Ana içeriğe geç
Motorola Edge (2022) Display Replacement
Neye ihtiyacın var
  1. Motorola Edge (2022) Display Replacement, Heat the right edge: adım 1, 1 resimden 1.
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola Edge (2022) Display Replacement, Separate the right adhesive: adım 2, 3 resimden 1. Motorola Edge (2022) Display Replacement, Separate the right adhesive: adım 2, 3 resimden 2. Motorola Edge (2022) Display Replacement, Separate the right adhesive: adım 2, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola Edge (2022) Display Replacement, Slice the right adhesive: adım 3, 2 resimden 1. Motorola Edge (2022) Display Replacement, Slice the right adhesive: adım 3, 2 resimden 2.
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick in the bottom right edge to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola Edge (2022) Display Replacement, Heat the bottom edge: adım 4, 1 resimden 1.
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola Edge (2022) Display Replacement, Slice the bottom right corner adhesive: adım 5, 2 resimden 1. Motorola Edge (2022) Display Replacement, Slice the bottom right corner adhesive: adım 5, 2 resimden 2.
    • Rotate the pick around the bottom right corner to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola Edge (2022) Display Replacement: adım 6, 2 resimden 1. Motorola Edge (2022) Display Replacement: adım 6, 2 resimden 2.
    • Slide the pick along the bottom edge to slice the adhesive.
    • Leave the pick in the bottom left edge to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola Edge (2022) Display Replacement: adım 7, 1 resimden 1.
    • Apply a heated iOpener to the back cover's left edge for two minutes.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola Edge (2022) Display Replacement: adım 8, 2 resimden 1. Motorola Edge (2022) Display Replacement: adım 8, 2 resimden 2.
    • Rotate the pick around the bottom left corner to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola Edge (2022) Display Replacement: adım 9, 2 resimden 1. Motorola Edge (2022) Display Replacement: adım 9, 2 resimden 2.
    • Slide the pick along the edge to slice the adhesive.
    • Leave the pick in the top left edge to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  10. Motorola Edge (2022) Display Replacement: adım 10, 1 resimden 1.
    • Apply a heated iOpener to the back cover's top edge for two minutes.
    FixBot'a Sor
    Yorum Ekle
  11. Motorola Edge (2022) Display Replacement: adım 11, 2 resimden 1. Motorola Edge (2022) Display Replacement: adım 11, 2 resimden 2.
    • Rotate the pick around the top left corner to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  12. Motorola Edge (2022) Display Replacement: adım 12, 2 resimden 1. Motorola Edge (2022) Display Replacement: adım 12, 2 resimden 2.
    • Slide the pick along the top edge to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  13. Motorola Edge (2022) Display Replacement, Remove the back cover: adım 13, 2 resimden 1. Motorola Edge (2022) Display Replacement, Remove the back cover: adım 13, 2 resimden 2.
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
    FixBot'a Sor
    Yorum Ekle
  14. Motorola Edge (2022) Display Replacement, Separate the camera bezel adhesive: adım 14, 2 resimden 1. Motorola Edge (2022) Display Replacement, Separate the camera bezel adhesive: adım 14, 2 resimden 2.
    • Insert an opening pick between the right edge of the camera bezel and the motherboard cover.
    • Slide the pick back and forth along the edge to slice the adhesive.
    FixBot'a Sor
    Yorum Ekle
  15. Motorola Edge (2022) Display Replacement: adım 15, 2 resimden 1. Motorola Edge (2022) Display Replacement: adım 15, 2 resimden 2.
    • Insert an opening pick between the left edge of the camera bezel and the motherboard cover.
    FixBot'a Sor
    Yorum Ekle
  16. Motorola Edge (2022) Display Replacement, Remove the camera bezel: adım 16, 2 resimden 1. Motorola Edge (2022) Display Replacement, Remove the camera bezel: adım 16, 2 resimden 2.
