenings on one side of the logic board you MIGHT be able to lever it up and work the speaker wire out without taking the entire thing out.
    bobthrollop.redirect -
    MacBook Pro 15“ 2014:
    if the keyboard is connected nothing works. I disconnected the keyboard and the MacBook was starting automatically. An external usb keyboard is not working either. Is something on the logic board defective or is this failure (usb keyboard not working) because of the disconnected keyboard and the system is confused?
    any idea for this?
    ps: the battery is loading
    Pättes - Yanıt
    MacBook Pro 15” Mid 2012
    I had the exact same symptom upon initial completion. The keyboard ribbon is actually 2 pieces on mine. There is a plastic cover sheet (that I tried to use as the ribbon the first time) and then there is the actual ribbon sheet. The keyboard works perfectly now that I have the actual ribbon sheet inserted into the the ZIF connector.
    It took entirely too long. I was being very careful. Recovery of the keyboard took me less than an hour. I don’t want to admit how long the original work took me.
    I hope you already have yours working. I was very careful due to not having an alternate device for my son to use if the work had failed. The other likely point of failure for the keyboard is damage to the ribbon as it goes under the battery pack. I caught myself almost poking too hard on that spot.
    EEM -
    You should more clear explain that it is possible to skip the steps 5-35 in the beginning explanation text.
    ( I lost many time to remove parts and there is also more risk to destroy some connectors ?‍♂️)
    Muescha - Yanıt
    Like many others here, I completed the battery replacement by skipping steps 5-52 and instead removing the battery cells with the “cheese cutter” method. I made my cutter from 20# braided monofilament tied to two 4” wooden dowels (3/8” diameter). I carefully applied 97% isopropyl alcohol to the taut mono with a small artist’s brush. I took my sweet time cutting through the glue, but all in all not too difficult, just tedious. I was super careful and mindful of the fire and explosion hazard, and took necessary precautions. One thing to be careful of using the cheese cutter method is to be sure the mono is is really under the cell package and not just in front of it before sawing away. There are some tight spaces that make this tricky. Once the battery was out I used the iFixit acetone to clean up the glue leftover by carefully applying drops on the strips and letting capillary action take over. After waiting about five minutes, the glue strips could be picked up with the supplied tweezers.
    Acme Nerd Games - Yanıt
    Hallo Leute, hab das Akku eben erfolgreich bei meinem MacBook getauscht ohne alles vorher auszubauen. WICHTIG: kein ACETON zum Kleber lösen verwenden! Sonst gehen die Lautsprecher kaputt! Auch kein Orangenpower oder ähnliches! Man nehme sich ein dünnes hochzugfestes Nylonband (oder Zahnseide geht auch) und schneide damit die alten Klebepads sägebandmäßig los.
    Also:
    In der Hoffnung mich so klar wie möglich auszudrücken war das Folgende meine Vorgehensweise:
    1. Deckel ab, Achtung die Schrauben mittig unterm Bildschirm sind kürzer!
    2. Akkustecker trennen und vorsichtig umbiegen
    3. die 2 Schrauben, die die Batterie in der Nähe des Steckers halten losschrauben
    4. nun mit zugfestem Band die Akkus rausschneiden
    die im Fix-Kit beigelegten Spatel können dabei unterstützen
    die übrigbleibenden Klebereste können einfach mit einem der Plastikwerkzeuge abgemacht werden: erst ein bisschen mit einem Spatel vorarbeiten, sodass man es mit seinen Fingen greifen kann, dann langsam und Richtung weg vom Logikboard vorsichtig abziehen.
    Jérôme Achilles - Yanıt
    Was dann noch an Kleberesten übrigbleibt, kann wegen mir auch bleiben. Sonst mit 1-2 Tropfen Lösemittel auf ein Microfasertuch geduldig nach und nach wegwischen. Und Wirklich nur WENIGE TROPFEN verwenden! Sonst gehen die Lautsprecher wohlmöglich kaputt.
    5. Mithilfe von Druckluft (2-3 bar! nur) nun sämtlichen Staub vorsichtig rausblasen. VORSICHT: Die Lüfter dürfen sich dabei nicht drehen! Die erzeugen sonst Spannung und grillen wohlmöglich das Logikboard!
    6. Neues Akku (Folien dabei vom Akku entfernen) reinsetzen und gleich an die Schraubenlöcher ausrichten.
    7. Die 2 Schrauben für die Batterie reinschrauben und mit Gefühl anziehen.
    Die packs einzeln auf ihren richtigen Sitz hin prüfen
    8. Wenn alles sauber ist und alles richtig sitzt, dann den Batteriestecker wieder auf das Logikboard stecken
    9. Deckel drauf. Der Deckel muss von alleine, ohne Schrauben richtig in seiner Ausfräsung liegen. Steht irgendeine Ecke hoch, ist darunter was verkehrt.
    10. Deckel festschrauben. ACHTUNG: 2 Schrauben sind kürzer auf der Seite des Bildschirms!
    Missverständnisse kann ich nicht ausschließen. Darum folgt ihr dieser Anleitung bitte nur auf eigenes Risiko. Ich übernehme keine Haftung für Schäden! Viel Erfolg!
    Hi guys, just successfully replaced the battery on my MacBook without removing everything first. IMPORTANT: do not use ACETON to loosen the glue! Otherwise, the speakers will be broken! Also no orange power or similar! Take a thin high-tensile nylon tape (or dental floss also works) and cut the old adhesive pads loose. Similarly as with a saw tape.
    So:
    Hoping to express myself as clearly as possible, the following was my procedure:
    1. remove the lid, beware that the screws in the center under the screen are shorter!
    2. disconnect the battery connector and carefully bend it over
    3. unscrew the 2 screws that hold the battery near the plug
    4. now cut out the batteries with tension-proof tape
    the spatulas included in the fix-kit can help you to do this
    the remaining glue can be easily removed with one of the plastic tools: first work a little bit with a spatula so that you can grip it with your fingers, then slowly and carefully pull it off in a direction away from the logic board.
    Whatever glue remains can stay because of me. Otherwise, patiently wipe away little by little with 1-2 drops of solvent on a microfiber cloth. And really only use FEW DROPS! Otherwise, the speakers may break.
    Now carefully blow out all dust with compressed air (2-3 bar! only). CAUTION: The fans must not rotate! Otherwise, they will generate voltage and possibly fry the logic board!
    Insert the new battery ( thereby remove the foils from the battery) and align it to the screw holes. 7.
    Screw in the 2 screws for the battery and tighten them with feeling.
    Check the packs individually for proper fit
    8. if everything is clean and everything fits correctly, put the battery connector back on the logic board.
    9. put the lid on. The cover must lie correctly in its groove by itself, without screws. If any corner is sticking up, there is something wrong underneath.
    10. screw the cover. ATTENTION: 2 screws are shorter on the side of the screen!
    I cannot exclude misunderstandings. Therefore, please follow these instructions only at your own risk. I assume no liability for damages! Good luck!
    Another vote for skipping step 34 after step 4. When I tried to reinstall the new battery, I couldn't get the two step 34 screw holes lined up and still be able to connect the battery cable, so I just left them out. Also, one of the bottom cover screws went AWOL.
    I think that anyone with a badly swollen battery can skip to 34 because the battery has already done a lot of the work. I doubt that I used more than a dozen drops of remover, if that. A bit of patience and careful work with dental floss did the trick. Maybe 30-40 minutes to get the old battery out and another 10 to peel off the remaining adhesive.
    schendel - Yanıt
    Like most have suggested here, definitely read through all of these comments! I learned valuable tips from other commenters above that made this repair easy. Also like many others here, I opted to skips the majority of steps, and instead focused on steps 1-4, 36-53. When removing the small screws from the back plate, make sure to keep them organized and away from the computer. Because they are slightly magnetic, one of the tiny top middle screws magnetized to the MagSafe charger port my my Mac and I spent 20 minutes thinking it fell on the floor.
    I had a nylon thread handy to get some of the packs started. Even with applying the adhesive remover, I found the plastic card iFixit provides was not always strong enough to get the pack started. Cheese cutter method was all it needed to get started!
    Make sure to elevate your Mac when applying the remover in whatever direction you want the remover to run. Make sure to test new battery before committing to the new adhesive in case it is faulty!
    Good luck!
    Patrick King - Yanıt
    At step 9, when reinstalling the io board cable, make sure it is the correct way round as in the photo, it fits the wrong way round as well, which results in the MacBook not starting at all. It took me hours to find my mistake...
    Pierre Arnaud - Yanıt
    This is just a suggestion or two to help those that might be doing this for the first time.
    1. Separate your screws by the component they came from, i.e. cover screws altogether, fan screws altogether etc. I used PostIt notes turned upside down and put the screws head down to hold them in place and then marked what they were and where they came from.
    2. If you have enough work space put the component next to the screws that were removed. Then you have everything located for an easy reinstall.
    Steve Rowe - Yanıt
    The photographs in this guide show two slightly different MacBook Pro 15" Retina machines being disassembled, probably because the guide has multiple authors, and there is a subtle but very important difference between them. Look at the photo in Step 55. This shows the old battery being lifted out of the machine, it has six cells, and the battery connector is located in the centre of the top edge of the battery between cells 3 and 4. Now look at the photo in Step 3. This shows a battery connector which is offset by about 3cm and is above cell 4, not between cells 3 and 4. I believe the offset battery connector is from a mid 2012-early 2013 MacBook and the central battery connector is from a late 2013-mid 2014 MacBook. This is important because if you have the wrong battery, it won't work because the connector won't reach the socket. I found this out to my cost when I bought a battery which the seller told me was the right one, it turned out to be the wrong one, and then I couldn't return it.
    Peter Gray - Yanıt
  2. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 2, 1 resimden 1.
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
    Does anyone noticed that the bottom cover and the bottom case is actually linked with the black plastic near the battery?! After the first time you open the cover, it will be impossible to put it back to the original place. Does the critical?! Thanks a lot for informing
    jamiegan835 - Yanıt
    I was able to simply push and click those clips back into place before I did the screwing.
    Tim Peat -
    I truly believe this is placebo and the 10*C difference is because in the process the dust was removed from the fan/heat sink rather then the thermal "magic" paste.
    This is a "PC" habit.
    On the other hand, all the cases and protections out there have a bad effect on cooling (not sleeves or pouches) because the whole aluminum body helps dissipate heat.
    I've never had any problems with any mac regarding heat (they do get hot, but it is OK).
    Whenever you feel heat from electronic device means the heat radiates away from it.. which means the cooling is doing a good job :).
    crus - Yanıt
    Hey,
    Writing about dust and dirt, do you know any cleaning products for the interior of the mac. i mean how do you clean your laptop, pc, etc..
    Regards
    Jose David Valle -
    This is untrue. Over time thermal paste will dry up and crack and not provide good coverage between the device and the cooler. The paste massively improves the thermal transfer between the chip and the heatsink. If you do not believe in the magic paste then you should wipe it all off and apply just a little bit or none at all and then compare temperatures. You will see the paste is responsible for a big reduction in temperature.
    Andrew Fox -
    I was able to remove all screws but lower case is not comming off easly. Is it glued to somthing?
    Thanks for help.
    c4rlosv8 - Yanıt
    There are two clips in the centre which simply unclip with a little force.
    Tim Peat -
    If you are following this how-to because liquid/coffee splashed in through the back vents, WAIT UNTIL THE END to clean any liquid spills on the bottom panel. Use them as your map for cleaning and QA guide for checking until you are finished with your cleanup of logic board and other items.
    auntialias - Yanıt
    There are a couple of small rectangular magnets (~ 1/2” long) that are sitting in pockets near the battery warning label. (One is visible in the Step 3 pic.) One of these left its pocket and was stuck to the bottom cover when I lifted it.
    Jon Scott - Yanıt
    i had no idea my battery was swollen until i opened the back case to replace it. the back popped up right away on its own as soon as i took the screws out.
    elyze - Yanıt
  3. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, Battery Connector: adım 3, 1 resimden 1.
    • Peel back the warning label covering the battery connector.
    For rMBP 2012 Late, you don't need to remove this sticker.
    iyeori - Yanıt
    Have laptop charging issues after this. When fully charged and i plug in magsafe it starts with green, then turns red and stays red (like if it was charging). Status bar says NOT charging. If i use battery a little bit (down to 69%) magsafe does the same (green then stay red). Status bar says battery 69% NOT charging. and it seems to be true. Any suggestions?
    g000phy - Yanıt
    Double check the connection from the battery to the logic board and the logic board socket itself... Might have damaged by disconnect/reconnect.
    max damage -
    This step is necessary to prevent any discharging, arcing, friction/static charges from damaging any of the extremely delicate and intricate parts of this (or most any) electrical system. In practice, you should even be wearing an anti-static band or be working on an anti-static bench even with the battery disconnected so your body doesn't create any unintentional charges.
