Ana içeriğe geç
Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement
Neye ihtiyacın var
  1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 2. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 3.
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 2. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 3.
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the top screw: adım 3, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the top screw: adım 3, 2 resimden 2.
    • Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS or Phillips driver if the screws won't come out.
  4. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the bottom screws: adım 4, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the bottom screws: adım 4, 2 resimden 2.
    • Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
  5. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the right screw: adım 5, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the right screw: adım 5, 2 resimden 2.
    • Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  6. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the left screw: adım 6, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the left screw: adım 6, 2 resimden 2.
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
  7. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Open the kickstand: adım 7, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Open the kickstand: adım 7, 2 resimden 2.
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  8. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the back-side screws: adım 8, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the back-side screws: adım 8, 2 resimden 2.
    • Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
  9. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the rear case: adım 9, 3 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the rear case: adım 9, 3 resimden 2. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the rear case: adım 9, 3 resimden 3.
    • Lift the rear case up from the top of the device and remove it.
    • If you're having trouble removing the case, use an opening pick to pry up the plastic clips.
  10. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the shield plate's tape: adım 10, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the shield plate's tape: adım 10, 2 resimden 2.
    • Use the flat end of a spudger to separate a corner of the tape from the shield plate.
  11. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement: adım 11, 3 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement: adım 11, 3 resimden 2. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement: adım 11, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers, or your fingers, to peel back and remove the tape.
    • Store the tape in a clean space for reinstallation.
  12. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Disconnect the primary Wi-Fi antenna: adım 12, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Disconnect the primary Wi-Fi antenna: adım 12, 2 resimden 2.
    • Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  13. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Reroute the primary antenna's coaxial cable: adım 13, 3 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Reroute the primary antenna's coaxial cable: adım 13, 3 resimden 2. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Reroute the primary antenna's coaxial cable: adım 13, 3 resimden 3.
    • Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
  14. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Unfasten the primary Wi-Fi antenna: adım 14, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Unfasten the primary Wi-Fi antenna: adım 14, 2 resimden 2.
    • Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
  15. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the primary Wi-Fi antenna: adım 15, 3 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the primary Wi-Fi antenna: adım 15, 3 resimden 2. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the primary Wi-Fi antenna: adım 15, 3 resimden 3.
    • Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
  16. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement: adım 16, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement: adım 16, 2 resimden 2.
    • Remove the primary Wi-Fi antenna.
  17. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Disconnect the secondary Wi-Fi antenna: adım 17, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Disconnect the secondary Wi-Fi antenna: adım 17, 2 resimden 2.
    • Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
  18. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: adım 18, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: adım 18, 2 resimden 2.
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
  19. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Unfasten the secondary Wi-Fi antenna: adım 19, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Unfasten the secondary Wi-Fi antenna: adım 19, 2 resimden 2.
    • Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
  20. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the secondary Wi-Fi antenna: adım 20, 3 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the secondary Wi-Fi antenna: adım 20, 3 resimden 2. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the secondary Wi-Fi antenna: adım 20, 3 resimden 3.
    • Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
    • Don't attempt to completely remove the antenna yet, as its coaxial cable is still routed through the frame.
  21. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement: adım 21, 3 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement: adım 21, 3 resimden 2. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement: adım 21, 3 resimden 3.
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable out of its slot in the frame.
    • Remove the secondary Wi-Fi antenna.
  22. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Unfasten the shield plate: adım 22, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Unfasten the shield plate: adım 22, 2 resimden 2.
    • Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
  23. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement: adım 23, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement: adım 23, 2 resimden 2.
    • Use your fingers to lift the top of the shield plate up and away from the frame.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  24. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Disconnect the battery: adım 24, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Disconnect the battery: adım 24, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the battery.
  25. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the tape: adım 25, 3 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the tape: adım 25, 3 resimden 2. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the tape: adım 25, 3 resimden 3.
    • Use tweezers, or your fingers, to remove the piece of tape obscuring the daughterboard's screw.
  26. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Unfasten the daughterboard: adım 26, 2 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Unfasten the daughterboard: adım 26, 2 resimden 2.
    • Use a Phillips driver to remove the 4 mm screw securing the daughterboard to the frame.
  27. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the daughterboard: adım 27, 3 resimden 1. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the daughterboard: adım 27, 3 resimden 2. Nintendo Switch OLED Model Game Card Reader Daughterboard Replacement, Remove the daughterboard: adım 27, 3 resimden 3.
    • The bottom of the daughterboard is connected to the motherboard via a press connector.
    • Insert a spudger between the edge of the daughterboard and the motherboard.
    • Pry up with the spudger to disconnect the press connector and separate the daughterboard from the frame.
    • Remove the daughterboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
164.275 İtibar
769 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.670 adet Kılavuz yazıldı
4Kılavuz Yorumları
Hello. Is this the part that replaces a damaged micro sd card reader on the OLED ? Thanks for the guidance
Roberto Cardoso - Yanıt
Hi Roberto!
Yes, the daughterboard holds both the microSD card reader and the game card reader.
Alex Diaz-Kokaisl -
The replacement part does not come with the micro sd reader & game card readers attached, is that correct?
jordinski - Yanıt
Attached to that replacement daughterboard is a new (1) gamecard reader, (2) microSD card reader and (3) headphone jack. No soldering required.
David Horowitz -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 84
Son 30 gün: 538
Her zaman: 10,816
