Ana içeriğe geç
Professional Series PS77401 Shell Removal
Zachary
Zachary ve 4 diğer katkıda bulunanlar
En son January 25, 2016 tarihinde güncellendi
5 dakika
Kolay
This guide will show you how to safely remove the outer shell of the toaster. Note that the outer shell is not the chassis.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Professional Series PS77401 Shell Removal, Shell: adım 1, 1 resimden 1.
    • Make sure that the toaster is unplugged before attempting any sort of disassembly!
  2. Professional Series PS77401 Shell Removal: adım 2, 2 resimden 1. Professional Series PS77401 Shell Removal: adım 2, 2 resimden 2.
    • Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
    • If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
  3. Professional Series PS77401 Shell Removal: adım 3, 3 resimden 1. Professional Series PS77401 Shell Removal: adım 3, 3 resimden 2. Professional Series PS77401 Shell Removal: adım 3, 3 resimden 3.
    • Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
    • Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
    • The outer shell should now only be connected by its internal wiring.
  4. Professional Series PS77401 Shell Removal: adım 4, 2 resimden 1. Professional Series PS77401 Shell Removal: adım 4, 2 resimden 2.
    • Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
    • The shell should now be completely separated from the rest of the toaster.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zachary
243 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-36, Maness Winter 2014 Cal Poly, Team 10-36, Maness Winter 2014 üyesi
CPSU-MANESS-W14S10G36
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 745
