Ana içeriğe geç
Motorola Moto G5 Battery Replacement
Neye ihtiyacın var
  1. Motorola Moto G5 Battery Replacement, Back Cover: adım 1, 2 resimden 1. Motorola Moto G5 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Battery Replacement: adım 2, 3 resimden 1. Motorola Moto G5 Battery Replacement: adım 2, 3 resimden 2. Motorola Moto G5 Battery Replacement: adım 2, 3 resimden 3.
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Battery Replacement: adım 3, 3 resimden 1. Motorola Moto G5 Battery Replacement: adım 3, 3 resimden 2. Motorola Moto G5 Battery Replacement: adım 3, 3 resimden 3.
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Battery Replacement: adım 4, 2 resimden 1. Motorola Moto G5 Battery Replacement: adım 4, 2 resimden 2.
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Battery Replacement, Battery: adım 5, 2 resimden 1. Motorola Moto G5 Battery Replacement, Battery: adım 5, 2 resimden 2.
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
Sonuç
After completing this guide, calibrate your newly-installed battery.
Repair didn’t go as planned? Check out our Motorola Moto G5 Answers community for troubleshooting help.
9 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
258.916 İtibar
531 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.086 adet Kılavuz yazıldı
5 Yorum
this is not the g5 replacement procedure. it will not work.need to remove screen.
Tom Tercek - Yanıt
@Tom Tercek - You are in a huge mistake. This is the Motorola Moto G5 phone and the battery is removable and as shown on the pics, very easy to replace.
prishylets - Yanıt
is it also possible with moto g5s?
Jojo Blublub - Yanıt
Unfortunately, the G5S does not have an easily replaceable battery.
Arthur Shi -
Hi, I'm looking for parts for Moto G5, specifically an intern plastic cover that goes over the charge port.
Leonardo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 113
Son 30 gün: 435
Her zaman: 40,383
