Ana içeriğe geç
PlayStation Portal Speaker (Right) Replacement
Neye ihtiyacın var
  1. PlayStation Portal Speaker (Right) Replacement, Power off your PlayStation Portal: adım 1, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Power off your PlayStation Portal: adım 1, 2 resimden 2.
    • Let your PlayStation Portal's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • If your battery is swollen, take appropriate precautions.
    • Power off your Portal and unplug any cables.
  2. PlayStation Portal Speaker (Right) Replacement, Pry up the L1 bumper: adım 2, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement, Pry up the L1 bumper: adım 2, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement, Pry up the L1 bumper: adım 2, 3 resimden 3.
    • Both bumpers are held in place with clips.
    • Rest a finger over the L1 bumper to prevent it from flying off when you pry.
    • Insert the flat end of a spudger between the top edge of the bumper and the white shell.
    • Pry up to unclip the bumper.
    • Slide the spudger along the seam to release any remaining clips.
  3. PlayStation Portal Speaker (Right) Replacement: adım 3, 1 resimden 1.
    • Remove the L1 bumper.
  4. PlayStation Portal Speaker (Right) Replacement, Pry up the R1 bumper: adım 4, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement, Pry up the R1 bumper: adım 4, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement, Pry up the R1 bumper: adım 4, 3 resimden 3.
    • Repeat the procedure to pry up and remove the R1 bumper.
  5. PlayStation Portal Speaker (Right) Replacement, Reassembly information: adım 5, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement, Reassembly information: adım 5, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement, Reassembly information: adım 5, 3 resimden 3.
    • To install a bumper during reassembly:
    • Align the bumper into its slot.
    • Use a finger to press the bumper down firmly until it clicks into place.
  6. PlayStation Portal Speaker (Right) Replacement, Loosen the left joystick trim strip: adım 6, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Loosen the left joystick trim strip: adım 6, 2 resimden 2.
    • Insert the tip of an opening pick underneath the left joystick trim strip, where it wraps below the grip.
    • Twist the opening pick to release the bottom clip.
  7. PlayStation Portal Speaker (Right) Replacement: adım 7, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 7, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement: adım 7, 3 resimden 3.
    • Insert the tip of an opening pick underneath the outer edge of the trim strip.
    • Slide the opening pick along the edge to release the clips.
  8. PlayStation Portal Speaker (Right) Replacement: adım 8, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 8, 2 resimden 2.
    • Insert the tip of an opening pick under the inner edge of the strip.
  9. PlayStation Portal Speaker (Right) Replacement: adım 9, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 9, 2 resimden 2.
    • Grasp the bottom edge of the trim strip and slowly lift to release any remaining clips.
    • If the strip feels stuck, twist or shift the strip sideways to help release any stubborn clips.
  10. PlayStation Portal Speaker (Right) Replacement, Remove the left joystick trim strip: adım 10, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Remove the left joystick trim strip: adım 10, 2 resimden 2.
    • Lift and remove the left joystick trim strip.
  11. PlayStation Portal Speaker (Right) Replacement, Remove the right joystick trim strip: adım 11, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement, Remove the right joystick trim strip: adım 11, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement, Remove the right joystick trim strip: adım 11, 3 resimden 3.
    • Repeat the procedure to unclip and remove the right joystick trim strip.
  12. PlayStation Portal Speaker (Right) Replacement, Reassembly information: adım 12, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Reassembly information: adım 12, 2 resimden 2.
    • To reattach a trim strip during reassembly:
    • Use your fingers to align and clip the top edge in place.
    • Firmly press along the remaining edges to clip the strip in place.
  13. PlayStation Portal Speaker (Right) Replacement, Remove the back shell screws: adım 13, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Remove the back shell screws: adım 13, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws at the bottom tips of each grip.
    • You may need to peel off some tamper-evident stickers to access the screws.
  14. PlayStation Portal Speaker (Right) Replacement: adım 14, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 14, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the top corners of the shell.
  15. PlayStation Portal Speaker (Right) Replacement, Back shell information: adım 15, 1 resimden 1.
    • The back shell is still secured with numerous clips. The next few steps will show how to unclip the shell while reducing the chance of damaging the clips.
  16. PlayStation Portal Speaker (Right) Replacement, Unclip the back shell: adım 16, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Unclip the back shell: adım 16, 2 resimden 2.
    • Push the flat edge of a spudger into the back shell's left, inner seam.
    • This releases the clip in that area while flexing the shell slightly, creating a larger outer seam.
    • Keep the spudger inserted in the seam.
