Ana içeriğe geç
Nintendo Switch OLED Model Screen Replacement
Neye ihtiyacın var
  1. Nintendo Switch OLED Model Screen Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement, Release the Joy Con controller locking tabs: adım 1, 3 resimden 3.
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch OLED Model Screen Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement, Remove the Joy Con controllers: adım 2, 3 resimden 3.
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch OLED Model Screen Replacement, Remove the top screw: adım 3, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the top screw: adım 3, 2 resimden 2.
    • Use a Phillips driver, or a JIS driver, to remove the 2 mm-long screw securing the top of the rear case to the frame.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS or Phillips driver if the screws won't come out.
    What if I don't have the screwdriver and I can't buy it
    Ivan ROSTRO jr - Yanıt
  4. Nintendo Switch OLED Model Screen Replacement, Remove the bottom screws: adım 4, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the bottom screws: adım 4, 2 resimden 2.
    • Use a Phillips driver to remove the two 2 mm-long screws securing the bottom of the rear case to the frame.
  5. Nintendo Switch OLED Model Screen Replacement, Remove the right screw: adım 5, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the right screw: adım 5, 2 resimden 2.
    • Use a Phillips driver to remove the 3.8 mm screw securing the right Joy-Con sensor rail to the rear case.
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
    all 3 need to be removed, not just the one.
    Roger - Yanıt
  6. Nintendo Switch OLED Model Screen Replacement, Remove the left screw: adım 6, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the left screw: adım 6, 2 resimden 2.
    • Use a Phillips driver to remove the 3.8 mm screw securing the left Joy-Con sensor rail to the rear case.
    Roger - Yanıt
  7. Nintendo Switch OLED Model Screen Replacement, Open the kickstand: adım 7, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Open the kickstand: adım 7, 2 resimden 2.
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  8. Nintendo Switch OLED Model Screen Replacement, Remove the back-side screws: adım 8, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the back-side screws: adım 8, 2 resimden 2.
    • Use a Y00 screwdriver to remove the two 4.3 mm screws securing the rear case to the frame.
    Before the next step remove any game cards in the console
    Zach - Yanıt
  9. Nintendo Switch OLED Model Screen Replacement, Remove the rear case: adım 9, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the rear case: adım 9, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement, Remove the rear case: adım 9, 3 resimden 3.
    • Lift the rear case up from the top of the device and remove it.
    • If you're having trouble removing the case, use an opening pick to pry up the plastic clips.
    Just a heads up that, even after removing the screws, the rear plate is still heavily clipped in place. I recommend using an opening pick or opening tool to carefully pry it up starting at the top and working your way down the sides. Once you get to the bottom, the speaker grilles are a little tricky. They're attached to the rear plate, but they can get stuck easily as you're removing the back plate.
    Craig Lloyd - Yanıt
  10. Nintendo Switch OLED Model Screen Replacement, Remove the shield plate's tape: adım 10, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the shield plate's tape: adım 10, 2 resimden 2.
    • Use the flat end of a spudger to separate a corner of the tape from the shield plate.
    Don't remove the antenna tape or the wires from the tape! The antennae can come off with the large metal shield plate anyways, so why remove them separately?? Extra UNNECESSARY WORK!! Just unscrew the antennae modules themselves, and pop out the antenna wires from the mainboard. Then they will lift with the large metal plate. (Steps 10, 11, 15, 16 are unnecessary, just remove the screws only that hold them down)
    hubbabubbahubbabubba9 - Yanıt
  11. Nintendo Switch OLED Model Screen Replacement: adım 11, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement: adım 11, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement: adım 11, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers, or your fingers, to peel back and remove the tape.
    • Store the tape in a clean space for reinstallation.
  12. Nintendo Switch OLED Model Screen Replacement, Disconnect the primary Wi-Fi antenna: adım 12, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Disconnect the primary Wi-Fi antenna: adım 12, 2 resimden 2.