    • Lift the camera bezel from the phone and remove it.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • If you are replacing the fingerprint sensor or screen assembly, use this guide to calibrate the fingerprint sensor.
    • Follow this guide to replace the back cover and camera bezel adhesive.
    FixBot'a Sor
    Yorum Ekle
  17. Motorola Edge (2022) Display Replacement, Detach the left wireless charging coil tape: adım 17, 2 resimden 1. Motorola Edge (2022) Display Replacement, Detach the left wireless charging coil tape: adım 17, 2 resimden 2.
    • Insert the pointed end of a spudger underneath the tape that connects the wireless charging coil to the speaker on the bottom left of the phone.
    • Slowly lift the spudger up until the tape detaches from the speaker.
    FixBot'a Sor
    Yorum Ekle
  18. Motorola Edge (2022) Display Replacement, Detach the right wireless charging coil tape: adım 18, 2 resimden 1. Motorola Edge (2022) Display Replacement, Detach the right wireless charging coil tape: adım 18, 2 resimden 2.
    • Insert a spudger underneath the tape that connects the wireless charging coil to the daughterboard cover on the bottom right of the phone.
    • Slowly lift the spudger up until the tape detaches.
    FixBot'a Sor
    Yorum Ekle
  19. Motorola Edge (2022) Display Replacement: adım 19, 2 resimden 1. Motorola Edge (2022) Display Replacement: adım 19, 2 resimden 2.
    • Use a Phillips screwdriver to remove the ten 4 mm screws securing the motherboard cover.
    FixBot'a Sor
    Yorum Ekle
  20. Motorola Edge (2022) Display Replacement: adım 20, 2 resimden 1. Motorola Edge (2022) Display Replacement: adım 20, 2 resimden 2.
    • Adhesive secures the motherboard cover to the motherboard itself.
    • Apply a heated iOpener between the bottom edge of the motherboard cover for two minutes.
    FixBot'a Sor
    Yorum Ekle
  21. Motorola Edge (2022) Display Replacement: adım 21, 3 resimden 1. Motorola Edge (2022) Display Replacement: adım 21, 3 resimden 2. Motorola Edge (2022) Display Replacement: adım 21, 3 resimden 3.
    • Insert an opening tool between the motherboard cover and the midframe.
    • Pry up with the opening tool until you are able to grab the motherboard cover with your fingers.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
    FixBot'a Sor
    Yorum Ekle
  22. Motorola Edge (2022) Display Replacement, Remove the motherboard cover: adım 22, 3 resimden 1. Motorola Edge (2022) Display Replacement, Remove the motherboard cover: adım 22, 3 resimden 2. Motorola Edge (2022) Display Replacement, Remove the motherboard cover: adım 22, 3 resimden 3.
    • Slowly pull the motherboard cover up and away from the phone and remove it.
    FixBot'a Sor
    Yorum Ekle
  23. Motorola Edge (2022) Display Replacement, Move the graphite film: adım 23, 2 resimden 1. Motorola Edge (2022) Display Replacement, Move the graphite film: adım 23, 2 resimden 2.
    • Use your fingers to move the graphite film that covers the battery out of the way.
    FixBot'a Sor
    Yorum Ekle
  24. Motorola Edge (2022) Display Replacement, Disconnect the battery: adım 24, 2 resimden 1. Motorola Edge (2022) Display Replacement, Disconnect the battery: adım 24, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    FixBot'a Sor
    Yorum Ekle
  25. Motorola Edge (2022) Display Replacement, Apply isopropyl alcohol: adım 25, 2 resimden 1. Motorola Edge (2022) Display Replacement, Apply isopropyl alcohol: adım 25, 2 resimden 2.
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the gaps along the battery's edges.
    • Tilt the device as you apply alcohol to help it flow under the battery.
    • Wait one minute to allow the isopropyl alcohol to penetrate the adhesive.
    • Only apply a few drops initially and apply more as necessary. If you apply too much alcohol, it may overflow onto the motherboard and daughterboard.