  17. PlayStation Portal Speaker (Right) Replacement: adım 17, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 17, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement: adım 17, 3 resimden 3.
    • Insert the tip of an opening pick into the shell's left, outer seam.
    • Slide the pick along the seam to release the clips securing the edge.
    • Keep a pick in the seam to prevent the shell from clipping back together.
  18. PlayStation Portal Speaker (Right) Replacement: adım 18, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 18, 2 resimden 2.
    • Remove the spudger from the inner seam.
  19. PlayStation Portal Speaker (Right) Replacement: adım 19, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 19, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement: adım 19, 3 resimden 3.
    • Repeat the previous three steps on the right side of the Portal to release the clips along the right edge.
  20. PlayStation Portal Speaker (Right) Replacement: adım 20, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 20, 2 resimden 2.
    • Carefully flip your Portal over.
    • Grasp the top edge of the back shell, near a corner.
    • Gently pull the top edge away until you feel the clips release in that corner.
  21. PlayStation Portal Speaker (Right) Replacement: adım 21, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 21, 2 resimden 2.
    • Pull along the top edge to release all the top edge clips.
  22. PlayStation Portal Speaker (Right) Replacement: adım 22, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 22, 2 resimden 2.
    • Grasp the bottom edge of the back shell, near the center.
    • Pull away with firm force to release the clips securing the bottom edge.
  23. PlayStation Portal Speaker (Right) Replacement, Remove the back shell: adım 23, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Remove the back shell: adım 23, 2 resimden 2.
    • Remove the back shell.
  24. PlayStation Portal Speaker (Right) Replacement, Reassembly information: adım 24, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement, Reassembly information: adım 24, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement, Reassembly information: adım 24, 3 resimden 3.
    • To clip the back shell in place during reassembly:
    • Align the corners near the trigger buttons first.
    • Firmly press around the entire perimeter to clip the shell back in place.
  25. PlayStation Portal Speaker (Right) Replacement, Loosen the left grip shell: adım 25, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Loosen the left grip shell: adım 25, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the left grip shell to the Portal.
    • From the back, these screws are on the right side of the Portal.
    • These screws can be tight. Brace the Portal with your hand and apply strong pressure to the screwdriver.
    • You can also try using a JIS #00 screwdriver to get a better grip on these screws.
  26. PlayStation Portal Speaker (Right) Replacement: adım 26, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 26, 2 resimden 2.
    • Grasp the top edge of the grip shell and twist it slightly outwards (away from the screen) to release the inner clips.
  27. PlayStation Portal Speaker (Right) Replacement, Remove the left grip shell: adım 27, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement, Remove the left grip shell: adım 27, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement, Remove the left grip shell: adım 27, 3 resimden 3.
    • Insert the flat edge of a spudger underneath the inner edge of the grip shell, near the vibration motor.
    • Twist the spudger along the edge to unclip the bottom portion of the grip shell.
    • Remove the left grip shell.
  28. PlayStation Portal Speaker (Right) Replacement, Remove the left joystick cover: adım 28, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the left joystick cover.
  29. PlayStation Portal Speaker (Right) Replacement: adım 29, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 29, 2 resimden 2.
    • Lift and remove the left joystick cover.
  30. PlayStation Portal Speaker (Right) Replacement, Remove the left joystick grip: adım 30, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Remove the left joystick grip: adım 30, 2 resimden 2.
    • Lift and remove the left grip from the joystick.
  31. PlayStation Portal Speaker (Right) Replacement, Loosen the left joystick: adım 31, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Loosen the left joystick: adım 31, 2 resimden 2.
    • Use the point of a spudger to flip up the black lock tab on the left joystick's ZIF connector.
  32. PlayStation Portal Speaker (Right) Replacement: adım 32, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 2.9 mm‑long screws securing the joystick module to the Portal.
  33. PlayStation Portal Speaker (Right) Replacement, Remove the left joystick: adım 33, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement, Remove the left joystick: adım 33, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement, Remove the left joystick: adım 33, 3 resimden 3.
    • Shift the joystick module so that the flex cable slides out of its socket.
    • Remove the left joystick.
    • During reassembly, slide the joystick cable into its socket before securing the joystick in place with screws.
  34. PlayStation Portal Speaker (Right) Replacement, Loosen the right grip shell: adım 34, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Loosen the right grip shell: adım 34, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the right grip shell to the Portal.
    • From the back, these screws are on the left side of the Portal.
  35. PlayStation Portal Speaker (Right) Replacement: adım 35, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 35, 2 resimden 2.
