Ana içeriğe geç
Nintendo Switch Heat Sink Replacement
Neye ihtiyacın var
  1. Nintendo Switch Heat Sink Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 1. Nintendo Switch Heat Sink Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 2. Nintendo Switch Heat Sink Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 3.
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo Switch Heat Sink Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 1. Nintendo Switch Heat Sink Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 2. Nintendo Switch Heat Sink Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 3.
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo Switch Heat Sink Replacement, Remove the back-side screws: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
    • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
    • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo Switch Heat Sink Replacement, Remove the top and bottom screws: adım 4, 2 resimden 1. Nintendo Switch Heat Sink Replacement, Remove the top and bottom screws: adım 4, 2 resimden 2.
    • Use a JIS 00 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
    • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo Switch Heat Sink Replacement, Remove the center side screws: adım 5, 2 resimden 1. Nintendo Switch Heat Sink Replacement, Remove the center side screws: adım 5, 2 resimden 2.
    • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo Switch Heat Sink Replacement: adım 6, 2 resimden 1. Nintendo Switch Heat Sink Replacement: adım 6, 2 resimden 2.
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    FixBot'a Sor
    Yorum Ekle
  7. Nintendo Switch Heat Sink Replacement, Remove the kickstand well screw: adım 7, 1 resimden 1.
    • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
    FixBot'a Sor
    Yorum Ekle
  8. Nintendo Switch Heat Sink Replacement, Remove the rear panel: adım 8, 3 resimden 1. Nintendo Switch Heat Sink Replacement, Remove the rear panel: adım 8, 3 resimden 2. Nintendo Switch Heat Sink Replacement, Remove the rear panel: adım 8, 3 resimden 3.
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel straight up from the bottom of the device and remove it.
    • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
    FixBot'a Sor
    Yorum Ekle
  9. Nintendo Switch Heat Sink Replacement, Remove the microSD card reader: adım 9, 1 resimden 1.
    • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
    FixBot'a Sor
    Yorum Ekle
  10. Nintendo Switch Heat Sink Replacement: adım 10, 2 resimden 1. Nintendo Switch Heat Sink Replacement: adım 10, 2 resimden 2.
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, remove the foam pad before connecting the press connector to the motherboard. Set the foam pad back in place after you verify it's connected.
    FixBot'a Sor
    Yorum Ekle
  11. Nintendo Switch Heat Sink Replacement, Remove the shield plate: adım 11, 1 resimden 1.
    • Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
    FixBot'a Sor
    Yorum Ekle
  12. Nintendo Switch Heat Sink Replacement: adım 12, 2 resimden 1. Nintendo Switch Heat Sink Replacement: adım 12, 2 resimden 2.
    • If the console doesn't have this foam, skip this step.
    • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
    • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
    FixBot'a Sor
    Yorum Ekle
  13. Nintendo Switch Heat Sink Replacement: adım 13, 3 resimden 1. Nintendo Switch Heat Sink Replacement: adım 13, 3 resimden 2. Nintendo Switch Heat Sink Replacement: adım 13, 3 resimden 3.
    iFixit Thermal Putty
    $9.95
    • Insert a spudger underneath the shield plate along the edge of the device.
    • Pry up to lift the shield plate and remove it from the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
    • During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
    • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
    FixBot'a Sor
    Yorum Ekle
  14. Nintendo Switch Heat Sink Replacement, Disconnect the battery: adım 14, 2 resimden 1. Nintendo Switch Heat Sink Replacement, Disconnect the battery: adım 14, 2 resimden 2.
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  15. Nintendo Switch Heat Sink Replacement, Remove the heat sink: adım 15, 1 resimden 1.
    • Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  16. Bu adımda kullanılan alet:
    iFixit Adhesive Remover
    $19.99
    • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
    • The foam only needs to be peeled back enough to clear the fan.
    • The foam is really delicate and tears easily. Use the following technique to peel the foam:
    • If you have some, dip the point of a spudger in adhesive remover or isopropyl alcohol (90% or greater).
    • Insert the point of a spudger underneath a part of the foam that isn't stuck to anything.
    • Press the top of the foam with your finger to hold it in place.
    • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
    FixBot'a Sor
    Yorum Ekle
  17. Nintendo Switch Heat Sink Replacement: adım 17, 3 resimden 1. Nintendo Switch Heat Sink Replacement: adım 17, 3 resimden 2. Nintendo Switch Heat Sink Replacement: adım 17, 3 resimden 3.
    • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
    • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
    • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly. Don't reuse the old thermal paste.
    • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
69 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
42.948 İtibar
82 adet Kılavuz yazıldı
10Kılavuz Yorumları
I couldn’t even get past the first step because my screws were in so tight I made them threadbare trying to get them out. I did use the iFixit toolkit so I was using the right head but taking the screws out is not as easy as demonstrated lol
Nate Topical - Yanıt Paylaş
same mines are stripped
Luigi Igii - Yanıt Paylaş
Same happened to me :( I was able to file down the screwdriver I was given and it worked on three of the screws before they’d stripped too much. The fourth screw I couldn’t remove so I was able to slightly bend and turn the backing enough to access the fan. I also wasn’t able to peel the tape back without it completely disintegrating. Haha guess I don’t have the magic touch.
Angela Evans - Yanıt Paylaş
Do you need the K5 thermal peas or is the Arctic silver 5 thermal paste enough?
Carlos O - Yanıt Paylaş
You just need a good thermal paste
Daniele Carminati - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 39
Son 7 gün: 201
Son 30 gün: 1,028
Her zaman: 110,076