    FixBot'a Sor
    Yorum Ekle
  26. Motorola Edge (2022) Display Replacement, Separate the battery's adhesive: adım 26, 3 resimden 1. Motorola Edge (2022) Display Replacement, Separate the battery's adhesive: adım 26, 3 resimden 2. Motorola Edge (2022) Display Replacement, Separate the battery's adhesive: adım 26, 3 resimden 3.
    • Take care not to puncture or bend the battery during the removal process—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Apply a suction cup to the battery.
    • Pull up on the suction cup with strong, steady force to create a gap between the battery and the frame.
    • If the battery doesn't budge, apply a few more drops of isopropyl alcohol and try again.
    • Continue to pull up on the suction cup while sliding the opening pick back and forth to slice the adhesive. Continue this process until the battery separates from the frame.
    FixBot'a Sor
    Yorum Ekle
  27. Motorola Edge (2022) Display Replacement, Remove the battery: adım 27, 2 resimden 1. Motorola Edge (2022) Display Replacement, Remove the battery: adım 27, 2 resimden 2.
    • Remove the battery from the midframe.
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Follow this guide to install new battery adhesive.
    FixBot'a Sor
    Yorum Ekle
  28. Motorola Edge (2022) Display Replacement, Transfer the battery's foam strip: adım 28, 3 resimden 1. Motorola Edge (2022) Display Replacement, Transfer the battery's foam strip: adım 28, 3 resimden 2. Motorola Edge (2022) Display Replacement, Transfer the battery's foam strip: adım 28, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers or your fingers to remove the foam strip from the battery's bottom edge.
    • Before installing your new battery, apply the foam strip to it.
    FixBot'a Sor
    Yorum Ekle
  29. Motorola Edge (2022) Display Replacement, Place the motherboard cover back on: adım 29, 2 resimden 1. Motorola Edge (2022) Display Replacement, Place the motherboard cover back on: adım 29, 2 resimden 2.
    • Before continuing your repair, place the motherboard cover back on the phone to protect the cameras and motherboard.
    FixBot'a Sor
    Yorum Ekle
  30. Motorola Edge (2022) Display Replacement, Place the back cover back on: adım 30, 2 resimden 1. Motorola Edge (2022) Display Replacement, Place the back cover back on: adım 30, 2 resimden 2.
    • Place the back cover on the phone to secure the motherboard cover.
    FixBot'a Sor
    Yorum Ekle
  31. Motorola Edge (2022) Display Replacement, Loosen the display adhesive: adım 31, 1 resimden 1.
    • Flip your phone over to access the display.
    • Apply a heated iOpener to the display for at least five minutes to loosen the adhesive underneath.
    FixBot'a Sor
    Yorum Ekle
  32. Motorola Edge (2022) Display Replacement, Insert an opening pick: adım 32, 3 resimden 1. Motorola Edge (2022) Display Replacement, Insert an opening pick: adım 32, 3 resimden 2. Motorola Edge (2022) Display Replacement, Insert an opening pick: adım 32, 3 resimden 3.
    • Once the display is hot to the touch, apply a suction handle to the bottom of the display as close to the edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the display.
    • Pull up on the suction handle with a strong, steady force to create a small gap between the display and the frame.
    • The display adhesive is very strong, so this may take multiple attempts. If you're having trouble, reheat the display and try again.
    • Insert an opening pick into the gap between the frame and the display.
    • Do not insert more than 3 mm of the pick to avoid damaging the display ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  33. Motorola Edge (2022) Display Replacement: adım 33, 3 resimden 1. Motorola Edge (2022) Display Replacement: adım 33, 3 resimden 2. Motorola Edge (2022) Display Replacement: adım 33, 3 resimden 3.
    • When slicing the bottom adhesive, don't insert the opening pick more than 3 mm to avoid damaging the fingerprint sensor.
    • Slide the opening pick along the bottom edge of the phone to slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  34. Motorola Edge (2022) Display Replacement: adım 34, 3 resimden 1. Motorola Edge (2022) Display Replacement: adım 34, 3 resimden 2. Motorola Edge (2022) Display Replacement: adım 34, 3 resimden 3.
