Ana içeriğe geç
Petcube Play 2 LED Replacement
Neye ihtiyacın var
  1. Petcube Play 2 LED Replacement, Motherboard: adım 1, 3 resimden 1. Petcube Play 2 LED Replacement, Motherboard: adım 1, 3 resimden 2. Petcube Play 2 LED Replacement, Motherboard: adım 1, 3 resimden 3.
    • Flip over the Petcube so the rubber bottom faces you.
    • Use an iFixit opening pick to pull up the rubber layer and expose the screws underneath.
  2. Petcube Play 2 LED Replacement: adım 2, 2 resimden 1. Petcube Play 2 LED Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the four 3.5 mm screws under the rubber cover.
    • The glue may cause a bit of resistance but the screws should come up without much effort.
  3. Petcube Play 2 LED Replacement: adım 3, 2 resimden 1. Petcube Play 2 LED Replacement: adım 3, 2 resimden 2.
    • Use an opening pick or spudger to pry off the glass front panel.
    • Do not force the front panel off as it may crack and break.
  4. Petcube Play 2 LED Replacement: adım 4, 3 resimden 1. Petcube Play 2 LED Replacement: adım 4, 3 resimden 2. Petcube Play 2 LED Replacement: adım 4, 3 resimden 3.
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum.
  5. Petcube Play 2 LED Replacement: adım 5, 3 resimden 1. Petcube Play 2 LED Replacement: adım 5, 3 resimden 2. Petcube Play 2 LED Replacement: adım 5, 3 resimden 3.
    • Once the internal assembly is removed, you should see a brass cylinder in the top left of the front face of the cube. At the top of that cylinder is a hole that leads down to a screw.
    • Remove it using a Phillips head size #1 screwdriver.
  6. Petcube Play 2 LED Replacement: adım 6, 3 resimden 1. Petcube Play 2 LED Replacement: adım 6, 3 resimden 2. Petcube Play 2 LED Replacement: adım 6, 3 resimden 3.
    • Flip the cube onto one of its sides to locate the pull tabs holding the two halves together.
    • Lift each of the five tabs using an opening tool to separate the two halves of the Petcube 2.
  7. Petcube Play 2 LED Replacement: adım 7, 3 resimden 1. Petcube Play 2 LED Replacement: adım 7, 3 resimden 2. Petcube Play 2 LED Replacement: adım 7, 3 resimden 3.
    • Disconnect the cable connectors to separate the two halves of the device.
    • Make sure to avoid pulling on the wires to prevent breaking them or the connectors.
  8. Petcube Play 2 LED Replacement: adım 8, 3 resimden 1. Petcube Play 2 LED Replacement: adım 8, 3 resimden 2. Petcube Play 2 LED Replacement: adım 8, 3 resimden 3.
    • Use the size #1 Phillips screwdriver to remove the two 1 mm screws.
    • Carefully release the three tabs and take out the motherboard.
    • Be gentle with the tabs as they will break under too much pressure.
  9. Petcube Play 2 LED Replacement, LED: adım 9, 3 resimden 1. Petcube Play 2 LED Replacement, LED: adım 9, 3 resimden 2. Petcube Play 2 LED Replacement, LED: adım 9, 3 resimden 3.
    • The next step is to remove the front plates from each other. This is located behind the motherboard and is shown in the pictures.
    • To do this you will need to remove the highlighted screws using a #1 Phillips head screwdriver.
  10. Petcube Play 2 LED Replacement: adım 10, 3 resimden 1. Petcube Play 2 LED Replacement: adım 10, 3 resimden 2. Petcube Play 2 LED Replacement: adım 10, 3 resimden 3.
    • First, remove the front plastic casing from the circuit board
    • Next, identify the LED and the foam protector.
    • Remove the foam protector using thin tweezers and gently pulling upwards.
    • Finally, use a soldering iron to desolder the LED from the board and solder the new LED in the same place and orientation.
    • Never touch a hot soldering iron.
    • When soldering, be careful not to damage any other components be resting the iron on them. Remove the solder on the LED only, then solder the new one on.
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Christopher Pereira
181 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Konn Spring 2024 UMass Dartmouth, Team 1-5, Konn Spring 2024 üyesi
UMASSD-KONN-S24S1G5
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 47
Her zaman: 108
