Ana içeriğe geç
Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement
Neye ihtiyacın var
  1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Flip the laptop over: adım 1, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Flip the laptop over: adım 1, 2 resimden 2.
    • Flip the laptop over and place it on your work surface, feet facing up.
  2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Removal tip: adım 2, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Removal tip: adım 2, 2 resimden 2.
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  3. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the rear feet: adım 3, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the rear feet: adım 3, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the rear feet: adım 3, 3 resimden 3.
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  4. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the front feet: adım 4, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the front feet: adım 4, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the front feet: adım 4, 3 resimden 3.
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  5. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Reassembly tip: adım 5, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Reassembly tip: adım 5, 2 resimden 2.
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  6. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Reassembly tip: adım 6, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Reassembly tip: adım 6, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Reassembly tip: adım 6, 3 resimden 3.
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
  7. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the upper case screws: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
    • During reassembly, don't over-tighten these screws—they strip easily.
  8. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Open the display: adım 8, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Open the display: adım 8, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Open the display: adım 8, 3 resimden 3.
    • Flip the device over.
    • Open the display as far as it will go.
  9. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Lift up the upper case: adım 9, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Lift up the upper case: adım 9, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Lift up the upper case: adım 9, 3 resimden 3.
    • The upper case is secured in place by magnets.
    • Grip the top edge of upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case just yet, as it's still connected to the rest of the laptop.
    • Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the display could cause damage to the display as it closes.
  10. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Disconnect the ribbon cable: adım 10, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Disconnect the ribbon cable: adım 10, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Disconnect the ribbon cable: adım 10, 3 resimden 3.
    • The keyboard and touchpad ribbon cable is secured in place by a magnet connector.
    • On some models, this connector is surrounded by black tape.
    • Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
    • Remove the ribbon cable from the motherboard.
  11. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the upper case: adım 11, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the upper case: adım 11, 2 resimden 2.
    • Remove the upper case.
    • Set the upper case onto a clean surface, keyboard-side down.
    • Ensure the ribbon cable lays flat, and isn't twisted or stressed.
  12. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the SSD screw: adım 12, 1 resimden 1.
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be performed before all major repairs.
  13. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the SSD: adım 13, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the SSD: adım 13, 2 resimden 2.
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
  14. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the tape: adım 14, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the tape: adım 14, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the tape: adım 14, 3 resimden 3.
    • Use a pair of tweezers to remove the two pieces of black tape covering the bottom left and bottom right corners of the motherboard.
    • During reassembly, reapply the tape if it's sticky enough to be reused.
  15. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the heatsink shield: adım 15, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the heatsink shield: adım 15, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the heatsink shield: adım 15, 3 resimden 3.
    • Insert the tip of one arm of a sharp pair of tweezers into one of the holes near the top left corner of the heatsink shield.
    • Pull upwards to release the top left corner of the shield.
    • This may require a considerable amount of force, but try not to deform the shield too much—you'll need to reinstall it during reassembly.
  16. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement: adım 16, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement: adım 16, 2 resimden 2.
    • Repeat the previous step's procedure to release the top right corner of the heatsink shield.
  17. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement: adım 17, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement: adım 17, 2 resimden 2.
    • Continue along the heatsink's top edge, inserting a tweezer arm into the shield holes and prying upwards on each one as you go.
  18. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement: adım 18, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement: adım 18, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement: adım 18, 3 resimden 3.
    • Once the top edge is loose, use your fingers to grip the top of the shield and pull it up and away from the heatsink to release the remainder of the shield.
    • Try not to deform the shield too much—you'll need to reinstall it during reassembly.
    • Completely remove the heatsink shield.
  19. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Disconnect the cooling fan: adım 19, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Disconnect the cooling fan: adım 19, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Disconnect the cooling fan: adım 19, 3 resimden 3.
    • Use the pointed end of a spudger to flip up the locking flap on the fan cable's ZIF connector.
    • Use a pair of tweezers to pull the fan cable straight out of the connector.
  20. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the heatsink screws: adım 20, 1 resimden 1.
    • Use a T3 Torx driver to remove the nine screws securing the heatsink:
    • One 2.5 mm screw
    • Three 2.0 mm screws
    • One 3.0 mm screw
    • Two 4.1 mm screws
    • Two 3.4 mm screws
  21. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Reassembly tip: adım 21, 1 resimden 1.
    • Align the heatsink with the centering peg on the motherboard.
    • Tighten the four CPU tension screws in an "X" pattern.
  22. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Clear the alignment peg: adım 22, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Clear the alignment peg: adım 22, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Clear the alignment peg: adım 22, 3 resimden 3.
    • Use the tip of your finger to lift the far right edge of the heatsink up and off of the small alignment peg near the right side of the fan on the lower case.
    • Once the heatsink has cleared the peg, lightly pull the right edge towards the front of the device.
  23. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the heatsink: adım 23, 3 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the heatsink: adım 23, 3 resimden 2. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Remove the heatsink: adım 23, 3 resimden 3.
    • Remove the heatsink.
    • If the heatsink feels stuck to the CPU, gently wiggle it side-to-side to separate it from the thermal paste holding it down.
    • Don't pull on the heatsink too hard; the heat pipes are susceptible to creasing.
  24. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Reapply thermal paste: adım 24, 2 resimden 1. Microsoft Surface Laptop 3 13.5" Heatsink and Fan Replacement, Reapply thermal paste: adım 24, 2 resimden 2.
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and CPU and reapply thermal paste.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
4 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
137.921 İtibar
379 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.715 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 42
Son 30 gün: 193
Her zaman: 3,898
