Giriş
Follow this guide to replace the motherboard on a Microsoft Surface Pro 7.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to apply adequate heat and be extremely careful while slicing through the adhesive. Wear safety glasses in case the glass shatters.
Neye ihtiyacın var
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the Surface’s display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Heat an iOpener and apply it to the right edge of the Surface's screen for two minutes.
Take note of the screen adhesive layout before continuing:
These areas only contain adhesive and are safe to cut.
The display board and flex cables sit here close to the edge. Cut carefully and do not insert the pick more than 1/8 inch (3 mm).
Fragile antenna cables lie under this part of the screen. Carefully follow the procedure in step 13 to avoid damaging them. The adhesive is also the thickest here.
Be prepared; the bluetooth/wifi antennas are adhered to the glass with this very strong tape. You WILL 98% of the time damage them; have another module available that includes the antennas before you attempt this repair as you will damage them if you've never done this repair before. Ive done dozens of these and damage most of them.
For tablets without swollen batteries you can use one of these: https://www.amazon.com/gp/product/B019PX...
For tablets with swollen batteries, you can use one of these: https://www.amazon.com/220V-300W-Tool-Bl...
Just be careful that you don't damage the touchscreen by heating one spot too much. Also, the trick is to get the pick against the back of the display above the adhesive.
David S. -
I managed to remove the screen successfully without breaking the glass, but I found out I completely sliced through cables underneath the lower portion of the display as I used a razor blade, so be careful!
Muhammad, if you are still looking at this, what do the antennas connect to> I can't find the antennas on my glass, nor where they would connect to the frame?
Insert an opening pick into the speaker opening on the screen and slide the pick between the glass and speaker grille.
Note carefully where they start. It is the only place with any sort of access. Razor blade is best. Use picks to hold the top open. Do NOT insert more than a quarter inch ever.
Rotate the pick toward the bottom of the Surface to slide it underneath the lower edge of the speaker cutout.
Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
Leave this opening pick in the right edge to prevent the adhesive from resealing.
Reheat your iOpener and apply it to the bottom edge of the Surface's screen for two minutes.
Reheat your iOpener and apply it to the left edge of the Surface's screen for two minutes.
Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel.
Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
Repeat this motion of inserting the point of the pick where you just cut, and rolling to the right all along the top edge of the Surface, until the pick is 2.5 inches (64 mm) from the right edge of the Surface.
Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated.
Use an opening pick to cut through any remaining adhesive.
Be sure to lift the top first ( camera side) as the ribbon cable have more give that way. I tore one of the cables trying to open from the bottom
Use the pointed tip of a spudger to carefully push on each side of the battery connector.
Alternating from one side to the other, gently “walk” the connector out of its socket.
Use a pair of tweezers to peel back the silver tape covering the left display cable connector.
Insert the flat end of a spudger underneath the tape and pry up on the connector to disconnect it from the motherboard.
I found that the replacement screen cable does not run the same way as the previous screen and it actually doubles over. Is there a reason for this? Can I get a cable that matches the new screen anywhere?
Use a T3 Torx screwdriver to remove the four 2.4 mm screws securing the EMI shield.
Remove the motherboard EMI shield.
Gently peel the center thermal pad off of the copper heatsink.
You don't need to remove the thermal pads. If they are stuck to the battery, use a thin pick under the edges and wiggle it and it will release.
Peel the remaining two thermal pads off of the heatsink.
Die Pad´s reißen wirklich sehr sehr leicht… Gibt es eine Seite, wo man Ersatz kaufen kann?
Translated: The pads tear easily, is there a place to get replacements?
Use an opening tool to pry up on the edge of the EMI shield covering the microSD card reader connector and remove it from the motherboard.
Use a T5 Torx screwdriver to remove the two 3.1 mm screws securing the microSD card reader.
You don't need to remove the microSD card reader; you can gently lift the cable and slightly bend it out of the way enough for the logic board to slide out from underneath it.
Remove the microSD card reader.
Use the flat end of a spudger to lift the flap that secures the Surface Connect port connector.
Use a T5 Torx screwdriver to remove the following two screws from the right speaker:
One 6.0 mm screw
One 3.8 mm screw
From step 26 and on, you will notice that the wifi/bluetooth board has already been removed; this needs to be removed before this step. There e are four P5 screws that need to be removed. Reference my earlier comment at beginning of section; you will MOST LIKELY RUIN THE BLUETOOTH/WIFI strips as they are adhered to the screen and are EXTREMELY difficult to remove without tearing them. Plan on purchasing another module and having it on hand. Ive done dozens of these and have had to replace most of them.
Correction; T4 screws not P5
I also noticed the missing step. This step is covered in another repair guide. See step 28: Microsoft Surface Pro 7 Windows Hello Face Camera Replacement
Use the flat end of a spudger to pry up and disconnect all three camera connectors from the motherboard.
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of tweezers to disconnect the antenna cable covering the front-facing camera ribbon cables.
Move the antenna cable out of the way.
Use the flat end of a spudger to flip up the white plastic locking flap of the ZIF connector at the top-left corner of the motherboard.
Use your fingers or a pair of tweezers to pull the cable out.
Use the flat end of a spudger to flip up the black plastic locking flap of the ZIF connector at the bottom center of the motherboard.
Il manque l'étape de la déconnection de la nappe du port de la prise jack avant l'enlevement des vis de la carte mère
Use a T3 Torx screwdriver to remove the following three screws securing the motherboard:
Two 2.4 mm screws
One 2.3 mm flanged screw
5 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Microsoft sa fare si è no i sistemi operativi, figuriamoci se puo' fare dei pc