    • Don't insert the opening pick more than 6 mm to avoid damaging the heat spreader.
    • Insert a second opening pick near the bottom right corner and slide it along the right edge to slice the adhesive.
    • Leave the pick inserted in the top right corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  35. Motorola Edge (2022) Display Replacement: adım 35, 3 resimden 1. Motorola Edge (2022) Display Replacement: adım 35, 3 resimden 2. Motorola Edge (2022) Display Replacement: adım 35, 3 resimden 3.
    • Insert a third opening pick at the top right corner of the display.
    • When slicing near the front facing camera, don't insert the opening pick more than 2 mm to avoid damaging the earpiece speaker cutout and the front camera.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick inserted in the top left corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  36. Motorola Edge (2022) Display Replacement: adım 36, 3 resimden 1. Motorola Edge (2022) Display Replacement: adım 36, 3 resimden 2. Motorola Edge (2022) Display Replacement: adım 36, 3 resimden 3.
    • Insert a fourth opening pick in the top left corner of the display.
    • Don't insert the pick more than 2 mm to avoid damaging the heat spreader and the fingerprint sensor.
    • Slide the pick along the left edge to slice the adhesive.
    • The screen should be detached at this point.
    FixBot'a Sor
    Yorum Ekle
  37. Motorola Edge (2022) Display Replacement, Remove the back cover: adım 37, 2 resimden 1. Motorola Edge (2022) Display Replacement, Remove the back cover: adım 37, 2 resimden 2.
    • Flip your phone over to access the back cover.
    • Remove the opening picks and back cover from the phone.
    FixBot'a Sor
    Yorum Ekle
  38. Motorola Edge (2022) Display Replacement: adım 38, 2 resimden 1. Motorola Edge (2022) Display Replacement: adım 38, 2 resimden 2.
    • Remove the motherboard cover.
    • The wireless charging coil may have adhered to the battery adhesive. If it has, pull up gently to detach it.
    FixBot'a Sor
    Yorum Ekle
  39. Motorola Edge (2022) Display Replacement: adım 39, 2 resimden 1. Motorola Edge (2022) Display Replacement: adım 39, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the display cable's press connector.
    FixBot'a Sor
    Yorum Ekle
  40. Motorola Edge (2022) Display Replacement, Loosen the display cable adhesive: adım 40, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  41. Motorola Edge (2022) Display Replacement, Separate the cable adhesive: adım 41, 3 resimden 1. Motorola Edge (2022) Display Replacement, Separate the cable adhesive: adım 41, 3 resimden 2. Motorola Edge (2022) Display Replacement, Separate the cable adhesive: adım 41, 3 resimden 3.
    • Use tweezers to grip the display cable just below the press connector.
    • Gently pull the display cable towards the bottom of the phone until it's freed from its space under the motherboard.
    • Continue pulling the cable to separate its adhesive.
    FixBot'a Sor
    Yorum Ekle
  42. Motorola Edge (2022) Display Replacement, Remove the display: adım 42, 3 resimden 1. Motorola Edge (2022) Display Replacement, Remove the display: adım 42, 3 resimden 2. Motorola Edge (2022) Display Replacement, Remove the display: adım 42, 3 resimden 3.
    • The display may have lightly readhered to the frame during the last few steps. If it has, use an opening pick to detach the display from the frame before continuing.
    • Before removing the display, make sure that the display's ribbon cable is completely detached from the adhesive on the midframe.
    • Gently pull up on the display and thread the ribbon cable through the hole in midframe to remove the display.
    FixBot'a Sor
    Yorum Ekle
  43. Motorola Edge (2022) Display Replacement: adım 43, 1 resimden 1.
    • During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%) and a micro-fiber cloth.
    • Follow this guide if you're using a precut adhesive card.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Spencer Day
196.911 İtibar
1.243 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.535 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 55
Her zaman: 2,244