    • Use tweezers, or your fingers, to pull up and disconnect the primary Wi-Fi antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  13. Nintendo Switch OLED Model Screen Replacement, Reroute the primary antenna's coaxial cable: adım 13, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement, Reroute the primary antenna's coaxial cable: adım 13, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement, Reroute the primary antenna's coaxial cable: adım 13, 3 resimden 3.
    • Use tweezers, or your fingers, to reroute the primary antenna's coaxial cable out of its slots in the shield plate.
  14. Nintendo Switch OLED Model Screen Replacement, Unfasten the primary Wi-Fi antenna: adım 14, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Unfasten the primary Wi-Fi antenna: adım 14, 2 resimden 2.
    • Use a Phillips driver to remove the two 4.4 mm screws securing the primary Wi-Fi antenna to the shield plate.
  15. Nintendo Switch OLED Model Screen Replacement, Remove the primary Wi-Fi antenna: adım 15, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the primary Wi-Fi antenna: adım 15, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement, Remove the primary Wi-Fi antenna: adım 15, 3 resimden 3.
    • Insert an opening pick between the primary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the primary Wi-Fi antenna from the shield plate.
  16. Nintendo Switch OLED Model Screen Replacement: adım 16, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement: adım 16, 2 resimden 2.
    • Remove the primary Wi-Fi antenna.
  17. Nintendo Switch OLED Model Screen Replacement, Disconnect the secondary Wi-Fi antenna: adım 17, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Disconnect the secondary Wi-Fi antenna: adım 17, 2 resimden 2.
    • Use tweezers, or your fingers, to pull up and disconnect the secondary Wi-Fi antenna's coaxial cable.
  18. Nintendo Switch OLED Model Screen Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: adım 18, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Reroute the secondary Wi-Fi antenna's coaxial cable: adım 18, 2 resimden 2.
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable from its slot in the frame.
  19. Nintendo Switch OLED Model Screen Replacement, Unfasten the secondary Wi-Fi antenna: adım 19, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Unfasten the secondary Wi-Fi antenna: adım 19, 2 resimden 2.
    • Use a Phillips driver to remove the 4.4 mm screw securing the secondary Wi-Fi antenna to the shield plate.
  20. Nintendo Switch OLED Model Screen Replacement, Remove the secondary Wi-Fi antenna: adım 20, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the secondary Wi-Fi antenna: adım 20, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement, Remove the secondary Wi-Fi antenna: adım 20, 3 resimden 3.
    • Insert an opening pick between the secondary Wi-Fi antenna and the shield plate.
    • Pry up with the pick to separate the secondary Wi-Fi antenna from the shield plate.
    • Don't attempt to completely remove the antenna yet, as its coaxial cable is still routed through the frame.
  21. Nintendo Switch OLED Model Screen Replacement: adım 21, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement: adım 21, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement: adım 21, 3 resimden 3.
    • Use the point of a spudger to reroute the secondary Wi-Fi antenna's coaxial cable out of its slot in the frame.
    • Remove the secondary Wi-Fi antenna.
  22. Nintendo Switch OLED Model Screen Replacement, Unfasten the shield plate: adım 22, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Unfasten the shield plate: adım 22, 2 resimden 2.
    • Use a Phillips driver to remove the six 4.4 mm screws securing the shield plate to the frame.
  23. Nintendo Switch OLED Model Screen Replacement: adım 23, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement: adım 23, 2 resimden 2.
    • Use your fingers to lift the top of the shield plate up and away from the frame.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as K5 Pro, during reassembly.
  24. Nintendo Switch OLED Model Screen Replacement, Disconnect the battery: adım 24, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Disconnect the battery: adım 24, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the battery.
    make sure you pry UP because it kinda looks like you pull it out and i almost broke my switch pulling out :/
    Soi - Yanıt
  25. Nintendo Switch OLED Model Screen Replacement, Remove the tape: adım 25, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the tape: adım 25, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement, Remove the tape: adım 25, 3 resimden 3.
