Ana içeriğe geç
Nikon D5100 Memory Card Replacement
Liz
Liz ve başka bir katkıda bulunan
En son June 10, 2014 tarihinde güncellendi
1 dakika
Çok kolay
Your camera stores images and data on an SD memory card. This guide will teach you how to locate and replace this memory card.
  1. Nikon D5100 Memory Card Replacement, Memory Card: adım 1, 3 resimden 1. Nikon D5100 Memory Card Replacement, Memory Card: adım 1, 3 resimden 2. Nikon D5100 Memory Card Replacement, Memory Card: adım 1, 3 resimden 3.
    • Open the memory card compartment door, located to the right of the digital display, by using your thumb to push it in the direction of the arrow.
  2. Nikon D5100 Memory Card Replacement: adım 2, 1 resimden 1.
    • Eject the memory card by pressing it into its slot until you hear a soft "click."
  3. Nikon D5100 Memory Card Replacement: adım 3, 1 resimden 1.
    • Using thumb and forefinger, gently remove the SD card from its slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Liz
1.428 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-54, Amido Spring 2014 Cal Poly, Team 10-54, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S10G54
4 Üyeler
Bir Yorum
isn't this procedure in the user manual?
Happy Fixer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 33
Her zaman: 2,566