    One of the first things you should learn in electronics repair and and electrical in general is to cut the power source whenever possible before performing any work. Some systems have schedulers/triggers set that will wake the system up (even when closed) to perform updates and other maintenance tasks as to not eat up CPU and RAM during 'peak hours'. The last thing you need is to have your $2,000 laptop turn on while pulling an SSD (which, correct me if wrong, isn't a plug-and-play based device) which could do some serious corruption and/or damage; when all you had to do was peel a sticker and plug.
    Hope that helps!!
    ~the more you know~
    Colin Devenney - Yanıt
    I did not peel back the sticker. It is probably there to help unplug the battery. You can apply a gentle constant pull while you use spudger to lift the battery connector out of the socket as per the next step. It made this very easy.
    Achilles - Yanıt
    I've found that it's actually better to NOT remove the sticker. I wish I had skipped that 'peel off the sticker part' ugh
    Miles Raymond -
    There is another connector here on mine, just to the left and up above the text on the battery sticker. It is an empty ZIPF socket on all these photos.
    Richard C - Yanıt
    Let me stop you guys here. You can skip steps 5-35.
    That’s what I did without a problem.
    Go directly to step 35 after the next step. 5-35 is only so you have more room to pry the old battery off.
    If you are not keeping the old battery, then just pry it off with a flathead screwdriver.
    This is not a difficult fix.
    Chris - Yanıt
    Chris,
    Thank you for providing the advise to skip several steps. I agree that you will have ample space to remove the old battery without removing everything else. I would like to provide a small correction in your directions. You will need to go to step 34 to remove the two screws holding the battery cable versus directly to step 35. You will not be able to completely remove the battery without this step.
    Laurence Rooks -
    I successfully followed all the instructions and all the steps in this guide. I installed the new battery successfully. However, looking back at the process now, I have no idea why I had to take out the memory, air card, speakers, fans, and motherboard to change the battery. None of that was necessary. I did it, and it worked out for me, but honestly, if you just want the battery out, do what Chris and Laurence said above me. Go straight to step 34.
    matthew.toledo - Yanıt
    Again, that label will loose its stickyness... order B09WMWH3LM from Amazon so you can reglue - a little smear on both parts, let it dry a few seconds and join them. Done. ... a little will go a long way.
    Alex De Lara - Yanıt
    I agree that this entire procedure is unnecessarily complex, unless you’d like to disassemble your entire laptop for the sheer fun of it. The point of all the disassembly is to avoid damage to other components from the adhesive remover. So what I did was not to pry at all, no leverage whatsoever, no strain on the battery cells. Instead, I simply slid the provided plastic scraper cards underneath the batteries from every side possible to begin removing the adhesive. Then I put one drop of the remover on each side of the card at the front edge so it was barely wet, slid it in and worked it deeper bit by bit…. When I got near the speakers, I pulled the screws, lifted them slightly, and wedged one of the picks under the long arm coming off each speaker to give it a few mm clearance from the case, so no remover/alcohol could wick underneath. That worked well for me; the hardest part was getting all the old adhesive off the case, which just took some careful soaking. Good luck! .
    Tor Matson - Yanıt
  4. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 4, 2 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 4, 2 resimden 2.
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    I ordered the whole kit, but seeing how much tedious effort it was to take out so many parts so they wouldn't be damaged by the solvent, I skipped from here to step 34 and only used the supplied cards (credit-card sized) with patience and persistence to free the battery sections from the backing. Success! Then I used a q-tip to apply the solvent to remove the remnants of the adhesive from the aluminum case. My battery was very swollen, so it was like removing little pillows. I think the swelling may have helped to give me additional access with the cards to free it. Success! My MBP is back up and running, and now the trackpad clicks again and it sits flat on a table!
    Joel Replogle - Yanıt
    So no need basically to unscrew all the mac
    Bert0ld0 -
    The best tool for battery removal for any glued in Apple batteries is a 6" PLASTIC puddy knife 1.5" or 1" in width. It is strong. It has a bit of a sharp edge to cut the glue. It is long enough to slide all the way from top to bottom on the middle cells and from the side to get the 2nd from the right and 2nd from the left out. Wear gloves doing this and eye protection. I've use the Nylon twine method also without removing the logic board, but that is a pain to get started. I just take the screws of of the speaker, lift them up, don't remove and go to work with the puddy knife.
    Chapman Gleason -
    Joel - the purpose of all of the trouble in removing the logic board is to make sure that you don’t damage anything when you start pull out the battery. After this step - it’s true, you have about 12 connectors and dozens of screws to unplug, but I didn’t have any major problems.
    REASSEMBLY - I had to use alot of force to get the official IFIXIT battery connect to push into place to actually connect. I was worried that one of the wires would stress and break. It worked, but it was not super easy this part.
    Jer - Yanıt
    I also skipped down to step 50. I stuck a piece of 1/2 inch weather stripping across the middle of the top cover of the laptop to maintain a pitch on the unit so the adhesive remover stayed away from the other components. I applied the remover and used a piece of string to cut through the adhesive strips. I owed the plastic tool from the kit to position the string behind the top of each cell and cut through one ata a time. The battery came out in about 15 minutes. The directions were very informative and useful but I thought the risks associated with dismantling the laptop and reassembling it again were greater. I could not have done it without the details presented. Thank you.
    Thomas Horan - Yanıt
    Couldn't agree more: use a wire to cut the glue. No need to remove anything else (I did remove the SSD for peace of mind). I used a thin metal wire, without the help of adhesive remover, wrapping it around two sticks to hold it (as pulling with your fingers is painful!). Took longer to clean the residue than to cut the glue!
    I'm not so mad with Apple's repairability considering that this method is viable.
    Eric Rannaud -
    Having broken a connector on a logic board in the past, I worried about all the steps. But I understand the disaster that can occur if cleaning fluid contacts the logic board. Weighing costs and benefits, I also did not remove the logic board. I loosened up the speakers (since only two screws could be removed) to give me space to slide the cards under the battery cells. Using the two cards, sometimes sliding one over the other, I was able to remove the battery in 15- 20 minutes. Removing the remaining adhesive was VERY tedious. Eventually I settled on CAREFULLY applying small amounts of remover with the syringe and using the spudger (both pointy and broad ends) to scrape the remainders off. I cleaned the residual with Q-tips dipped in remover (buy a big box of Q-tips), refastened the speakers, installed the new battery, closed the case and voila.
    James Suojanen - Yanıt
    I too found the need to completely teardown the laptop onerous and risky. I’m not certified in anything hardware but I’ve been doing my own repairs for a while. I watched the video referenced above and read the comments there. With some changes, here is what I did, which worked perfectly and minimized the risk, for a whole additional $3 in parts, just myself and in under an hour:
    1. Go to hardware store and get 2 4” bolts ($1 each) and a coil of 20 gauage galvanized wire.
    2. Wrap one end of the wire a few times around one bolt, then tie it off with a knot. Do the same with the other bolt, leaving about 10” of wire between the two.
    3. Follow steps 1-4 in this guide
    4. Slip the wire under one of the outer batteries (use a card or spudger to help get the wire underneath
    5. Grip both bolts with one hand and rock them back and forth, pulling the wire under the battery, using your other hand to hold the case. This should take about 2 seconds (seriously). Repeat for other outer batteries
    (continued)
    steve - Yanıt
    6. Pull the plastic frames away from the left and right sides of the center batteries.
    7. Repeat steps 4 and 5 for the two center batteries.
    8. Jump to step 55, then reassemble.
    Note: when installing the new battery, ensure the part closest to you is UNDER the two plastic tabs.
    Worked perfectly.
    Link to video: https://www.youtube.com/watch?v=fupkPz55...
    Note: using the nylon thread with that much effort is crazy. Use the wire or fishing line.
    steve - Yanıt
    cool.
    removed everything and have now 88% after 2 times calibrating and smc reset
    wouldn’t have liked to do everything again, but this seems like a possible solution :)
    Dennis Britsch -
    i just got my Kit and started the procedure, i decided to try if i can get the bulged batteries out with a fishing line, which worked fine. No need to use any solvent and even not too much force was needed to get the line under the batteries. I was able to remove the batteries in about 5min, used another 10min to clean the case from the residue, and put in the new battery. All togehter about 20min of work. I´m very happy with the result, Macbook stays now back on its feet, closes correctly and trackpad works as expected.
    manu - Yanıt
    Also departed from procedure immediately after STEP # 4 as per JOEL’s recommendation …used a small chunk of fishing line and it worked sans solvent…easily ! Spudger worked quite well to initially position the string /line & the ifixit ( ‘credit’ ) cards were nice for final dislodging of each battery segment from the last bits of residual gooey adhesive , AFTER working the fishing line back & forth down the length of the battery as much as possible. With the old battery out of the way, I used a razor blade to clean out the remaining bits of adhesive gunk. ( Decided NOT to use solvent here, either.) Took me every bit of 1-hour.
    One thing that helped ,too, was a cheap pair of cotton gloves coated on the palm side w/ latex. This kept my fingers comfortable from the pressure of the fishing line & allowed more of a range of force …since I wasn’t wincing from saw-cutting myself !
    John Joslin - Yanıt
    I skipped steps 5-33. These steps are completely unnecessary. I used the back of a flat tweezers to separate the battery from the case.
    support64 - Yanıt
    so the only reason they are taking all the stuff off before the battery is because of the solvent?
    I used cards and dental floss and just took the battery out … It was a pain in the butt but i got it out with out using the solvent remover solution.
    GR Verner - Yanıt
    I skipped steps from 5 to 33 and directlychanged the battery (before disassembling all). Worked fine.
    derdietrich - Yanıt
    I also skipped all the additional disassembly. I used cards and wire to cut through the adhesive quite easily. I also did not apply any tape on the new battery. The Mid-2014 laptop seems slim and tight enough to keep the cells from moving and the two screws at the power connector area seem to stabilize the connection and battery as a whole. Such STRONG tape seems unwarranted for the amount of squirm room in such a tight compartment.
    P.S. Remember, while you have it open, clean, clean, clean!!!
    jyee - Yanıt
    Speaking of the power connector screws, I accidentally screwed down the R speaker flat cable on reassembly, which caused the speaker to malfunction. On finding that, I re-routed slightly and the speaker worked fine, this time, but I recommend being extra careful with that cable when putting things back together. You really do have to remove most everything to replace speakers!
    WillUseSpudger -
    Thanks guys for all the tips. I followed the pragmatic way of cutting short and really taking battery out only. Thanks to the cards it worked well and none of the liquid made it to any other part of the computer. Put some efforts in to properly clean the remaining glue after battery was out - but looked good and this message comes from the old mid 2012 15” Retina modell - but with the new battery in - and all is fine. I am happy - thanks to the short cut encouragement.
    Jochen Färber - Yanıt
    Also skipped steps from 5 to 32. I used the supplied cards and a piece of string, i.e. braided nylon twine, (thickness 24). and used supplied acetone sparingly, mostly to the middle section. It took one and a half hours and another half hour or so for removing the leftover goo. It was demanding but not challenging, just take it slow and steady.
    jkobli - Yanıt
    Learnt a lot from former comments. Also skipped steps from 5 to 54. Used fishing line to cut through adjective by myself easily, but needed to put on glove to protect hands. I didnt order full package, so used nail polish remover and eraser to clean the base. Looks good and all is fine! Thanks to the short cut method!
    Gerry GU - Yanıt
    If you decide to skip to Step 34 or 52 or whatever, at least take note of Step 50. This is the only place I saw reference to the thin metal plate protecting the trackpad. I also skipped to just pulling out the batteries, but this plate came out with the them. I had to carefully pry it off the old batteries, reinstall it, and clean the adhesive residue off it.
    Also, YMMV, but I did not bother with delicately removing the old batteries with fishing line, loosening with solvent, or whatever. They’re going in the trash (ahem, recycling) anyway, so I pried them out with a screwdriver, using the neighboring cell as a fulcrum. 98% of the adhesive remained with the batteries, leaving very little residue in the case.