    • Use tweezers, or your fingers, to remove the piece of tape obscuring the daughterboard's screw.
  26. Nintendo Switch OLED Model Screen Replacement, Unfasten the daughterboard: adım 26, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Unfasten the daughterboard: adım 26, 2 resimden 2.
    • Use a Phillips driver to remove the 4 mm screw securing the daughterboard to the frame.
  27. Nintendo Switch OLED Model Screen Replacement, Remove the daughterboard: adım 27, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the daughterboard: adım 27, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement, Remove the daughterboard: adım 27, 3 resimden 3.
    • The bottom of the daughterboard is connected to the motherboard via a press connector.
    • Insert a spudger between the edge of the daughterboard and the motherboard.
    • Pry up with the spudger to disconnect the press connector and separate the daughterboard from the frame.
    • Remove the daughterboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  28. Nintendo Switch OLED Model Screen Replacement, Disconnect the display's ZIF connector: adım 28, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Disconnect the display's ZIF connector: adım 28, 2 resimden 2.
    • Use an opening tool, spudger, or your fingernail to flip up the hinged locking flap on the display's ZIF connector.
  29. Nintendo Switch OLED Model Screen Replacement: adım 29, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement: adım 29, 2 resimden 2.
    • Use a pair of tweezers to pull the display cable straight out of its connector on the motherboard.
  30. Nintendo Switch OLED Model Screen Replacement, Heat the right edge: adım 30, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the screen for 90 seconds to loosen the adhesive underneath.
  31. Nintendo Switch OLED Model Screen Replacement, Insert an opening pick: adım 31, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement, Insert an opening pick: adım 31, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement, Insert an opening pick: adım 31, 3 resimden 3.
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    This step took quite a long time to complete. The adhesive on my switch was very strong, and required several repetitive cycles of heating and suctioning. One of the iFixit teardown videos of the OLED switch mentions using "consistent suction" to pull up the screen. I replaced the plastic lever on my suction cup with a metal chopstick. It helped with a very persistent and consistent pull that eventually separated the screen from the frame.
    zle896 - Yanıt
    Same as comment above, this adhesive is very strong and rigid. The iOpener didnt work for me on this stage after many times. I finally I used a soldering heat gun set at 215 F for about 15 seconds. That worked really well because I was able to leave the suction cup attached and apply constant pull while the warm air was heating the adhesive. Once you get the first pick in there, the rest is much easier.
    Helmrich - Yanıt
  32. Nintendo Switch OLED Model Screen Replacement, Separate the right edge adhesive: adım 32, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement, Separate the right edge adhesive: adım 32, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement, Separate the right edge adhesive: adım 32, 3 resimden 3.
    • Slide the pick along the right edge of the screen to separate the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  33. Nintendo Switch OLED Model Screen Replacement, Heat the top edge: adım 33, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the device for 90 seconds to loosen the adhesive underneath.
  34. Nintendo Switch OLED Model Screen Replacement, Separate the top-right corner adhesive: adım 34, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement, Separate the top-right corner adhesive: adım 34, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement, Separate the top-right corner adhesive: adım 34, 3 resimden 3.
    • Insert a new opening pick into the gap you created.
    • Rotate the opening pick around the top-right corner of the device.
  35. Nintendo Switch OLED Model Screen Replacement, Separate the top edge adhesive: adım 35, 3 resimden 1. Nintendo Switch OLED Model Screen Replacement, Separate the top edge adhesive: adım 35, 3 resimden 2. Nintendo Switch OLED Model Screen Replacement, Separate the top edge adhesive: adım 35, 3 resimden 3.
    • Slide the new pick along the right edge of the device towards the top-left corner.
    • Repeat the heating and slicing process on the remaining edges to separate the adhesive.
  36. Nintendo Switch OLED Model Screen Replacement, Remove the screen: adım 36, 2 resimden 1. Nintendo Switch OLED Model Screen Replacement, Remove the screen: adım 36, 2 resimden 2.
