Ana içeriğe geç
Petcube Play 2 Microphone Replacement
Neye ihtiyacın var
  1. Petcube Play 2 Microphone Replacement, Motherboard: adım 1, 3 resimden 1. Petcube Play 2 Microphone Replacement, Motherboard: adım 1, 3 resimden 2. Petcube Play 2 Microphone Replacement, Motherboard: adım 1, 3 resimden 3.
    • Flip over the Petcube so the rubber bottom faces you.
    • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
    FixBot'a Sor
    Yorum Ekle
  2. Petcube Play 2 Microphone Replacement: adım 2, 2 resimden 1. Petcube Play 2 Microphone Replacement: adım 2, 2 resimden 2.
    • Remove the four 3.5mm screws from under the rubber cover using a Phillips #1 screwdriver.
    • The glue may cause slight resistance, but the screws should come out with minimal effort.
    FixBot'a Sor
    Yorum Ekle
  3. Petcube Play 2 Microphone Replacement: adım 3, 2 resimden 1. Petcube Play 2 Microphone Replacement: adım 3, 2 resimden 2.
    • Carefully pry off the glass front panel using an opening pick or a spudger.
    • Do not force the front panel off, as it may crack and break.
    FixBot'a Sor
    Yorum Ekle
  4. Petcube Play 2 Microphone Replacement: adım 4, 3 resimden 1. Petcube Play 2 Microphone Replacement: adım 4, 3 resimden 2. Petcube Play 2 Microphone Replacement: adım 4, 3 resimden 3.
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum casing.
    FixBot'a Sor
    Yorum Ekle
  5. Petcube Play 2 Microphone Replacement: adım 5, 3 resimden 1. Petcube Play 2 Microphone Replacement: adım 5, 3 resimden 2. Petcube Play 2 Microphone Replacement: adım 5, 3 resimden 3.
    • Once the internal assembly is removed, a brass cylinder in one corner of the cube's front face will be visible. A screw will be attached to it.
    • Remove the screw with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Petcube Play 2 Microphone Replacement: adım 6, 3 resimden 1. Petcube Play 2 Microphone Replacement: adım 6, 3 resimden 2. Petcube Play 2 Microphone Replacement: adım 6, 3 resimden 3.
    • Flip the cube onto its side to locate the pull tabs.
    • Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
    FixBot'a Sor
    Yorum Ekle
  7. Petcube Play 2 Microphone Replacement: adım 7, 3 resimden 1. Petcube Play 2 Microphone Replacement: adım 7, 3 resimden 2. Petcube Play 2 Microphone Replacement: adım 7, 3 resimden 3.
    • Gently disconnect the cable connectors to separate the two halves of the device.
    • Avoid pulling on the wires to prevent damage to the connectors.
    FixBot'a Sor
    Yorum Ekle
  8. Petcube Play 2 Microphone Replacement: adım 8, 3 resimden 1. Petcube Play 2 Microphone Replacement: adım 8, 3 resimden 2. Petcube Play 2 Microphone Replacement: adım 8, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the two 1mm screws.
    • Carefully release each of the tabs on the sides of the cube and remove the motherboard.
    • Be gentle with the tabs. They will break under too much pressure.
    FixBot'a Sor
    Yorum Ekle
  9. Petcube Play 2 Microphone Replacement, Microphone: adım 9, 3 resimden 1. Petcube Play 2 Microphone Replacement, Microphone: adım 9, 3 resimden 2. Petcube Play 2 Microphone Replacement, Microphone: adım 9, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the screws from the plates behind the motherboard, separating the two plates.
    FixBot'a Sor
    Yorum Ekle
  10. Petcube Play 2 Microphone Replacement: adım 10, 2 resimden 1. Petcube Play 2 Microphone Replacement: adım 10, 2 resimden 2.
    • Detach the PCB with the microphones from the plastic.
    • Using a soldering iron, desolder the microphones from the PCB.
    • Be careful! The soldering iron becomes hot! Avoid touching the device for too long, as this may damage the components.
    • To Avoid burning yourself or damaging the device, follow the IFixit soldering instructions
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
Jacob Branco
291 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Konn Spring 2024 UMass Dartmouth, Team 1-5, Konn Spring 2024 üyesi
UMASSD-KONN-S24S1G5
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 26
Her zaman: 353