    Jon Scott - Yanıt
    I also forwent the many steps to protect components from the isopropyl alcohol. Blocking the back of the computer up an inch or so meant that any spill would run down and away from the logic board, which actually helped loosen the adhesive. I felt that disconnecting so many parts was a greater risk with no real benefit so long as care was employed in the use of the alcohol. Using some twine in a sawing motion behind each battery got through the adhesive without trauma. The entire repair was actually very simple and fast. The toolkit is excellent and well worth buying from iFixit. The machine is now working really well again. Worth fitting a new SSD now.
    Simon Morice - Yanıt
    Info for assembly: you have place it from top into to connector - watch out for the guidegroove/pimple .
    Not horizontal from battery side (as it seems my first try)
    Muescha - Yanıt
    Success! I ordered the whole kit and thought I would do all these steps below. But instead I just unplugged the battery and skipped all the steps up to step 36. For getting loose the old glued in battery I used waxed dental floss, it is strong and easily available. I strung it around two wood pieces and wired it around the underside of the batteries, then slowly pulled it downwards till the end. This worked quite well and after 10 minutes all the 6 batteries were free. Now the ‘fun’ part, cleaning up the old adhesive strips. I used the little bottle of alcohol from the kit but found this not the best cleaning solution. Be warned, dont forget that in this position, directly under your downpressing fingers there is the glass trackpad and the display!! I really was scared to break them during this cleaning process. Because of this I switched to LIGHTER FLUID , which is stronger and the process quickly proceeded. Thanks ifixit for your great support.
    Jamba - Yanıt
    I had to replace my replacement battery ... luckily the ifixit adhesive isnt that overpowered ... ehem ... I just pulled the old one out softly ... used the plastic card, some force ... and build the hopefully-this-time-lasting-longer-than-4-month-new-battery in ... it saved my evening.
    Arne Fischer - Yanıt
    I just finished doing my second battery replacement on one of these. If you're replacing a battery that came from iFixit you can skip straight to step 34 and use cards/spudgers/guitar picks to remove the batteries. The adhesive on the iFixit batteries isn't nearly as tenacious as the original Apple adhesive (though it's plenty to keep the battery stable) and it was easy to pop the battery segments out with a spudger and peel up most of the excess adhesive strips. What little was left came off easily by putting small amounts of the solvent on paper towel and rubbing - no need to pour any amount of solvent into the case.
    lindensmith - Yanıt
    When it's time to install the new battery, bend the wires a little more to make a "U" shaped down curve...
    The acetone bottle shown runs the risk of dispensing a lot of solvent - which may well damage the speaker plastic. I used a 5 ml plastic pipette to deliver small controlled amounts and had no problems removing the battery without having to take everything else out :-) I also used propanol (isopropyl alcohol) on some kitchen towel to remove the adhesive residue from the case - slightly less effective than acetone, but doesn't dissolve the plastic :-)
    Jon Harris - Yanıt
    I took the good advice of all you previous commenters and skipped to step 34.
    I did not have any solvent but it just took some careful patience prying up the battery with a couple plastic cards.
    elyze - Yanıt
    I used a guitar string ( high e 9 gauge) and a pair of thin leather gloves (to protect hands ) and after using tweezers to get it behind the batteries I was able to pull thru/ cut thru the adhesive with relative ease .
    brian stoller - Yanıt
  5. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, AirPort/Camera Cable: adım 5, 1 resimden 1.
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
    • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
    will this procedure remove my warranty? I have applecare for another 2 years, Laptop was dropped on the side, there is a very small dent on the side of I/O.
    Oleg Babko - Yanıt
    Yes, this voids your warranty.
    max damage -
    These are notoriously difficult to remove. I actually damaged 2/3 of the connector pins during the process. Thankfully i was still able to fit them in place. This step should not be underestimated.
    Alvin Chua - Yanıt
    If you are not replacing the display case assembly, you can opt to leave all 3 connectors attached and remove the Airport card with them connected. You will need to carefully manage the card and attached cables so as not to damage them(masking tape) as you proceed with disassembly/reassembly. Step 6 will need to be done carefully (camera cable connector). I did it after step 8. I took a picture of routed cables as well before I removed them from channel.
    Macrepair SF -
    unless you have really tiny fingers, a tweezer helps, just be careful not to damage the wires or the board as your holding each cable in place. Oh and take your time - this is like the most frustrating step in the process, imo.
    Arn Custodio - Yanıt
    The order of the cables doesn't seem to matter when re-attaching. It also might be helpful to unscrew and eject the airport card. Having it free can give you a better angle.
    joey - Yanıt
    Definitely the hardest step (when putting it back together). The three pins were on progressively longer plugs, so I put the shortest one on the left and so on. This helps with getting the right angle. I used my fingers and the spudger to guide them back in. It took me easily 10-15 minutes to do this. The pattern that worked eventually was to first adjust the angle of the pin head so that it's x/y/z axes would line up perfectly with the connection if you are able to bring it together just so. If you're off on any of these while you try to bring it together, you won't be able to just click it down at the end. Good luck!
    Thomas Kunjappu - Yanıt
    Agreed, for some reason, the middle one was stubborn — and I was worried the amount of force I applied to push it back on was going to break something - but it did pop back on.
    Jer -
    I would never remove those tiny plugs unless I absolutely have to. And we do not have to remove them, just the card itself…
    Jurgen -
    I looked at these plugs under a 8X lupe, since my 56-year-old eyes are not what they used to be. They are circular, so it’s more a question of just aligning the bottom with the top of the plug rather than angle. If I can do it, someone with better eyes can definitely do it.
    Sam Bortnick -
    After reading so many reviews on ifixit and other sites regarding the difficulty of replacing my MacBook Pro retina screen assembly, I was a bit nervous. Using this walk through made it super easy. Thank you so much for taking the time to create it!
    cabcpa - Yanıt
    Removing these 3 tiny cables is completely unnecessary. I removed my fan last week to clean and it slips by these cables. For some dumb reason i wanted to follow this "correct" procedure and now one of the gold connections detached from the wire like it was nothing. Seriously, dont do this. I used a spunger and was very delicate putting it back on... And look what happened. SKIP!
    travismlive - Yanıt
    Yeah, I agree, just leave the airport card attached to the pins and remove the card itself. Then you won’t have to fuss with these connectors.
    Jer -
    @tmm Your right on! Just finished replacing my right fan and your tip saved me from messing with these tiny cables. I totally understand your frustration as I was too just about to stick to the procedure, but if it’s any comfort your tip helped someone… so don’t be surprised being rewarded by some good karma :)
    IT’S UNNECESSARY TO DETACH THE 3 TINY CABLES FROM THE CARD, JUST DETACH THE AIRPORT CARD WITH IT’S CABLES ATTACHED BY GRABING IT FROM BOTH SIDES USING TWO FINGERS AND GENTLY SHAKE IT UNTIL IT DETACHES. THEN MOVE THE WHOLE THING A BIT ASIDE.
    THIS STEP IS ONLY NECESSARY TO MAKE WAY TO THE FAN CONNECTOR UNDERNEATH.
    There is one thing though I find missing which concerns:
    1)The rubber heat sink cover
    2 The AirPort/Camera cables
    3)The IO board cable
    All these are “glued” to the fan and you need to peel them off gently using the spudger, now while I noticed that some glue remains on each cable so they will kinda stick again, I wonder what kind of glue is this and where one can buy it?
    Itai -
    These individual instructions are re-used across multiple tutorials. If you are replacing the battery, you probably won’t need to remove the three connections from the Airport card; if you are replacing the display, you definitely need to replace them, because they are connected to the display. I just replaced the battery and the display in a single activity, so I pretty much had to remove everything. Also agree with a previous commentor that it’s easier to reconnect the cables before the card is reconnected to the system board.
    ChrisMBP -
    travismlive is right, you do not need to remove these cables or the airport card. Just remove the I/O board cable, undo the screws, and detach the antenna cables from the fan where they are glued with a spudger. Unlock the ZIF-socket and the you can wriggle the fan out. Probably saved my airport card, thanks travismlive!
    Jasper - Yanıt
    I only successfully reattached 1 of the 3 AirPort cables, I just taped the other two. But the AirPort seems to work fine. Do these also have anything to do with Bluetooth though? I do seem to have trouble with Bluetooth after this operation. In any case, it was worth it... I replaced the screen with a new Apple screen for less than 1/2 the Apple Store wanted! Thanks!
    Douglas Johnston - Yanıt
    Would soldering them back in place be better than taping? I certainly don't want spare solder on my motherboard, so I figure that'd be a last resort only if I lose AirPort connectivity.
    Assembly is a nightmare. If rightmost cable is not connected, BT will not work.
    Radoslaw Przybyl - Yanıt
    the hardest step is reconnecting the airport antenna cables. just have patience< and use tweezers, spluger and a q-tip.
    Frederick Rae - Yanıt
    The three cables have different lengths. The longest should to the farthest pin, medium to middle, short to nearest.
    Sam Jomaa - Yanıt
    Also, having the right tools will make the job really easy. I used a spudger similar to the one recommended on this web site. But i had ordered a complete kit from amazon.com. I did not have any problem removing or re-attaching the pins.
    Sam Jomaa - Yanıt
    tweezers to hold the cable and the flat part of the spudger to push down on the connectors is the easiest way to re-assemble
    Jon Ocampo - Yanıt
    Replacing these were the most difficult step I encountered. I finally determined that it took slight back and forth twisting of the cable (from left to right as viewed from above) to cause the connector on the cable to twist into position so it could be pressed down.
    chuck60 - Yanıt
    I read your step and you are 100% correct. This helped me tremendously. Thanks!
    Achilles -
    Use leverage with tip of a spudger, it’s not that difficult to pry the cables.
    When you reassemble, use a tweezers to put the connector on the right position and push it down with a finger on the other hand.
    Grab the neck of the cable when using a tweezers.
    eskoo - Yanıt
    Several of the people above mentioned not disconnecting these three wires. You must remove and replace these if you are replacing the entire display which is what these instructions are about. This is the most difficult step as others have noted. Just be careful and make sure you have the cable level before you start pushing down.
    Walt Goede - Yanıt
    Macrepair SF - Yanıt
    Reassembling: What makes this so hard? From all appearances I’m just pressing a squat sleeve-and-pin connector down onto the female counterpart. It appears to be circular and therefore not needing to be oriented radially in any particular angle. It doesn’t look hard at all! Does anyone understand what the subtlety is that causes everyone so much grief?
    Chapman Harrison - Yanıt
    Reassembling: as so many as commented, this is incredibly hard - and inexplicably so. From all appearances I’m just pressing a squat sleeve-and-pin connector down onto the female counterpart. It doesn’t look hard at all! But I couldn’t do it.
    Here’s what seems to have worked for me: with my left fingertip on the cable holding the connector directly above the female, I used the spudger to press down the flat back of the connector, initially at the top and then sliding along toward the neck. I used normal pressure, and voila, when I lifted the spudger away the wretched wire didn’t spring up again. It was like it wanted to be rocked, or stroked, once, from top to neck, rather than pressed straight down.
    I skipped to step 34. Just pushed up the speakers so that they don’t touch the body.
    Sascha Gl Richy - Yanıt
    Can anyone help me? I would like to replace my speakers. Which steps can i skip?
    Manzil Monabber - Yanıt
    I have completed replacing my speakers and this step was not needed at all.
    I just completed the full screen assembly replacement with 90% success I guess. Like many others noted, this was the hardest step, and one them (leftmost) was extra hard, but I eventually got them all back in. However, I don’t have 5G wifi anymore. 2.4 g works fine, bluetooth works fine, and the screen, camera, and mic are all perfectly functioning. I just can’t connect to 5G wifi. Is there a fix for this?
    Aaron C - Yanıt
    Absolutely no need to take apart the whole thing, get some strong fishing line and slowly saw the adhesive away. Once the battery is out, (if you are prone to be clumsy just cover/ shield the rest of the computer, than use GOO GONE or the like waiting a couple minutes to scrape out the old adhesive. The only reason they make your take everything out is that they assume you are lazy and will be using the adhesive remover which could damage the rest of the computer if allowed to splatter etc. Just save your self some time and stress, get strong braided fishing line ( works way better than floss or string as it is of a smaller diameter and isn’t smooth and helps the sawing action), and work your way around each cell. This is still way shorter than removing the entire computer and much less likely hood of damaging sensitive connectors.
    Pia Paeh - Yanıt
    Agreed! Especially if you replace the batttery a second time with a less Apple-like adhesive.
    To prepare for a third time I actually covered parts of the adhesive pads with plastic film on the new battery. I figured that gluing it to the base where it is actually hooked behind the frame makes little sense.