    Tesa 61395 Tape
    $5.99
    • Lift the screen off the device, threading the display cable through the frame as you do.
    • Take care not to snag any of the ribbon cables on the frame as you remove the screen.
    • You can reuse the screen adhesive if it is still sticky. Otherwise, replace the adhesive with double-sided tape such as Tesa tape.
    • During reassembly, make sure to thread the display cable through the frame before securing the screen adhesive.
    Which width of sticky tape is needed? I’d like to have everything ready before I open it up!
    Claire (TomAndJerry) - Yanıt
    Hi Claire!
    We don't typically give widths because you could realistically use 1-4 mm tape or even two side-by-side layers of 1 mm if you don't want to buy 2 mm tape, but you're right that we should have limits or recommendations! For this repair, 2 mm tape should work well. You can also use multiple layers of 1 mm depending on what future repairs you want to use with the leftover tape.
    Alex Diaz-Kokaisl -
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
11 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
164.284 İtibar
769 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
9Kılavuz Yorumları
Amazing guide! Steps were easy to follow and allowed me to knock out my Switch OLED screen replacement in about 1.5-2 hours, including a few intermissions to clean the internals. The only thing I would add to this guide are a few steps at the end for removing the old adhesive, applying the new Tesa tape, folding/threading the ribbon cable on the new screen, and plugging the ribbon cable into the Switch to make this a true one-stop shop. The 1mm Tesa tape worked like a charm, although there is one side of the screen frame where you need to do three strips instead of one, you don't have to buy a bigger size just for that side. Thanks again iFixit! Y'all rock!
Kyle Bartolo - Yanıt
Hi Kyle.
Thank you for the appreciation and the tips! I changed the last step a bit to hopefully remind people to re-thread the display cable. We will consider making a dedicated reassembly step ;)
Alex Diaz-Kokaisl -
nope not doin this
alex gamer - Yanıt
I stripped a screw on my Nintendo Switch OLED, now there’s absolutely no way for me to open it, I wanted to replace my Nintendo Switch Card Cover, and now I can’t. I’m gonna have to get a new Switch now :(
shayne_lavallee - Yanıt
Oh my goodness, I'm sorry to hear that! We've all been there. If you're willing to try something to remove the stripped screw, you can check out this guide for some strategies. Please let us know how it works out!
Alex Diaz-Kokaisl -
Thank you for this help
Thanh Tam - Yanıt
Thanks for these great instructions, much easier than following a video. I couldn’t find which width of Tesa tape to use, I used 2mm which worked fine. Was also unsure how much heat-conducting paste to use, so I guessed! My biggest problem ( nothing to do with the instructions); was that the old screen was so firmly stuck that it wouldn’t lift at all, it was only possible to remove it by breaking it some more. Anyway, new screen is now fitted, so my kids are going to be very happy to be able to use it in handheld mode again.
Hi,
Do you have this tutorial in Spanish?
Nice job!
Regrets from Honduras.
Sincerely,
Gerardo Carbajal
Gerardo Carbajal - Yanıt
He seguido tus pasos al pie de la letra, pero he usado un secador de pelo para separar la pantalla, a distancia corta de la misma, solo en los bordes, con un tiempo inferior a 20 segundos. Antes de separar la pantalla antigua he probado la nueva y funcionaba correctamente aunque ambas presentaban el problema de no funcionar el tactil, aun asi segui en mi cruzada y monte la pantalla nueva sabiendo que ya funcionaba ( al menos la imagen ) y al tratar de encenderla la pantalla no mostraba imagen, pense que era la bateria y lo conecte a la corriente, al intentar de nuevo sono un bip pero no habia imagen, pense que habia cometido algun error asi probe la pantalla antigua y nada, sin imagen, a que podria deberse este problema?
Lorenzo A - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 70
Son 7 gün: 424
Son 30 gün: 1,741
Her zaman: 50,933
