Ana içeriğe geç
Opening the Galaxy Watch3
Tobias Isakeit
Tobias Isakeit
En son May 27, 2024 tarihinde güncellendi
3 - 6 dakika
Orta
Use this guide to remove the back cover of the Samsung Galaxy Watch3.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Opening the Galaxy Watch3, Unfasten the back cover screws: adım 1, 1 resimden 1.
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
    I heeded your advice - and now need another screw because it fell out!!!
    Paul - Yanıt
    I must have stripped the screws out or either the dirt and sweat is so packed into the screw i can't get a good bite to unscrew the screws. What can I do about this? This watch battery DOES NOT hold a charge for more than 5min, should I trash the watch?
    ShaneWizdum - Yanıt
  2. Opening the Galaxy Watch3, Wedge open the back cover: adım 2, 2 resimden 1. Opening the Galaxy Watch3, Wedge open the back cover: adım 2, 2 resimden 2.
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
    Could not get the back housing off
    Joseph Ortiz, Jr - Yanıt
  3. Opening the Galaxy Watch3, Disconnect the sensor flex cable: adım 3, 3 resimden 1. Opening the Galaxy Watch3, Disconnect the sensor flex cable: adım 3, 3 resimden 2. Opening the Galaxy Watch3, Disconnect the sensor flex cable: adım 3, 3 resimden 3.
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  4. Opening the Galaxy Watch3, Remove the back cover: adım 4, 2 resimden 1. Opening the Galaxy Watch3, Remove the back cover: adım 4, 2 resimden 2.
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
    Where would one get a new rubber water gasket if the old one is damaged by this process?
    Jack Popham - Yanıt
    I need also the Rubber Sealing. Anyone got a replacement part?
    Steffen Politzky -
    Me too, I'm tired of searching for one, they don't exist.
    Karl Roberts - Yanıt
    If anyone has the red ringed gasket in the photo please share a link to buy or part code to search for etc. I am constantly drawing a blank no matter what key words I search. It's utterly crushing not to have this part easily available.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
124.417 İtibar
189 adet Kılavuz yazıldı
Ekip
5Kılavuz Yorumları
where can I get the galaxy watch3 rubber gasket?
regards
Miguel Vera - Yanıt
That’s a good question. As for the previous models it is very hard to find those rubber gaskets. Using a “liquid rubber gasket” might be one solution to that. (Use carefully to not spill too much on and into the watch)
Tobias Isakeit -
I tried to remove all of the screws from the back cover, but 3 of the 4 screws remained and seemed to be fused to the main base of the watch. One of the screws was stripped. Now only 1 screw is engaged with the back cover. (I might need to replace the back cover. My watch is glitching which is draining the battery. I would like to fix the problems myself. Where can I get specific advice?
Antoinette - Yanıt
Hallo Hallo..Ich kann gar nicht offnen galaxy watch 4 classic.Fast alle schraube dreher gekauft aber für nichts einfach geht nicht raus schraube.wollte ich akku wechseln..kann mir jemand helfen?
Danke
maia margishvili - Yanıt
@isakrittl Du schreibst: "Achte darauf, dass die Gummidichtung (rot markiert) in Ordnung ist. Falls sie beschädigt ist, ersetze sie beim Zusammenbau durch eine neue, damit die Uhr wasserdicht bleibt."
Wo bekomme ich denn eine neue her? Hab nirgends eine gefunden... Danke!
Steffen Politzky - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 95
Her zaman: 3,375