    Cheers to everyone repairing good old things and keeping them alive!
    Jörg -
    Putting these 3 cables back was a lot of work. I bent the outer side of the middle cable, but was able to fix it with fine tweezers from the repair kit.
    olegpsh - Yanıt
    I did a screen replacement recently using this guide and the disassembly/assembly was fine - very good instructions. But when I turned on the machine there was a very fine flickering, snow-like interference, especially noticeable on black backgrounds. I assumed it was a faulty replacement screen and continued to use it. Recently, I had to change out the battery so I dissasembled the screen again to see if reconnecting it would fix the problem. Now it is perfect. I think the problem was that the left-most (shortest) airport cable connector was touching the black screw next to it on the board and shorting out. Be careful to position this connector well away from that screw.
    rumblefish - Yanıt
    I found placing the spunger under the part of the connectors AWAY FROM THE WIRE (top and/or side depending on which of the three you’re finessing), and then rocking them gently from side to side pops them out gently.
    MFMauceri - Yanıt
    I read the note above and managed to fold the card out of the way. I’d put it in a paper envelope to stop it touching anything as it flaps around. The bag also stops static build up and reminds you it’s there ! The wires on mine were held down with two strips of tape, the pointed spudger? pushed along the length of the wires widened the tape loop when I pushed firmly but carefully. Once widened, tweezers can open it fully .
    Simon Anthony - Yanıt
    I skipped the step of removing the airport antenna cables and removed the airport card with the cables since so many users said it was extremely hard to get the airport cables back on properly. By skipping the airport cable removal I save a lot of potential headaches and performing this task was not any more difficult to do.
    Timothy McDaniel - Yanıt
    I skipped steps 5 - 40 and removed the old battery with the plastic card and a palette-knife after heating the adhesive strips cautiously with a hair dryer. After that removing the adhesive strips with the solvent was by far the most time consuming part.
    Martin Zeilinger - Yanıt
    so what happens if you damage 1 of the 3 connectors because you didn’t read all the comments first? Does it work at all or just diminished wifi reception?
    Can someone at ifixit update the main instruction page to advise removing the airport card instead of the super fragile cables?
    Brandyn McKibben - Yanıt
    YOU DONT NEED ANY OF THIS!
    it is SO stupidly risky to remove all this. Who the HECK wrote this guide?!? Thank God I checked on youtube and found guys who did NOTHING of these steps and simply removed the battery in under 1 h.
    Silly Billy - Yanıt
    Steps 5-33 are not really needed if you are careful with the speakers, not to spill the fluid onto them. It saves a lot of time and potential dangerous operations. I did it without any problem.
    Cristian Caprar - Yanıt
    Please be extremely careful, I just ripped out one of the sockets for the cables. I fixed it with Tesa until I can buy a new Airport-Card.
    Josiah Lauer - Yanıt
    BE EXTREMELY CAREFUL WITH THIS STEP both when disconnecting the cable connection points and while doing the reconnection. I damaged the J2 connector (Wi-Fi and Bluetooth are working just fine, though) while trying to reconnect it to the AirPort card. I’ll suggest, as others have here as well, to not disconnect the cables and just have them connected to the card the entire time as this is, IMHO, a completely unnecessary step to take while doing this whole procedure.
    Rafael Pérez - Yanıt
    Well, this is the step that (just through reading these comments) I decided NOT to fix my right speaker. Anytime I have to remove these delicate Airport and Camera wires and connections, I get very nervous. (I've done it before, successfully, on a MacMini [ugh; never again!] - just to replace the two slow HD with SSDs! What a hassle!
    I'll just my headphones or computer speakers through the headphone jack.
    Jonathan Paul Saltzman - Yanıt
    I'm an amateur, so what do I know - but to replace a battery I skipped this step, and all other steps until step 36, I've no idea why they include all these other steps for battery replacement. Literally all steps from 5 - 35 aren't needed.
    Andy M - Yanıt
    I broke the J0 connector when this reconnecting step. But Wi-Fi and Bluetooth functionality are still alive I don't know the reason why.
    ppop popy - Yanıt
    Pretty sure it is fine, but if you want stronger and further WiFi range, that 3rd connector is what gives you that.
    Cary B -
    Why do I have to remove the airport antennas?
    Cary B - Yanıt
    Why this step of unplug the AirPort/Camera Cable
    Matteo Schipsi - Yanıt
    Surtout ne pas démonter les 3 connecteurs. Extraire la nappe camera/wifi sans enlever le 3 connecteurs. Les 3 connecteurs sont fragiles et très difficile à remettre. Dans mon cas, 2/3 des connexions sur la nappe sont HS.
    bruno Villers - Yanıt
    This is the point where you should say "No freaking way" and go watch this youtube video and save yourself a nightmare: https://www.youtube.com/watch?v=rfHHIERH...
    There is absolutely no need for this repair to be this insanely convoluted.
    Donovan Rittenbach - Yanıt
  6. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 6, 1 resimden 1.
    • Use the tip of a spudger to push the camera cable's plug toward the fan and out of its socket on the logic board.
    • The plug in the photo has six connections, but some models have twelve connections. The process of removing the plug from its socket is the same for both.
    • If the camera cable's plug won't come easily out of its socket on the logic board, fold back the rubber cover over the fan to gain access to the cable, then gently pull on the cable while using the spudger to gently push the plug out of its socket.
    • Be sure to push parallel to the board, first on one side, then the other, to slowly "walk" the plug out of its socket. Do not pry up, or you will damage the socket.
    I've broken camera connection socket, is it repairable?
    Sergey - Yanıt
    Same for me too just take the socket from your broken screen and cut it off and solder it onto the new screen. It was really hard because it's so small but I did it.
    bhayes9614 -
    This is much easier if you do step 7 first so you can pull lightly on the cable and take the tension off the connection caused by the stiff cable.
    mayer - Yanıt
    This tip worked for me.
    eskoo -
    If you are removing the right fan it is not necessary to unplug the camera cable. You can slip the fan out underneath the cable.
    noahtfu - Yanıt
    Hi! Camera flex cable is from MBP Retina Mid 2012 & Early 2013. Not Late 2013 :) Edit it please.
    kramerigor - Yanıt
    the tip of the middle 3 wire was broken on the replacement screen. I didn't connect it and everything seems to work fine, mac hardware test says everything is fine... Is it possible?
    micheleroger - Yanıt
    Yes. They are wifi antenna cables. Missing one antenna won't affect much, and won't show up in any hardware test.
    Jason Amri -
    Push on the little wings, from right to left.
    Julian Wood - Yanıt
    This is the hardest part of disassembly! Arguable hardest part of re-assembly too, other than the airport cables
    Jon Ocampo - Yanıt
    The instruction is not clear to me at all. Frankly the comments mentioning things make me uneasy about proceeding further.
    Ben Moore - Yanıt
    This came off for me - now my computer’s fan is running high constantly, and “Kernel_task” is using 500% of the CPU even though nothing else is running - what can I do?
    Ryan Brown - Yanıt
    Did you ever get the fan to stop? how?
    Cyd Trice -
    It is very important to note here that you are NOT pushing up. You are pulling the cable back toward the fan. Doing step 7 first makes that easier. I misunderstood the instruction here (as others seem to have as well) and broke this part. I’m fine with not having a camera on this computer so I’ll leave it or ask my son to help me solder it later.
    Jen Wells - Yanıt
    can you give guidance on the soldering? Im new to it and dont want to burn anything / especially the wrong thing!
    Cyd Trice -
    The wing closed to the edge of the chassis is completely stuck. I’ve worked on it for an hour. The other wing moves freely. I’m not sure what to do now.
    Charles Lindauer - Yanıt
    The connector is very tight - I couldn’t even see the join between cable end and the socket and couldn’t see the “ears” on the end of the socket. And, of course, pulling didn’t help. I eventually used tweezers to start things off, gripping on the metal of the socket right where the invisible join was. What a delight to have the join open enough to see! After that, it was easy.
    jerryl - Yanıt
    Thank You Jerryl - The tweezers did the trick. They want to pop out so you can use your other hand to apply slight downward pressure to keep them in place. Work both ends of the tweezers gently back and forth and you should start to see the gap get bigger.
    Chuck Barton - Yanıt
    I used tweezers and the spudger. Take the point of the spudger and push on one side of the “dog ear” while supporting the other side with the closed tweezers on the cable side of the dog ear. (Could use a second spudger) work one side the move to the other repeatedly until the connection disconnects.
    This is allows You to push and support simultaneously and minimize the chance damaging the connector.
    Jonathan Dowling - Yanıt
    Removed cover (Step 7). Released adhesive. Pulled directly out of socket to the left.
    Pushing out of this connector is ill advised, as no mechanical ledge to push.
    Joseph Gorse - Yanıt
    The late 2013 Macbook connector is slightly different to the picture, I used tweezers to loosen up first and when the joint appeared used the flat edge of the spludger to push the connector using the gap. Don't rush push this from each side gently till it comes out.
    Lanre O - Yanıt
    I found this step to be difficult due to the picture and instructions being incorrect for MacBook Late 2013. Unfortunately, I damaged the pins during this step and my camera no longer works. :^( Please update this step.
    Cristina Stoll - Yanıt
    @xtstoll I looked at two separate Late 2013 units today, and both are indistinguishable from what’s shown in the instructions. Are you sure you’re working on the right model? A photo of what this cable looks like on your laptop would be helpful.
    Jeff Suovanen - Yanıt
    A MAGNIFYING GLASS really helps on this. The cable’s sheathing may need to be pushed back a tad to find a place to get leverace to work the pin out.
    MFMauceri - Yanıt
    DO FIRST
    STEP 7 : Untight the rubber heat sink cover on the right fan.
    Lift the cover and flip it back so that you can access the cables underneath.
    STEP 8 : Carefully de-route the cables from the plastic cable guide.
    So you can easily disconnect the connector.
    KRIS - Yanıt
    Tweezers saved me on this one! Take your time and keep trying (gently) if you're still struggling
    Elizabeth Jolly - Yanıt
    gently set pointed tweezers at the ears on either side and walk it back toward the fan
    Christa - Yanıt
    I have jewellers glasses and they were so helpful. Without them I would have broken plenty of bits. I really recommend getting some magnification for this job, some of the bits are sooooo small!
    Gordon Young - Yanıt
    I have a late 2013, and using the tweezers to gently create a gap worked excellently. I used the tip of the spudger to push it out the rest of the way, alternating right and left on the edge exposed by the gap, pushing gently even when it wasn’t apparent there was any movement.
    Troy Hall - Yanıt
    The way I did it took less than a minute. Ensure the AirPort card is not in place on the board. Get a pair of tweezers to squeeze the ends of the cables into each holder on the card. Apply pressure on the back of the card and the cable end at the same time. If it works, the cables will swivel easily in their slots. Then put the AirPort cable into the board.
    Michael Stroh - Yanıt
    I did it in less than a minute. Used a pair of tweezers. First thing is to take out the AirPort card from the slot. Hold it in one hand while using the tweezers to squeeze each of the cable ends into their sockets. Ensure that you are squeezing the back of the card at the same time as you are clipping in the cable ends. You will see that each cable end will swivel around and not come out of their sockets.
    As per other comments, recommend referring to steps 7 and 10 before attempting step 6.
    I found it helpful to remove the airport card first, then use tweezers to gently pull cable 0.5 m from socket, then use pointy end of "spudger" to push connector out of socket.
    Tim Telcik - Yanıt
    I got to this point on the reassembly only to realise that i was missing the camera cable! Trapped under the motherboard. Decided i dont need the camera that much to warrant reversing everything again
    Barry Cooper - Yanıt
  7. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 7, 3 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 7, 3 resimden 2. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 7, 3 resimden 3.
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and flip it back so that you can access the cables underneath.
    Back (case) side of rubber attachment is flimsy-ish, so need to be delicate when peeling rubber back.
    cahcadden - Yanıt
    assume everything is delicate and needs to be worked gently.
    Christa -
    True @cahcadden.
    Worst case you could accidentally tear it off
    (thank god, that didn’t happen to me, but belive me —> it was a close call)
    Shahzad Arif - Yanıt
    The glue will be gone, don't fret about it. You can just let it flap back when you are done, you can order this item from Amazon: B09WMWH3LM - contact shoes glue.. A little smear on both parts goes a long way. In my case I already had the stuff from other things I fixed for my wife.
  8. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 8, 3 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 8, 3 resimden 2. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 8, 3 resimden 3.
