Giriş
Follow this guide to replace the 3.5mm headphone jack and game card reader board in a Nintendo Switch gaming console.
Remove the single 3.1mm JIS #000 screw from micro SD card board.
Insert the pointed end of a spudger underneath the white connector and pry upwards to disconnect the battery from the motherboard.
Remove the two 3.1mm JIS #000 screws from the headphone jack reinforcement plate.
Use a spudger to flip up the small black locking flap on the ZIF connector connecting the display to the motherboard.
To reconnect ZIF connectors like this one, gently slide the cable back in place and press the locking flap back into place.
13 farklı kişi bu kılavuzu tamamladı.
12 Comments
The SD card slot removal wasn’t in the guide, but otherwise spot on. Thanks!
Good catch! It’s updated now :)
It worked, thanks
After changing the board out, I don’t have touch on the screen, put the original PCB back in the console and i have touch again, so its not that I did any damage to the flexes or ZIF connector. Any one have any ideas?
Hey man, did you ever figure this out? I have the exact same issue. My touchscreen is no longer working.
