Ana içeriğe geç
Meta Quest 3 Controller Strap Replacement
Andrew28709
Andrew28709 ve başka bir katkıda bulunan
En son December 22, 2023 tarihinde güncellendi
2 - 3 dakika
Kolay
Have you ever wanted to add accessory's to your oculus quest but were afraid to break something, or simply not know how? In this guide I will go over how to apply the Meta Quest Active Straps for the oculus quest 3 controllers. I will guide you step-by-step to ensure you do not break anything and know how to properly apply the accessory.
  1. Meta Quest 3 Controller Strap Replacement, Controller straps: adım 1, 1 resimden 1.
    • First, you will want to pick up any of the controllers to begin replacing the wrist strap.
  2. Meta Quest 3 Controller Strap Replacement: adım 2, 1 resimden 1.
    • Adjacent to the controller's joystick is a white triangle button.
    • You need to press down firmly on the button to open the controller's battery compartment.
  3. Meta Quest 3 Controller Strap Replacement: adım 3, 2 resimden 1. Meta Quest 3 Controller Strap Replacement: adım 3, 2 resimden 2.
    • Once you open the compartment, pinch and pull up the strap to disconnect it from the controller.
  4. Meta Quest 3 Controller Strap Replacement: adım 4, 1 resimden 1.
    • Grab the corresponding wrist strap for the controller you are working on.
  5. Meta Quest 3 Controller Strap Replacement: adım 5, 2 resimden 1. Meta Quest 3 Controller Strap Replacement: adım 5, 2 resimden 2.
    • With the new wrist strap, push the black clip down into the now-empty small compartment to connect your new strap to the controller.
  6. Meta Quest 3 Controller Strap Replacement: adım 6, 2 resimden 1. Meta Quest 3 Controller Strap Replacement: adım 6, 2 resimden 2.
    • You can close the battery compartment using the new cover connected to the controller strap.
    • Closing the battery compartment can be frustrating because it is connected to the strap; I found it easier to slide the cover from the bottom to the top.
    • The new controller straps come with new battery compartment covers, so when you replace the straps, you will end up with spare parts.
  7. Meta Quest 3 Controller Strap Replacement: adım 7, 3 resimden 1. Meta Quest 3 Controller Strap Replacement: adım 7, 3 resimden 2. Meta Quest 3 Controller Strap Replacement: adım 7, 3 resimden 3.
    • Put the controller in your hands to see if you need to adjust the fit of the strap.
    • If Adjustments are needed, you can pull or push the strap through the clip's hole.
  8. Meta Quest 3 Controller Strap Replacement: adım 8, 2 resimden 1. Meta Quest 3 Controller Strap Replacement: adım 8, 2 resimden 2.
    • Next, repeat steps 2-7 on the second controller.
    • As mentioned in step 6, you will have spare parts left over from the original wrist strap and battery cover. Store these parts somewhere safe if you ever feel like reverting to the original controller straps.
Sonuç
Once you have followed all these steps, you will have properly applied the accessory to your oculus quest 3 controllers.
2 farklı kişi bu kılavuzu tamamladı.
Andrew28709
184 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 122
Son 30 gün: 295
Her zaman: 3,511