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
    It's a bit tricky to re-route the cables when you're installing the new display, so pay close attention to how they're originally routed, to make sure you don't pinch them or torque them.
    PriorityMail - Yanıt
    I used scotch tape to temporarily hold the cables in place until I was ready to reinstall the bottom cover, but I removed the tape at that last step (didn’t want it coming loose later, and possibly obstructing a fan).
    ChrisMBP - Yanıt
  9. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, I/O Board Cable: adım 9, 3 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, I/O Board Cable: adım 9, 3 resimden 2. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, I/O Board Cable: adım 9, 3 resimden 3.
    • If your I/O Board cable's connectors have notches in the padding, you will need to release a locking lever underneath the notch in order to remove the cable. If this is the case, don't pry up on the connector until the levers are unlatched.
    • Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
    • During reassembly, connect this end first, as it does not flex.
    • In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
    • Remove the I/O Board cable from the MacBook Pro.
    Note that the Mac has been rotated 180º between steps 8 & 9
    peteyx - Yanıt
    When reinstalling the io board cable make sure it is the correct way round as in the photo, it fits the wrong way round as well, which results in the MacBook not starting at all.
    bitmat23 - Yanıt
    ABSOLUTELY ! I found out the hard way. I took a break, came back to me dead computer and wondered - if - this cable would fit the other way round - and voila ! I wish I had read this note first :-)
    Simon Anthony -
    i did exactly the same mistake! Same procedure as well: keep calm, and start again the tutorial.
    every thing work find now
    Guigui -
    Sockets are ZIF with releasing levers on the top. If you pull up on the top padding, you will reveal silver lever handels facing the rear of the machine. Pry up on the LEVER to release the pressure, then pull the lever straight up to release the connector from the socket. DO NOT pry under the edge of the connector to remove these or you may damage the ZIF socket. They may have changed these connectors between models, otherwise I don’t know how this was overlooked in the guide.
    hybrid - Yanıt
    Confirming, these are indeed zifs for me too. My padding has notches indicating location of lever needing to be raised. Obviously lever is tiny, look closely. If your padding is a clean rectangle as shown in guide, you may not have zif sockets here
    hamiltont -
    Confirmed; if the foam pieces are not perfectly rectangular, you should be able to pry back the side of the foam with the cut-away. It folds in half. You can see the lever under the foam. Lift the handle with the spudger, then when it’s pointing straight up (it flips up), you can lift up on the lever (straight up). This should be done for both ends.
    Patryk -
    Confirmed. These instructions (and photos) should definitely be added to the guide!
    Nathan Lucy -
    I just did this and there are no silver lever handles. The connectors just pop off when you pry on them.
    edc - Yanıt
    While putting back the I/O cable, I assumed that it just connects back in place with pressure, kind of like Velcro. I just pushed the one on the left down first as instructed, and, while doing so, folded down the tiny wire lever under the padding (As someone stated earlier, the wire lever isn’t on all models) along with it. It seem to go back in place fairly easily if you’re careful to align the two sides (the part under the cable with the part on the logic board). A a novice, I think this warrants being addressed in more detail. Kinda had to do this intuitively.
    Sam Bortnick - Yanıt
    There is adhesive under the cable. I twisted the cable parallel to the flat fan surface to break it without bending the cable.
    Nathan Lucy - Yanıt
    Yeah, and a strong adhesive.
    throughout all the repairs i have on my MacBook, I have put changing the right fam on the side, just because I was thinking there will be no way of removing the cable without damaging it.
    Soufiane Ezzine -
    I hope I didn't mess up (I'm still dismantling my MBP) but I didn't detach the cable from the fan housing. Disconnected from both ends, and it appeared contented to flop there in space. Fan was then removed without incident
    Fredrick Mezger - Yanıt
    you need to lift one side of the rubber/foam cover to reveal the lock
  10. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, Airport Card: adım 10, 1 resimden 1.
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort card to the logic board.
    I don't see why this is necessary just to remove the logic board...
    Miles Raymond - Yanıt
  11. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 11, 2 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 11, 2 resimden 2.
    • Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board.
    • Pull the AirPort card parallel out of its connector on the logic board to remove it.
    As others have mentioned, it's not necessary to remove the Airport antenna cables. Leave the cables attached and remove the Airport card.
    Swing the card and the attached cables across the fan.
    stvn chng - Yanıt
    You may lift a little like few degrees then pull parallel when removing.
    eskoo - Yanıt
    There might be a touch of adhesive, lift first – a gentle touch with the spudger helps.
    Tristan Harward - Yanıt
    Yes, lift about 5-10 degrees first, then pull out. If you do not release the adhesive, it may be stuck in place and you could damage the card trying to pull it out.
    hybrid - Yanıt
    I will add to what others have said about lifting the card lightly using a spudger to get the adhesive to let go of the board. Otherwise the card may get damaged.
    jeiboussa - Yanıt
    Yes. LIFT up slightly on one end to clear retaining pin before tugging.
    MFMauceri - Yanıt
    Yes. Slight lift to release adhesive and then pull out.
    David Choy - Yanıt
    Highly recommend attaching to your new logic board right away.
    bmellman - Yanıt
    I found it helpful to use the flat end of a "spudger" to gently lift airport card from the main board prior to unplugging.
    Tim Telcik - Yanıt
  12. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 12, 2 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 12, 2 resimden 2.
    • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Starting at the top of the cable, slide a plastic opening tool under the right fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board.
    I was able to flip the retaining flap while removing the damaged fan but accidentally dislodged after installing the replacement fan. Again, be very careful at this stage. Thankfully my new fan appears to function normally.
    Alvin Chua - Yanıt
    My retaining flap just came off. Can you confirm your fan doesn't need it to function??
    Peter Ungacta, Jr. -
    Easier to do while removing fan.
    mayer - Yanıt
    ZIF = Ziero Insertion Force. Once the tiny retaining flap is up, it should slide out easily toward the back. There was no adhesive on my machine, so the cable slid out easily. But be careful if yours is glued down.
    Don Steele - Yanıt
    I don’t know why, but I could pull the connector out & in without flipping up the flap. And fans are working flawlessly.
    eskoo - Yanıt
    The pictures were confusing to me so let me add some more context. There is a ZIF socket (Zero insertion force) being addressed in the first picture. This socket has a black top that is currently closed down on the socket. Using your tool you need to lift this flap up to release the wire underneath (This release happens in the second step). Hence only pull up on the black flap enough to make it go from horizontal to vertical (Swing flap). Neither picture shows it in the up position. Step 2, Picture 2, Then gliding your flat spudger, you goal is to lift the wire that was in the ZIF socket out by lightly lifting up on both the wire and the rubber cushion on top of it. Make sure you lift both. You are successful when both are lifted up and out and facing vertical instead of horizontal.
    Frank D - Yanıt
    Great clarification, thank you.
    Hunter Gallagher -
    Can anyone advise what to do if the ZIF socket pulls up from the logic board? I was gentle with it, but it pulled up anyway. The fan and ribbon are fine, but I’m worried this will require an expensive logic board repair.
    Jaysmi - Yanıt
    To really see which part of the ZIF socket has to be lifted up you should compare the pictures of step 10 and of step 12, preferably in its original size.
    Then you can see that the inner part of the ZIF has to be moved up, away from the batteries.
    Stephan Yaraghchi - Yanıt
    I managed to broke the side, thought this was pulling on sides mechanism to release, not just upwards. Luckily I managed to attach it and the fan is working.
    Josip Ricov - Yanıt
    Here is video how to open the ZIF socket. https://youtu.be/MQbqpWkCz94?t=360
    Ketut Sandiarsa - Yanıt
    Many thanks Ketut, that vid clip really helped!
    Paul Clarke -
    very appreciated!
    Alexis Quintana -
    Thank you… that vid is crisp!
    Erich Hentschel -
    Incredibly poor instructions!!! Thanks to the incorrect wording, I have just ruined the fan connector. There is NO lever. The cable gently slid out, after I borked it. I’m done with IFIXIT and the $@$*!& information. How about a little video clip inserted here. You guys can do better!
    Lorne Shantz - Yanıt
    Can anyone share how to put the retaining flap back onto the connector? Has anyone’s fan worked without it? My hinged retaining flap just slid off and it's extremely difficult to place it back on.
    Peter Ungacta, Jr. - Yanıt
    I found it easier to slide the flat end of the spudger tool in from the left side of the cable, near the 90 degree bend.
    Aimee Ness - Yanıt
    There’s no need to take off all this stuff. I’ve just disconnected the battery, used the glue remover and a dental floss to pull off the battery ✌?
    matteo lepore - Yanıt
    These instructions are pretty lacking for this step. In my case, for both the left and right fans, I did not need to flip up a retaining flap. I did not need to remove the airport card as I could sneak the ribbon cable out from underneath the airport card. There was a tiny bit of adhesive on the ribbon cable. Once that was worked free, I could slide the ribbon cable out of the connector (toward the screen hinge).
    Louis Kreusel - Yanıt
    To all those who complain about the quality of instructions given here, I find them so simple and clear, if you have problems following them you should be letting a repair shop or Apple do the repairs.
    robert - Yanıt
    I can recommend, after lifting ZIF clip, gently slide cable out of socket using "spudger" and/or need nose pliers.
    Tim Telcik - Yanıt
    I destroyed it. Now when the ZIP socket is off the board. Will I have chance to repair with a new or go on only with one fan function. It is so tiny to soldering that I guess the contact legs will connect together and cause a short circuit
    WeDoIt - Yanıt
    Took me step 28 to figure out the latch. its the rear of the connector
  13. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 13, 1 resimden 1.
    • Remove the following three screws securing the right fan to the logic board:
    • One 4.4 mm T5 Torx screw
    • One 3.9 mm T5 Wide Head Torx screw
    • One 5.0 mm T5 Torx screw with 2 mm collar
    With most parts, its easier to leave the screws in the holes parts they come off with, and have small containers or a layout to do this with so each major part does not get mixed up - too many similar but different screws!
    AES - Yanıt
    What I did to separate the different screws, is to take the top of the ifixit essentials-kit (which has lots of small spaces to hold screws) and picked a row of these spaces, which I marked for the cooling-fan screws. So basically I just sort them by lenth: The 5 mm on the top space, underneath it the 4,4mm, and at last the 3,9mm. That way I didn’t loose track, because I was working in tandem with this instruction.
    In my case, the 3.9mm screw was connected to a spacer that sat flush to the motherboard. I misplaced this spacer and had to take the computer apart twice to find it… Make sure not to lose it if you have one!
    Daniel Kirk - Yanıt
    I was able to stop at this step and jump ahead to removing the battery. I did this based on the fact that the batteries were extremely swollen and I could see that the adhesive strips below were already separated from the bottom quite a bit. In retrospect my wife had complained that the computer ran very hot in the vicinity of the batteries (not sure why) but that heat apparently diminished the adhesive properties and allowed me to slowly pry the cells up while using a spudger to push between the case and batteries. Saved twenty some odd steps by doing it that way. If the batteries weren’t swollen I could not have done it this way. NOTE: When ordering just the battery adhesive remover is NOT included. I did not order it because I have acetone here and felt I did not need the iFixit remover.
    Terry Angelli - Yanıt
    The inner spacers on both fans that appear to have been SMT'd to the logic board fell off. I used a light adhesive to put them back but be cautious not to drop them if yours detach also.
    L. Hille - Yanıt
  14. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 14, 1 resimden 1.
    • Lift and remove the right fan out from the MacBook Pro.
    • When reinstalling the fan, it's easiest connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
  15. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, Left Fan: adım 15, 1 resimden 1.
    • Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
    This came of super easy as the glue seemed to have dried up or something of that nature; anyone know if this is an issue?
    Also it seemed like there are clips on sides of the rubber heat sink which I couldn't work out how to clip it back on, so I placed it back where it was after and it seems to be ok; maybe it isn't meant to clip on hard and rather just to be a security measure. Anyone else had this?
    RT0 - Yanıt
    I had the same experience as you this was super easy to remove as well.
    spearson - Yanıt
    Glue was long gone. It just flops over by itself.
    Jer - Yanıt
    I have this feeling that my “noisi fan” was actually the loose end of this rubber cover. So verify that you insert rubber clips back to its slots on under the edge of the sink.
    Albert Stein - Yanıt
  16. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 16, 1 resimden 1.