  36. PlayStation Portal Speaker (Right) Replacement, Remove the right grip shell: adım 36, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement, Remove the right grip shell: adım 36, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement, Remove the right grip shell: adım 36, 3 resimden 3.
    • Remove the right grip shell.
  37. PlayStation Portal Speaker (Right) Replacement, Remove the right joystick cover: adım 37, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the right joystick cover.
  38. PlayStation Portal Speaker (Right) Replacement: adım 38, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 38, 2 resimden 2.
    • Lift and remove the right joystick cover.
  39. PlayStation Portal Speaker (Right) Replacement, Remove the right joystick grip: adım 39, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Remove the right joystick grip: adım 39, 2 resimden 2.
    • Lift and remove the right grip from the joystick.
  40. PlayStation Portal Speaker (Right) Replacement, Loosen the right joystick: adım 40, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Loosen the right joystick: adım 40, 2 resimden 2.
    • Use the point of a spudger to flip up the black lock tab on the right joystick's ZIF connector.
  41. PlayStation Portal Speaker (Right) Replacement: adım 41, 1 resimden 1.
  42. PlayStation Portal Speaker (Right) Replacement, Remove the right joystick: adım 42, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement, Remove the right joystick: adım 42, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement, Remove the right joystick: adım 42, 3 resimden 3.
    • Remove the right joystick.
  43. PlayStation Portal Speaker (Right) Replacement, Loosen the joystick brackets: adım 43, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Loosen the joystick brackets: adım 43, 2 resimden 2.
    • Use a Phillips screwdriver to remove the four 6.5 mm‑long screws (two on each side) securing the two joystick brackets to the Portal.
    • These screws can be tight. Brace the Portal with your hand and apply strong pressure to the screwdriver. You can also try using a JIS #00 screwdriver to get a better grip on these screws.
  44. PlayStation Portal Speaker (Right) Replacement: adım 44, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 44, 2 resimden 2.
    • Each joystick bracket is still attached to the Portal by a delicate flex cable. Be careful not to strain the cable as you move the bracket.
    • Carefully flip the right bracket over so that it no longer blocks the edge of the screen.
    • Repeat the process for the left bracket.
  45. PlayStation Portal Speaker (Right) Replacement: adım 45, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 45, 2 resimden 2.
    • Use tape to secure the two brackets to the frame so they don't block the screen.
    • Make sure the delicate flex cables aren't strained when the brackets are taped down.
  46. PlayStation Portal Speaker (Right) Replacement, Loosen the screen: adım 46, 1 resimden 1.
    • Heat an iOpener and apply it to the bottom edge of the screen for two minutes to soften the adhesive.
    • You can also use a hair dryer, heat gun, or hot plate, but be careful not to overheat the device—the display and internal battery are both susceptible to heat damage.
  47. PlayStation Portal Speaker (Right) Replacement: adım 47, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 47, 2 resimden 2.
    • Place your fingers underneath the bottom edge of the Portal to keep it steady.
    • Apply a suction handle to the center of the bottom edge, as close to the edge as possible.
  48. PlayStation Portal Speaker (Right) Replacement: adım 48, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 48, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement: adım 48, 3 resimden 3.
    • This step shows how to create an initial gap using an opening tool. If you don't have an opening tool, skip to the next step.
    • Pull up on the suction handle with strong, steady force.
    • Press the edge of an opening tool downwards into the seam to create an initial gap.
    • If you're having trouble, reheat the edge and try again.
    • Insert the tip of an opening pick into the gap.
    • Don't insert the pick more than 2 mm, or you may damage the screen.
  49. PlayStation Portal Speaker (Right) Replacement: adım 49, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 49, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement: adım 49, 3 resimden 3.
    • This step shows how to create an initial gap using an opening pick.
    • Pull up on the suction handle with strong, steady force to create a gap between the screen and frame.
    • If you can't insert the pick, heat the edge and try again. You may need to repeat the process multiple times before the adhesive loosens enough to insert the pick.
  50. PlayStation Portal Speaker (Right) Replacement: adım 50, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 50, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement: adım 50, 3 resimden 3.
    • Angle the opening pick downwards to a 45° angle.
    • This helps the opening pick slide underneath the display panel.
    • Insert the opening pick deeper into the seam until the pick can stay in place by itself.
    • You can insert the pick more than 2 mm once you've angled the pick.
  51. PlayStation Portal Speaker (Right) Replacement: adım 51, 1 resimden 1.
    • Apply a heated iOpener to the bottom edge of the screen for a minute to reheat the edge.
  52. PlayStation Portal Speaker (Right) Replacement: adım 52, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 52, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement: adım 52, 3 resimden 3.