    • Remove the following three screws securing the left fan to the logic board:
    • One 4.4 mm T5 Torx screw with 2 mm collar
    • When reinstalling the fan and its screws, don't fully torque the screws until you've first installed all of them loosely, so that the fan can move a little and position itself properly as you insert the screws into their threaded standoffs.
    check if screw marking here is right
    Oleg - Yanıt
    what exactly do you mean by wide head torx screw? Is that another torx screw i should buy?
    best regards,
    Seth
    sethroot - Yanıt
    “Wide Head” just refers to the head of the screw being a bit wider than the others. It shouldn’t affect the size of the tool needed. That said, I also was unable to remove this screw with a T5. The screw on mine looked corroded. I ended up using Vampliers (great tool).
    maccentric -
    seems like T5 is the wrong screwdriver for the "3.9 mm T5 Wide Head Torx screw"
    ryanbraganza - Yanıt
    T4 seems to have worked for me
    jonathaniscarroll - Yanıt
    i tried unscrewing the screw with a yellow circle around it but it is not unscrewing i think it is stripped
    Habib Sy - Yanıt
    The nut of the 3.9 mm T5 screw (marked with red circle) seams to be glued or soldered onto the pcb. On my laptop, the connection broke so the nut is rattling on the pcb making a sick noise.
    Does anybody have an idea, how to best fix the nut on the pcb again?
    Marcel Reschke - Yanıt
    Marcel: The 3.9mm screw threads into a metal standoff (not a nut) that's glued to the logic board. If this standoff comes off of the board, a drop of superglue may allow it to stay in place, but to position the standoff properly while re-gluing it, first reattach it to the fan with its screw, then place a drop of superglue on the bottom end of the standoff, then drop the fan back into place and apply a little pressure to the top of the screw to help the superglue stick to the logic board.
    johnsawyercjs - Yanıt
    "One 4.4 mm T5 Torx screw with 2 mm collar" (red) .. mine had no collar; I noticed on closing up.
    Gavin Eadie - Yanıt
  17. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 17, 3 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 17, 3 resimden 2. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 17, 3 resimden 3.
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
    • Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board. If necessary, use an iOpener or hair dryer to heat the cable in order to soften the adhesive and make it easier to remove.
    • Lift the left fan out of the device.
    • When reinstalling the fan, it's easier to connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
    a question out of curiosity is it possible to remove that left fan completely and use and external fan instead of it?
    and what is that fan for? is it for CPU or VGA? i noticed someone was referring to that fan as vga's fan.
    Albert Einstein - Yanıt
    I can't imagine any scenario why one might want to do that Einstein. An external fan on a laptop? Seriously?
    maccentric - Yanıt
    be nice, silly
    Richard RUNGE - Yanıt
    I would say that my cable was permanently adhered, or at least requires chemistry to remove the adhesive. Definitely check if fan parts are in stock before attempting to remove the cable that doesn't seem to be coming loose from the motherboard.
    orders - Yanıt
    Couldn’t manage to “flip up the retaining flap on the left fan ribbon cable ZIF socket.”, in fact think I may may broken a piece off. In the end just pulled out the cable by sliding it down and out (maybe I did manage to loosen it after all). Cable didn’t appear to be glued down thankfully.
    Chris McKay - Yanıt
    That happened to me too! Little pieces of copper came off but I couldn’t see where from . I hope it’ll work after I reassemble.
    Sam Bortnick -
    Holes on the new fan did not exactly match up and ribbon cable has more tension as a result -
    I had to cut the loop on the mount for the 4.4 mm T5 Torx screw. Not ideal.
    Scott Evans - Yanıt
    So, what do I do if I break the connector on the board? Serious question, yes I did it. Now, how do I get the replacement part?
    Amin Shah Gilani - Yanıt
    The retaining flat is super fragile. And I doubt there’s any practical way to replace it. Don’t know if the connector still works ok without the flap.
    Steven DeRose - Yanıt
    After I exchanged the fan it‘s super noisy. I ordered at the ifixit shop and it seems it works but it‘s just super noisy. Does anyone know why?
    Thanks
    Karsten Hullebeck - Yanıt
    I have the same issue with my newly replaced fan…sounds worse than the broken one - will need to check with the ifixit team…
    Markus Meßerschmidt -
    reported this to the support team and got a replacement within one day. The new part works fine - no noise at all, old one is on the way back. Thank you iFixit!
    Left fan was 400% harder to remove due to adhesive. Use the opening tool to gently pry the cable little by little and eventually it will come up. The adhesive pad is the same size and position as the foam pad so concentrate your efforts there
    Aleksis G Williams - Yanıt
    Heads up that the ribbon cable slides into the connector on the board like a little tiny SD card.
  18. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, SSD: adım 18, 1 resimden 1.
    • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
    When I got to this step I realized the screw was stripped. I'm unsure if it was stripped by my efforts -- I used the prescribed P5 screwdriver that was also used for the other screws, and the screwdriver still works when putting the lid back on.
    So to extract the stripped screw in Step 5 I've ordered iFixit's Precision Screw Extractor Set.
    Now I'm wondering if I also need to find a replacement screw since I probably won't be able to use the stripped one again after it's been extracted? The screw is called: 3.1 mm T5 Torx screw as per this guide .. the best I can find on eBay are screws called: 1,4 X 3,1 mm Torx T5 or 1,5 X 3,1 mm Torx T5 ... will one of these work? Would I be able to just go to a hardware store and find the proper screw or is it a specialty item?
    Lorte Messenger - Yanıt
    I'm sure you've long since figured it out, but for the benefit of anyone else reading this, a P5 is not a T5. It's a different screwdriver. The driver for the screws on the outside of the case will not work on the screw holding the SSD. I'm not sure why they left it off in the list of tools at the top.
    Dave Miller -
    The screws on the outside of the case are Pentalobe.
    The screw for the SSD is Torx.
    Both drivers are (now) on the list of required tools.
    (However, my devices both have a T6 head, not T5. May have been after-market.)
    jkgarrett17 -
    For the Macbook Pro Retina 15" Late 2013 models, I've heard the SSD is soldered to the logic board. This guide is for that model, but it doesn't address the soldering issue. Have I just been misinformed on this issue? Has anyone tried it with the late 2013 model yet?
    Elaine - Yanıt
    The SSD is not soldered to the board. You maybe thinking of the RAM which is soldered. (thank you apple) *dripping sarcasm*
    Ryan Tucker -
    I was needing to send my mid 2014 15" MacBook Pro in for a keyboard repair, and my company IT department shipped me a loaner of the same model except that it had a smaller SSD in it than mine, and said I should swap the SSDs between the two and then send mine back with the smaller drive in it to get fixed. I've been unable to swap the drives because neither mine nor the loaner (which are both the same model) appear to have a T5 screw holding the SSD in place. Both of them appear to have a T4, not a T5 (whatever it is is smaller than a T5 anyway, so I'm guessing it's a T4). So now I'm on hold until I can find a T4 screwdriver.
    Dave Miller - Yanıt
    OK, got the new tool set, and yes, it really is actually a T5 screw, you just need a really sharp driver. My existing T5 driver was getting a little dull on the tip. So make sure you have a really new/precision T5 driver/bit to use (and again I'll point out that ifixit failed to list this tool in the list of needed tools at the top).
    Dave Miller -
    It's definitely a T5, just takes more control vs only strength. I went left and right in small increments while pushing down to let the screwdriver dig in before slowly being able to loosen it up.
    Toan Tran - Yanıt
    Both of my A1398 computers (Mid-2012 Retina 15” and Late 2013 Retina 15”) have a screw that my T6 bit fits perfectly. If using a T5 screwdriver/bit makes your screw seem stripped, try the T6.
    (The 2012 was purchased second-hand, and the 2013 was purchased from a dealer known for unauthorized upgrades; it is possible my screws were swapped.)
    jkgarrett17 - Yanıt
    I’m pretty certain this screw is a tiny bit larger diameter than the others — I mixed it up and tried to use it elsewhere, and it wouldn’t fit, so IO swapped in another and set this one aside. Later when I got to this point, other screws were too small and wouldn’t grab. So I tried the one I had set aside earlier, and it fit perfectly. That might explain why this one seemed “stripped” to another commentator.
    On my MacBookPro11,3 this screw was 2.8mm long and had a slightly thicker thread.
    lochotzke - Yanıt
  19. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 19, 2 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 19, 2 resimden 2.
    • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
    where can I buy a 1 or 2 TB SSD? I think it isn’t possible using a SSD like I build in my MacBook Pro mid 2012?
    Chris - Yanıt
    You can get 1TB or 2TB SSD from OWC macsales.com
    https://eshop.macsales.com/shop/ssd/owc/...
    Macrepair SF -
    Hi,
    I intent to purchase a 2 TB ssd for my late 2013 MBP. I read some comments, that the mac reaacted weirdly and was not 100 % compatible with the ssd (not waiking up properly, macstart sound sounded twice, sometimes freezing…). Can you confirm these issues, and are there any workaroundas for them?
    Secondly I plan to restore the time machine from my broken late 2011 MBP. Since you recommended late os for the ssd upgrade I was wondering whether If I restore a time machine backup with an older os if my ssd will cause problems then because the drivers are suddenly missing?
    Thanks and best regards
    ramón
    ramón - Yanıt
    I did this first thing after disconnecting the battery and I'd suggest everyone to do the same! Save your data!
    My battery was bulging and it is obviously quite dangerous. But anyways, any battery in seemingly good conditions can be dangerous as well.
    So in order to prevent a massive data loss along a very long crying session, I opened the back, disconnected the batt as per the guide instructions and then took the SSD off.
    So in case something had gone wrong and the battery started smoking forcing me to throw my laptop off the window, burying it in sand or the whole thing starting to burn, I would've already had a way to access my data by setting the SSD aside first thing.
    It is actually no joke when working with batteries, specially when they're bulging like mine was. Check videos on youtube and see how volatile these things can be!
    Kudos to the iFixit team, this is a great guide!
    Ismael Abufon - Yanıt
    Ismael: That's a good idea, but it's also a good idea to back up the SSD before beginning the Macbook disassembly procedure. This way you'll have two copies of your data, and you can plug the backup into another Mac if you need access to it before you've got your Macbook reassembled, especially if something goes wrong during reassembly that prevents you from using your Macbook for a while.
    Do i need to reinstall macos when i change the ssd? And is the data on the mac will change when changing it?
    Azkap - Yanıt
  20. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, I/O Board: adım 20, 2 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, I/O Board: adım 20, 2 resimden 2.
    • Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
    • Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Do not lift up on the I/O board data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    This is a difficult step. A few images for the removal of the cable would be good/better
    Robert Jan Lebbink - Yanıt
    Yes, a few more detailed pics here would help. Indeed, general pics explaining HOW ALL the plugs and sockets fit would be VERY handy :-)
    Simon Anthony -
    I helped me to use the pliers both to get underneath the canble lock and then push on the wings of the cable.
    Calvin Truong - Yanıt
    Used fingers on the cable lock.
    gently use tips of tweezers at either side to walk it out
    Christa - Yanıt
    It is much more easy to do step 21 before step 20 - this cable is more easy to remove
    Also if you assemble then do step 20 before step 21 - it is more easy to place the cable into the connector
    Muescha - Yanıt
    I found it easier to just use my finger nail to release the clamping lever. Then the spudger to ease it out.
    billbonney - Yanıt
  21. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 21, 3 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 21, 3 resimden 2. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 21, 3 resimden 3.
    • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
    • On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
    • Carefully lift the I/O board and remove it from the lower case.
    This did not want to come out. The bottom was really wedged in there good. I had to pry up the bottom part with a screw driver. The funny thing was it was really easy to put back in. *shrug*
    Jer - Yanıt
    it actually has an extra screw that needs to be removed.
    Reid Rankin - Yanıt
    Thank you. Removing the screw by the heat sink really helped get this board removed.
    Christopher Hofmann -
    It helped me to push the IO board further into the casing and then lifting.
    i/o cable was much easier to remove after freeing the i/o board & slightly lifting it. SK
    Stefan Kirchanski - Yanıt
    I believe, the IO Board can stay where it is, for logic board replacement..?
    smirgle - Yanıt
    Yes, I replace motherboard without touch IO Board
    Александр Гращенков -
    On a 2014.5 design, these instructions should be revised on this process. The heat pipe needs to be removed first if one were to remove the I/O CCA, Reason being, the CCA is installed first into the case and then the heat pipe contact tab lays atop the CCA under the plastic injection molded part. This injection molded piece part secures the tab to the CCA to ensure optimal contact thus, ensuring heat is wicked away from the CCA.
    So when I see comments regarding how it is easier to install than remove, that is an indicator that the user was unaware of how to correctly assemble this component thus, the CCA top side substrate is sitting below the heat pipe tab vs. the other way around.
    This will induce a thermal issue on the I/O CCA and also, possibly short out the board when the conformal coating and painted surface of the heat pipe wears off due to vibration when cables are connected.
    While I like these instructions, I would overhaul them and revise them.
    Christopher McKenna - Yanıt
    Yes, removing the screw near the heat sink really did make it come out easily!
    David Choy - Yanıt
    Notice that the silver 3.5 mm T5 Torx screw is the same one you’re going the be asked to remove on step 29.
    As per comments above, I found it mandatory to remove the extra silver screw near the heat sink, which locked the logic board.
    Hence, the instructions for this step were very relevant:
    "On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal."
    Tim Telcik - Yanıt
    If you have a Transcend JetDrive installed, it needs to be removed. It was just so familiar and form-fitting that I forgot it was in there. Removing it made the I/O board suddenly so easy to remove...
  22. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, Logic Board Assembly: adım 22, 1 resimden 1.
    • Use the flat end of a spudger to pry the headphone jack connector up from its socket on the logic board.
    After connect the cable aux is not working
    deepak selvanathan - Yanıt
    Mine is not working as well after reconnecting, what to do now?
    Guillermo Pichardo -
    Strange, I'm working on the same model, and it doesn't have a flex here. It's soldered.
    Ross Karnes - Yanıt
    Same as Ross. No cable to pry. It’s soldered. But looks like I can continue on anyway
    Cameron Melvin - Yanıt
    Mine not soldered.
    Paul Clarke - Yanıt
  23. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 23, 2 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 23, 2 resimden 2.
    • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board.
    • Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board
    • Be sure to pry on the cable head, and not on the socket itself. Prying on the socket may cause it to separate from the logic board.
    This step could use an image showing the cable lock in the "up" position, releasing the connector. It is hard to see how it works in the "down" position. I think this is the actual connector - there are images in the PDF linked here:
    http://www.ddknet.co.jp/English/products...
    My MBP has an intermittent connection in this keyboard cable. It would be good to know where to buy a replacement!
    Rich - Yanıt
    Pry the speaker connectors *up and out*. Doing it from the cable's sides, next to connectors, is easier.
    Kitipong Mork - Yanıt
    Not sure what happened, but when I put it back together, i barely had enough room to plug this back in. It’s like the cable shrunk. I had to really yank on it to get it to fit.
    Jer - Yanıt
    Adhesive under the left cable made it hard for me to remove it. The right one came out very easy.
    i broke off all the connectors to the logic board any fix for this ?
    Steven Rai - Yanıt
    be gentle - lever under each edge of the connector - you may have to do one side then the other , but the connectors come out easily enough
    AES - Yanıt
    Key here is to go EXTREMELY slow and gentle. The speaker connector in left photo has no release lever(in case you were wondering) I used a tweezer to hold very outside edge down while massaging cable side from underneath with spooner. Gentle rocking and it finally came out properly!
    Edward Bannan - Yanıt
    These instructions are completely inadequate. For anyone who hasn’t done this before, there has to be some image of whatever it is that releases the cables. “Pry the left speaker connector up” without showing the release is just telling me how to turn my computer into junk. . . Which I just did. It’s twelve years old and fully backed up, so I was prepared for this, but I am very disappointed in these instructions. They’ve been bad from the start.
    David Ericksen - Yanıt
    Es wäre besser, wenn man den Ausbau des rechten Lautsprecherkabels besser heraushebt! Ich habe das leider überlesen und den Connector zerstört. Aber ich habe es doch irgendwie geschafft, das der Lautsprecher funktioniert!
    markus.scheiner - Yanıt
    Pay attention that there are 2 connectors of speakers! Otherwise, you will realise in step 32 (like I did) that you forgot one of them ;).
    Francisco Daza - Yanıt
    Despite being extremely careful, both of these connectors broke off from their position on the logic board. It seems like they were soldered on rather than being just a push fit.
    Dave Harper - Yanıt
    following these instructions exactly removed the entire socket from the board. This needs much more detailed instructions and pictures on how to accomplish this and how the connector is put together. the wide view here is grossly inadequate. This needs a much bigger warning to slide the cable away from the connector as any prying will destroy it. The socket came up and took the pads with it, so there's no soldering it back on. guess I'll just have to go without one audio channel in the onboard speakers
    Manuka - Yanıt
    On minute 15:04, in this video, this step is better explained: https://youtu.be/ykqJenHhZJs
    amanda - Yanıt
    well, i managed to do it without screwing the cable, you've actually got to hold the cables at the very base of their connection to the board and gently pull the all together up, not to the side.
    amanda - Yanıt
  24. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 24, 1 resimden 1.
    • Peel back any tape covering the keyboard ribbon cable connector.
    On Re-assembly, I found this to be the hardest part. I resorted to using the provided tweezers and taking turns left and right, working it back into its ZIF socket. If someone knows a better way, please share.
    Fred Anderson - Yanıt
    I just got done with this and my plus/equal, tilde/apostraphe, brackets/braces and volume up keys are not working. Wondering is this isn't seated correctly or if i damaged something. :-(
    sturmjonny - Yanıt
    This is one of the fussier flex cables to reconnect. I'd say it's worth opening it back up and reseating it. Only takes a few minutes—just disconnect the battery and then come straight to this step. Make sure the cable contacts are clean (wipe them with a little isopropyl alcohol and a lint-free cloth), and that the connector is clear of any dirt/debris (give it a good blast or two with some compressed air). Make sure the cable is inserted perfectly flat and straight into the connector (this is the hardest part, just takes patience and a little dexterity). Good luck!
    Jeff Suovanen -
    After replacing the battery I also ended up with keys that don't work (ESC, 0, -, p, ;, ', ENTER). Tried reseating the connector, but without any luck. What is weird is that the keys sometimes work, sometimes they don't. Usually they don't in the first 10 minutes or so after I turn on the mac. If the room temperature is lower (if it's cold), the keys are not functional for a longer period of time...
    Advice for other people who are changing their macbook battery: take extra care with this connector!
    alin.catana -
    This is really a pain to pull out. You sorta have to lift it up and out - I was worried I was going to flex the cable and break it too much.
    Jer - Yanıt
    Use the retaining flap to pull the ribbon cable back into the socket.
    Andrew Dunning - Yanıt
    This keyboard ribbon is so thin. It is like thinner than X-ray film. I was afraid to remove the ribbon from the socket. So, I skipped this step and follow other steps till ‘Step 30’. I didn't remove the logic board as shown in Step 31 and 32. Instead, I removed DC board screws and then DC board from the hole. The cable from the DC board connected at bottom corner of the logic board. I hold the MacBook Pro vertically and lift the logic board slightly and removed the DC board ‘plug’ from the socket. Next, I plugged in the new DC board and followed this procedure in reverse order ( from Step 30 to Step 1). Everything went fine. Important Note: When lifting logic board, please do it carefully and very slowly. Don’t be hurry and don’t break anything. Use magnifying glass and Magnifier in your iPhone to see the tiny parts big and clearly, before removing them.
    Jay Rajamanickam - Yanıt
  25. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 25, 3 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 25, 3 resimden 2. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 25, 3 resimden 3.
    • Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pry only under the hinged retaining flap, not the socket itself, or you may break it off the board.
    • Use the flat end of a spudger to gently back the keyboard ribbon cable out of its socket by pushing first at one side, then the other.
    What is the connector to the right of the keyboard (shown in the above diagram i.e with battery at the bottom)?
    There doesn’t seem to be anything attached to this connector on my system.
    The trackpad connector looks quite similar to the leftof thekeyboard connector.
    Darrell Haslam - Yanıt
    It connects to the EFI Chip.. You can read / write bios information here with dedicatet tools..
    smirgle - Yanıt
    I was having trouble seating the keyboard connection back in. In actuality the issue was the real electronic connector was hidden under logic board after reinstalling the PCB! i was trying to insert the Tape cover instead! Had to re-loosen Logic board and retrieve connector (should see metal traces on the connection strip (that is an easy way to confirm! I had used some scotch tape to hold the cover tape back and this caused me to miss the actual wire harness! I advise anyone doing this process to have a magnifyer with a light so it is easier to see the small parts.
    Rather than pushing with the Spudger, I found it much easier to use the tape to pull directly back on the connector.
    Michael Bryenton - Yanıt
  26. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 26, 1 resimden 1.
    • Use the flat end of a spudger to pry the trackpad ribbon cable connector up from its socket on the logic board.
  27. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 27, 1 resimden 1.
    • Use the flat end of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
    As with all the cables you must be careful here. This one felt even more fragile than the others to me.
    zacz0007 - Yanıt
  28. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 28, 1 resimden 1.
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Pull the microphone ribbon cable out of its socket.
    A small elastic popped out when removing the cable. Glad I wore the protective glasses.
    Louie - Yanıt
    Meaning, pull the ribbon cable out horizontally. And be aware that the copper wiring is on the underside of the cable and the topside is just black plastic, so don’t freak out and think you ripped something pulling it out.
    This cable is quite stiff and felt very resistant to being pulled out - I gently shaped a small bread tag piece of plastic in to a hook that would gently and evenly pull the cable back without tilting it to one side or the other. It is also a pain getting it back in when replacing the logic board - very stiff. Be patient.
    AES - Yanıt
    I just used tweezers.
    curtis phan - Yanıt
    Looks like it had a sticky patch fixing it near the edge of the board - this would make it unwilling to come out of the socket. The patch looks to be the width of the cable and square, so probably pushing a thin something (plastic) under the cable up to the edge of the board would unstick it.
    Christopher - Yanıt
  29. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 29, 2 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 29, 2 resimden 2.
    • Use the tip of a spudger to pry the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    I'd recommend using the pliers.
    conflicting... correct is 'Pull the cable parallel to the face of the logic board.'
    Alex De Lara - Yanıt
  30. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 30, 1 resimden 1.
    • Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near to the MagSafe 2 connector.
  31. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 31, 1 resimden 1.
    • Remove the following six screws securing the logic board to to the upper case:
    • One 2.6 mm T5 Torx screw
    • Two 5.8 mm T5 Torx screws
    • One 3.8 mm T5 Torx screw
    • One 5.2 mm Raised Head T5 Torx screw
    • One 3.5 mm Silver T5 Torx screw
    While you're doing this, unplug the right speaker before you lift the logic board. That is the only step missing in the guide.
    anthony - Yanıt
    anthony: Unplugging the right speaker connector was done in step 23.
    No, you are mistaken . Step 23 was for the LEFT speaker. Anthony is correct stating that right speaker disconnect is missing from this guide. NOW is the time to disconnect the right speaker from the LB!
    Macrepair SF -
    when following on the contrary, its good to check all the ribbons and cables to make sure some are not stuck under board prior to screwing down.
    Robert Gregory - Yanıt
    green indicator: raised head screw is the one you removed the rubber cap from in prior step. (I removed – and then replaced — a different screw in this step. Revisited it with more daylight and saw my error.)
    auntialias - Yanıt
  32. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 32, 3 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 32, 3 resimden 2. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 32, 3 resimden 3.
    • Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
    • Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
    • When reinstalling the logic board, check the cables at the marked locations to make sure they don't get pinned underneath the logic board.
    • Clockwise from top: keyboard, trackpad, battery, right speaker, keyboard backlight, display, microphone, headphone jack, left speaker.
    In bullet #1 I lifted logic board from left side (nearest battery), tilted toward right side (port side) and pulled to to the left a bit to get ports out of chassis cutouts.
    Then I followed bullet #2.
    Going revese order, remember about mic connector and backlit connector. Those nasty small tails are easy to omit. Then you will have to repeat disassembly to get them from under mainboard.
    Radoslaw Przybyl - Yanıt
    Agreed with Radoslaw's comment. It might even be nice to have a list of small cables to watch for during logic board reassembly.
    talarohk - Yanıt
    @radioerewan @talarohk - I think that's a good idea. I went ahead and added a photo showing all the cable locations to check—hopefully it will save someone some trouble! Thanks for your comments.
    This was the single most important pic of the reassembly.
    Mike Jeffries -
    Yes heed everyone’s warning. I had to remove the entire logic board TWICE because i forgot to pull out the antennae and the backlit keyboard plug.