    • Slide the opening pick along the bottom edge to slice through the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  53. PlayStation Portal Speaker (Right) Replacement: adım 53, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 53, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement: adım 53, 3 resimden 3.
    • Repeat the heating and slicing procedure around the left and top edges of the screen. Leave an opening pick in each corner to prevent the adhesive from resealing.
    • There are no cables along these edges, so you can insert the pick deeper than 2 mm.
  54. PlayStation Portal Speaker (Right) Replacement: adım 54, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 54, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement: adım 54, 3 resimden 3.
  55. PlayStation Portal Speaker (Right) Replacement: adım 55, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 55, 2 resimden 2.
    • Grasp the left edge of the screen near the corners and lift it slightly to separate any remaining adhesive.
  56. PlayStation Portal Speaker (Right) Replacement: adım 56, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 56, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement: adım 56, 3 resimden 3.
    • Be careful not to strain the short display cable as you move the screen.
    • Swing the left edge of the screen over the right and rest the flipped screen on top of the Portal.
  57. PlayStation Portal Speaker (Right) Replacement: adım 57, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 57, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement: adım 57, 3 resimden 3.
    • Rest a finger on top of the display cable bracket to prevent it from flying off when you pry.
    • Insert the point of a spudger underneath a corner of the bracket and pry it up.
    • Remove the bracket.
  58. PlayStation Portal Speaker (Right) Replacement: adım 58, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 58, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  59. PlayStation Portal Speaker (Right) Replacement, Remove the screen: adım 59, 1 resimden 1.
    • Remove the screen.
  60. PlayStation Portal Speaker (Right) Replacement, Reassembly information: adım 60, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Reassembly information: adım 60, 2 resimden 2.
    Bu adımda kullanılan alet:
    Tesa 61395 Tape
    $2.99
    • You'll need to replace the adhesive to reattach the screen:
    • To ensure a good adhesive bond, thoroughly clean all adhesion surfaces.
    • Remove large chunks of adhesives with the flat edge of a spudger or tweezers.
    • Use high concentration isopropyl alcohol (>90%) to remove any remaining residue. Wipe in one direction with a lint-free cloth or coffee filter until all the adhesive residue is gone.
    • Allow any leftover isopropyl alcohol to completely evaporate before reassembly.
    • Apply strips of double-sided tape such as Tesa tape to the screen perimeter to reattach the screen.
  61. PlayStation Portal Speaker (Right) Replacement, Loosen the motherboard cover: adım 61, 1 resimden 1.
    • Use a Phillips screwdriver to remove the eight 6.5 mm‑long screws securing the motherboard cover to the Portal.
  62. PlayStation Portal Speaker (Right) Replacement: adım 62, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement: adım 62, 2 resimden 2.
    • Insert the flat edge of a spudger under the top-right corner of the motherboard cover.
    • Pry up to release the clips securing the corner.
  63. PlayStation Portal Speaker (Right) Replacement, Remove the motherboard cover: adım 63, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Remove the motherboard cover: adım 63, 2 resimden 2.
    • Lift and remove the motherboard cover.
    • During reassembly, lay the cover in place and press along the edges to clip it in place.
  64. PlayStation Portal Speaker (Right) Replacement, Disconnect the battery: adım 64, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Disconnect the battery: adım 64, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the battery connector.
  65. PlayStation Portal Speaker (Right) Replacement, Power off your PlayStation Portal: adım 65, 2 resimden 1. PlayStation Portal Speaker (Right) Replacement, Power off your PlayStation Portal: adım 65, 2 resimden 2.
    • Before you begin repairs, power off your PlayStation Portal and unplug any cables.
  66. PlayStation Portal Speaker (Right) Replacement, Loosen the right speaker: adım 66, 1 resimden 1.
    • Use a Phillips screwdriver to remove the three screws securing the right speaker to the Portal:
    • Two 2.9 mm‑long screws
    • One 6.5 mm‑long screw
    • This screw can be tight. Brace the Portal with your hand and apply strong pressure to the screwdriver. You can also try using a JIS #00 screwdriver to get a better grip on the screw.
  67. PlayStation Portal Speaker (Right) Replacement, Remove the right speaker: adım 67, 3 resimden 1. PlayStation Portal Speaker (Right) Replacement, Remove the right speaker: adım 67, 3 resimden 2. PlayStation Portal Speaker (Right) Replacement, Remove the right speaker: adım 67, 3 resimden 3.
    • Insert the point of a spudger underneath the bottom right corner of the right speaker.
    • Pry up and remove the right speaker.
Sonuç
Arthur Shi
281.866 İtibar
585 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.418 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 100