    Jer - Yanıt
    Yes, be very careful before screwing things down. I also forgot the backlight and the display cables. Had the cover for the display cable out, but not the actual cable. I was able to use tweezers to fish the cables out after removing the screws but without removing the whole board.
    E Carlton Hays Jr - Yanıt
    My logic board was stuck under the battery PCB, on the top right side of the battery PCB, when viewed like in the first picture.
    I suggest removing the two screws from step 35 holding the PCB down for a little more wiggle room before attempting to remove the logic board.
    Tom - Yanıt
    I had to go back cause I couldn’t figure out where the logic board connector into (under the board). Funny enough i assembled it and it worked though the night and didn’t come on again. Had to go through the whole process b4 i figured it out. Definitely a good idea to at least breeze through all the images
    Yemi Dalley - Yanıt
    In link MacBook Pro 15" Retina Display Mid 2015 Logic Board Replacement step 34 the second picture exit the procedure install ZIP
    raul - Yanıt
    reassembly: so far the hardest step. After getting all the connectors above board, I still couldn’t quite line up the screw holes. It finally turned out that the board was being prevented from being in its full leftward position because the edge of a flange at the top of the USB port was directly positioned against the edge of a flange on the case. I used my thumbnail to press down on the port’s flange so that it slid under the case flange, allowing the board to shift left another half-millimeter and make everything finally line up.
    Chapman Harrison - Yanıt
    I Just removed the whole power connector with the main board, seemed a little easier. But that’s just me. Good manual thou.
    Timothy de Wal - Yanıt
    Had a lot of trouble getting the power cable out. Would definitly recomend this.
    Calvin Truong -
    100% take the power connector out. This guide is amazing but that is something I would change in it. Also I would do step 35 before attempting to remove the logic board. Unsure if there are other implications of this approach.
    kevinhayes656 -
    Am I completely stupid? ...! When I wanted to remove the mainboard, it was still connected to a plug. I searched, but found no indication about this plug. So I had to try to figure out how this plug works. I started trying, which finally tore the console off the board: -o ...: .- ( It is a small plug to the right of the power supply - Pic. #3 top right!!. Comes below the battery. Note, this must be pushed backwards, but may have a lock. What can I do now? If someone has a tip that I do not have to change my motherboard, I am very, very grateful!
    privat - Yanıt
    I had the same issue where that cable was still connected. I noticed that it was the same type as another one where it needed to be lifted vertically so I did that using the tweesers.
    Jonathan McCaffrey -
    Same problem here, so concerned I might break it I've been working on it for more than an hour! Frustrating to be stuck this late in the process. Anyone know how we missed it in the guide and what it's called?
    Pamela Wilson -
    Definitely unscrew and remove the two screws that hold the MagSafe 2 connector then remove the connector with the board.
    The connector that’s not mentioned in the dissasembly manual is the right hand loudspeaker connector. It pulls up, just the same way as the left hand loudspeaker connector does. No locking tab.
    Other than that it’s a brilliant dissasembly instruction manual, well done.
    I took the logic board out, re-soldered U8900 (well known issue with these boards) and put it back together following the manual in reveres. All works fine now.
    One thing that I did which helped. I printed the manual off, then stuck the screws in every case to the page next to where each screw was described using cellotape. So every screw went back exactly where it came from.
    Steve Hills - Yanıt
    It is mentioned in step 23, but I agree it was not very clear (I also realised in this step).
    Francisco Daza -
    For me, this step was the most hard part when reassemble. Because it is easy to forget or hard to reconnect MagSafe 2 connector properly. I had to give in to professionals just to find out i couldn’t plug this MagSafe 2 connector properly. because of it’s limited angle and i only have 2 hands to do the job while board is lifted.
    kmg125 - Yanıt
    Instead of disconnecting the magsafe socket, I unscrewed the two screws holding it to the case. Then, when the logic board is removed, the connector will slide out with the logic board. Also useful to if theres a bunch of magnetic junk stuck to the adapter as it becomes easy to clean.
    max - Yanıt
    Unscrewing the 2 magsafe screws should be put as a step in the manual. I had a hard time disconnecting the cable and a hard time trying to connect it back when reassembling because there is not enough room to do it and i couldn’t figure out that there is a small clip that holds the connector back in place safely. I had to repeat the role proccess of assemble/disassemble twice in order to fix the magsafe not charging issue. I thought i had lost the connector or damaged the board.
    Jean masaoka -
    Agreed. I found it necessary to unscrew the magsafe power socket from the main board during disassembly to help unplug the ribbon cable from the main board, then screw in the magsafe power socket before the main board during reassembly. The magsafe power socket plug is too short to try and reattach when the magsafe power socket remain attached to the chasis.
    Tim Telcik -
    unscrewing the mag safe as max suggests is a great suggestion. Easier and you can clean the connector.
    klloyd - Yanıt
    It is not necessary to remove the logic board for this. I did this process without removing the logic board and the 30 steps required to disconnect, remove and reconnect it. It was much easier. Not sure why iFixit insists on removing the logic board: its presence does not block removal of the battery.
    Ben Doherty - Yanıt
    Why do you need to remove the entire logic board??? Seems like if you detach the appropriate cables, remove the speakers, that that should be enough. Removing the entire board doesn’t seem necessary - what am I missing?
    Sandwah - Yanıt
    Same question here. What’s the reason behind removing entire logic board?
    Art Skupienski - Yanıt
    From what i gather, logic board removal facilitates de-adhering the ex-battery units, as the solvent can damage the speakers.
    AKin Adams - Yanıt
    I had the hardest time removing the MagSafe 2 connector clip and ended up removing the two screws to dislodge the entire connector.
    Andre K - Yanıt
  33. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 33, 1 resimden 1.
    • Remove the logic board assembly from the MacBook Pro.
  34. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, Speakers: adım 34, 2 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement, Speakers: adım 34, 2 resimden 2.
    • Remove the following three screws securing the left speaker to the upper case:
    • One 5.6 mm T5 Torx screw
    • One 6.9 mm T5 Torx screw
    • Lift the left speaker out of the upper case and set it aside.
    • The speaker is secured to the case with some light adhesive.
    On my MBP there was an adhesive holding the speakers down. So, "lifting" was not exactly accurate.
    Yeah there’s a tiny smidgen of glue around the speaker itself. I just slowly put force on it and it ripped off quite easily.
    Jer - Yanıt
    I have A1398 15 inch , need to replace or fixed left speaker but i can’t find One 2.6 mm T5 Torx screw(yellow one), any idea what to do here?
    Biswajit Patra - Yanıt
    Same question as Biswajit, I can’t find the 2.6 mm T5 Torx screw (yellow one) on my mid 2012 MBP...
    Daniel Gandolfo -
    can you get too the speaker without taking the logic board first
    gianguyen1991 - Yanıt
    How it possible to get speaker out if system without taking the logic board first?
    Biswajit Patra -
    I only removed the 10 screws and the back panel, the 5 speaker’s screws (without removing the speakers), and the two battery screws, and managed to remove the battery package without undoing anything else. I used a member card (credit card type) to loosen the adhesives under the batteries.
    To remove the rest of the glue, I soaked it with something called Label Off from Biltema (Nordic). Finally, I used methylated spirit (rødsprit) to clean it all up and let it dry for 5 minutes before assembling the new battery pack.
    Andreas H. Parlow - Yanıt
    Yeah, it seems that all this complexity is just about protecting the speakers from the acetone… a different solvent might have saved me a LOT of work, and damage to my speaker connection.
    Peter Kaczkowski - Yanıt
    The speakers may stick so be prepared to gently force any adhesive free.
    Eddie Reyes - Yanıt
    @pkay What is so bad about getting acetone near the speakers? Assuming we're a little careful and it evaporates before we switch on again. It won't melt them or something?
    Richard - Yanıt
  35. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 35, 2 resimden 1. MacBook Pro 15" Retina Display Mid 2012 Speakers Replacement: adım 35, 2 resimden 2.
    • Remove the following three screws securing the right speaker to the upper case:
    • Remove the right speaker from the MacBook Pro.
    My speaker wire was wedged under the edge of the battery. I proceeded to step 35 and removed the two battery screws. This freed up the cable.
    Mine was stuck too, and I did what Fred did and waited to step 35 to try and remove the cable. It turned out not to be wedged under anything, but just glued in place.
    I used the flat spudger to loosing the glue underneath the speaker to remove it.
    KC89 - Yanıt
    My left Speaker makes ugly noise. do I really have to do all the steps or is it possible to just remove the speaker… I guess, it’s necessary.
    Gerd Herzog - Yanıt
    The speaker has quite a lot of plastic that goes under the board at the top end. There is no option but to remove the covering parts. The notes show which steps can be skipped.
    Simon Anthony -
    I forgot to run the speaker wire the motherboard. Can it create interference and make the speakers croate?
    Riccardo Nerani - Yanıt
Sonuç
88 farklı kişi bu kılavuzu tamamladı.
Brett Hartt
127.897 İtibar
143 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
18 Yorum
Am I required to change both speakers if only one is damaged? The top of the guide explains it should be replaced as a pair... Don't see why it would be required? Thanks
Lukas Pechar - Yanıt
I have the same question - clearly one speaker is buzzing while the other sounds fine. Why replace both?
Andrew -
Speakers are frequently tested for frequency response and impedance and ones that are similar are paired with one another for installation as a matched set. I presume this is the reasoning behind the statement at the top of this guide.
agorophobe -
Great guide! My speakers sound fine now! Thanks to your guide, man!
RD Rubio - Yanıt
Why is there a need for the speakers to "be replaced as a pair" as noted in the introduction, why can't just one be replaced? or was this not the intention of the author when he wrote that sentence?
Jonathan S - Yanıt
Great Guide, was easy to work with! Thanks for you effort you put into this guide to help other people.
Alexander Jung - Yanıt
I don’t have any instruments for the screws - if I was to order it online, what instruments would I need to order?
Nate Chilton - Yanıt
any t5 torx screwdriver will do
ImmortAL Pang -
The speaker set should have similar life span, when one is broken, another will come to its end of lift soon. I think that’s the reason replace the whole set to prevent another 2 hours work in near future.
Ray Cao - Yanıt
A1398 2012 has both speakers with 6-pin connectors. All the replacements available online are 4 pin out speakers. Specifically, when I used a 4-pin left replacement speaker (by the headphone jack), the headphone detection became an issue coming out of sleep mode. If the laptop was restarted then headphone plugging/unplugging worked OK. I put back the old 6-pin left speaker and it all worked fine. Can anyone shed some light on this issue? Interestingly, most online seller of this product don’t show the number of pins on the left speaker connector.
Bobby Patel - Yanıt
The left speaker of my Retina, Mid 2012 Macbook Pro is creaking. Would it work if i just change the left one? Did anybody just change a single one instead of both? It seems that the left speaker is easy accessable without unplug the logicboard and all the stuff. Why is it necessary to unplug everything? I appreciate your help guys. Thanks!
flo_ryan - Yanıt
I replaced just the right blown speaker. So far so good, both working fine. Pretty straight forward direction to follow from this guide.
AJ Wilhelm - Yanıt
just 3 months later and the original left speaker has now blown. wish i had replaced both at the same time while I had everything taken apart ;)
AJ Wilhelm -
The third picture on step 32 is SUPER helpful! It’s worth double-checking (or even triple-checking) that no connections are trapped underneath the board. Pay extra attention to the right speaker cable: the skinny part goes under the logic board and the wider end goes over the logic board to plug into the socket.
Thumy Webb - Yanıt
Thank you so much, I don’t know how I could do it without your guide. It made it so easy like a breeze.
Foxy - Yanıt
Great job, £24 for the speakers including delivery. Easy to follow.
Andrew Mckay - Yanıt
I agree with AJ above. In my case two weeks after replacing one bad speaker, the other failed. Don’t waste your time replacing just one!
Robert Kridle - Yanıt
Super Anleitung! Vielen Dank. Man sollte sich jedoch wirklich genug Zeit nehmen, kein Stress! Beim Zusammenbau die Kabel alle beachten, hatte ich teilweise unter den Logicboard begraben und musste das Board wieder lösen um dranzukommen! Langsam ist besser!
Habe beim Lautsprecherwechsel auch gleich das Akku mit getauscht. Ging in einem. Kann das Fixit-Werkzeug hierfür nur empfehlen. Alles dabei. Um den Akku zu lösen hatte ich Nagellack-Entferner (mit Aceton) genommen und eine alte EC-Karte zum Lösen. Ging gut.
Uwe Schmitt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 92
Son 30 gün: 420
Her zaman: 83,005
